Tempera - Granularsynth
  • #151
Andre​
Hello all!We are go for Tempera firmware v2.3-rc1 with a bunch of improvements, bug fixes and polishings
Big thanks to everyone who participated, reported bugs and brainstormed
  • Fixed modulator modulating another modulator's size
  • Fixed crash when viewing
    :Tracks:
    waveform after being on the last page of
    :Emitters:
    parameters
  • Fixed Note index modulator is now quantized to notes and hidden decimal numbers are discarded
  • Polish dangerous actions of loading or merging a canvas, or batch-loading samples from a folder are now protected by the need to hold the button for a bit
  • Polish the defaultly selected element in Sync time is now the time signature
  • Polish Sync time is now greyed out again when Grain trigger is 0.0
  • Polish most action UI buttons now flash briefly to give a confirmation that they did a thing. Seems more civilized to me but let me know if it's obnoxious.
  • New function Grain skip probability works the same was as Grain reverse probability and these two share a UI slot
  • New function Internal SD Card / Flashdrive formatter which will format the medium with a compatible ExFAT and MBR partition. This is usually not necessary but might help.
  • New per-emitter function Grain pitch. It goes smoothly from -12 to +12semitones and integrates the Octave switching. Grain pitch is also a modulation target. Behind the scenes it hitches a ride on pitchbend which was already per-voice
  • New function to Nudge cell markers in
    :Tracks:
    -> Edit -> Trim . Select the marker and then turn the 2nd encoder to adjust. This allows to have uneven cell lengths if your audio material requires it
Bytes are ready for download here: https://fw.beetlecrab.audio/tempera/tempera-2.3-rc1.firmware , update procedure same as before.Please give it a go and report any new or lingering bugs or oddities.
M.i.a.u.: Danic und mr.slow
  • #152
Andre​
Hello everyone New Tempera firmware v2.3-rc4 is built and ready
  • Fix a timing miscalculation which resulted in super short grains not out producing a correct grain train
  • New function inside -> Edit-> Trim: Round + Fit the waveform to zoom the start-end portion neatly across all 4 displays. When Start and End knobs are turned, the Zoom* readjusts accordingly. Big thanks to everyone who provided ideas on this. Looks fab!
  • New function by slightly extending the current Grain shape parameter: **Shape tilt`, which allows the grains have the shape of anything between a pluck, a symmetric window, or a swell-up. This is accompanied by a nice visualization on the display. I'm not super stoked about the symmetric operation (do i turn left or right to have more curvy shape?) but let's try and see.
Get it here: https://fw.beetlecrab.audio/tempera/tempera-2.3-rc4.firmwareUpdate procedure same as before:
  • Place the firmware file onto an SD card or USB flash drive
  • With the storage medium plugged in, turn Tempera on while holding the round button until the orange splash
  • Follow instructions on the displays
  • #153
Is it possible to rotate the MIDI note assignment? I couldn’t find anything about that…
  • #159
Gern geschehen (der Link ist auf der Tempera-Seite bei Beetlecrab ganz unten)! ;-)
M.i.a.u.: MC242
