Moogulator
Admin
18-CHANNEL PERFORMANCE MIXER WITH STEP-SEQUENCED FX, TRANSPORT, AND TEMPO CONTROL
The MX-1 Mix Performer brings together your synths, drum machines, loops, DAW tracks, and more into a single performance-optimized mixing instrument. Combining elements of a mixer, control surface, audio interface, and step-based effector, the MX-1 is designed to be the nerve center of your electronic music rig. It’s a mixer you can play – and so much more.
Tempo40-300Scene Memory16 x 4 (Bank A, B)BEAT FXFILTER: 5 types
SIDE CHAIN: 5 types
SLICER: 5 typesMASTER FXDELAY: 8 types
FILTER: 8 types
SCATTER: 8 types
FLANGER: 8 types
BIT CRUSH: 8 types
ROLL: 8 typesMASTERING10 typesNumber of USB Audio Max Input/Output ChannelsSampling frequency: 96 kHz, 48 kHz, 44.1 kHz
Input: 18 channels
Output: 18 channelsSignal ProcessingPC interface: 24 bits
AD/DA conversion: 24 bitsSampling FrequencyAD/DA conversion: 96, 48, 44.1 kHz
DIGITAL (IN, OUT): 96, 48, 44.1 kHzNominal Input Level (variable)Input 1–4: -26– +4 dBu
Input 5/6: -26– +4 dBuNominal Output LevelMIX OUT: +4 dBuHead Room18 dBInput ImpedanceInput 1–4: 100 k ohms
Input 5/6: 100 k ohmsOutput ImpedanceMIX OUT: 1 k ohm
PHONES: 24 ohmsFrequency Response96.0 kHz: 20 Hz–40 kHz (+0/-2 dB)
48.0 kHz: 20 Hz–22 kHz (+0/-2 dB)
44.1 kHz: 20 Hz–20 kHz (+0/-2 dB)Dynamic RangeAD block INPUT 1–4: 100 dB typ.
AD block INPUT 5/6: 100 dB typ.
DA block MIX OUT: 108 dB typ.ConnectorsPHONES jack: 1/4-inch stereo phone type
MIX OUT (L/MONO, R) jacks: 1/4-inch phone type (unbalance)
INPUT 1–4 (L/MONO, R/MONO) jacks: 1/4-inch phone type (unbalance)
INPUT 5/6 jack: Stereo miniature phone type
AUX RETURN (L, R) jacks: RCA phono type
AUX SEND (L, R) jacks: RCA phono type
USB FUNCTION Port: USB type B (Audio, Midi)
USB HOST 1–4 ports: USB type A (Audio, Midi, for only TB-3/VT-3/TR-8/SYSTEM-1)
USB HOST 3 port can supply USB Bus power
COAXIAL IN/OUT jack
MIDI (IN, OUT) connectors
DC IN jackInterfaceHi-Speed USB
Digital input, output: Coaxial type (conforms to IEC60958)
MIDI IN/OUTPower SupplyAC adaptorCurrent Draw1.7 A
AccessoriesOwner's manual
Leaflet "USING THE UNIT SAFELY"
AC adaptor
Ableton Live Lite Serial Number Card
SIZE AND WEIGHTWidth400 mm
15-3/4 inchesDepth264 mm
10-7/16 inchesHeight65 mm
2-9/16 inchesWeight1.81 kg
3 lbs. 16 oz.
Re: AIRA MX
Ich sag mal "analog" der TR8 = 500€
Vor allem, das ist schon offiziell auf der Homepage, gehts als auch direkt los... AIRA = der Rozz der Zukunft
Re: AIRA MX
Wow, das ergibt natürlich ungeahnte, neue Möglichkeiten mit den Airas, das muss ich erstmal sacken lassen...
Re: AIRA MX
bin mir noch garnicht so sicher wofür man das braucht
Re: AIRA MX
4 mal USB SPDIF out coaxial
  SPDIF out coaxial
ich mag ja dieses Alien Grün
Re: AIRA MX
18-Kanal-Performance-Mixer mit step-basierten FX, Transport- und Tempokontrolle
Drei verschiedene Arten von step-basierten Beat FX (Filter, Side Chain, Slicer) mit Tastern im TR-Stil
Sechs verschiedene Master FX (48 Variationen) mit großem Performance Control-Regler
Beat FX und Master FX können einzelnen oder allen Inputs zugewiesen werden. Beat FX steht pro Kanal zur Verfügung.
Mithilfe der Combination-Funktion kann zu jedem einzelnen Step ein anderer MASTER FX-Typ zuordnet werden
Vier AIRA-Link-USB-Ports für Audio, MIDI, Sync und Bus Power (Port 3) zum Anschluss von AIRA-Instrumenten
Mix-Modus mit sechs analogen, einem digitalen (Stereo), vier AIRA- (Stereo) und zwei PC-Kanälen für Mixer und FX
Im External-Modus können 18 Audio-Ausgänge einer DAW zum Mixer geroutet und mit FX versehen werden.
Control-Surface-Modus für volle DAW-Kontrolle via MIDI
Cue Monitoring im DJ-Style, Quick Mutes und sechs Fader-Kurven pro Kanal
Ton-/Filter-Regler pro Kanal mit zehn verschiedenen EQ-Charakteristiken, Filtern und Isolatoren
Transport- und Tempokontrolle mit Feineinstellung-, Shuffle- und Tap-Tempofunktionen
Schnelles Speichern und Abrufen von kompletten Setups inklusive sämtlicher FX-Konfigurationen
SIDE CHAIN: 5 types
FILTER: 8 types
SCATTER: 8 types
FLANGER: 8 types
BIT CRUSH: 8 types
Input: 18 channels
COAXIAL IN/OUT jack
AC adaptor
3 lbs. 16 oz.
Re: AIRA MX
klangsulfat schrieb:Was für eine brilliante Produktidee ... dass da vorher noch niemand drauf gekommen ist. Aira wird als Gesamtpaket immer leckerer. Bin mal auf den Preis gespannt.
Re: AIRA MX
Re: AIRA MX
Trooper schrieb:Wow, das ergibt natürlich ungeahnte, neue Möglichkeiten mit den Airas, das muss ich erstmal sacken lassen...
Wo bleibt der Däne mit Demo ?
Re: AIRA MX
01233456 schrieb:Rückansicht.
[ https://www.sequencer.de/synthesizer/download/file.php?id=13572&t=1 (•BILDLINK) ]
4 mal USB
 SPDIF out coaxial
  SPDIF out coaxial
Re: AIRA MX
 (oder auch Vollmixer, wenn die 6 zusätzlichen Kanäle reichen).
		 wer hatte denn die Idee = grandios
  , vielleicht in 10 oder 15 Jahren...
 ... Aber den System 1 oder die TR-8 verfkaufen die mir trotzdem nicht ^^...
