Prophet VS Waves
orgo
Hat jemand die single cycle Waves aus dem Prophet VS als Wave oder Aif Dateien?
Es gibt dazu zwar einen Link: https://www.dropbox.com/sh/ja0tc8wn6cnu ... 6MhOa?dl=0
diese Waves stimmen aber zumindest in der Ordnung nicht mit dem überein wie es im Original beschrieben ist. Dort beginnt die Auswahl laut Manual mit: 32/sine/ 33/saw 34/square ... und endet mit 127/noise.
http://www.synthmanuals.com/manuals/seq ... manual.pdf
Edit: Im Evolver sind ja auch die VS Waves. Könnte mir jemand die Waves Exportieren?
Path: rz.uni-hildesheim.de!zib-berlin.de!news.th-darmstadt.de!terra.wiwi.uni-frankfurt.de!zeus.rbi.informatik.uni-frankfurt.de!news.dfn.de!swiss.ans.net!howland.reston.ans.net!spool.mu.edu!olivea!sgigate.sgi.com!gazette.engr.sgi.com!prophet.esd.sgi.com!gints
Newsgroups: comp.music,vectory@netcom.com
Subject: available: Prophet VS wave data
Date: 4 Jan 1995 23:52:53 GMT
Organization: Silicon Graphics, Inc.
Lines: 35
Distribution: world
Message-ID: <3efccl$drn@gazette.engr.sgi.com>
NNTP-Posting-Host: prophet.esd.sgi.com
Many years ago, I dumped all Prophet VS waves (128 samples/cycle, 12-bit
resolution) over MIDI to my Atari ST. email me if you want them.
Prophet VS Wave data - 128 waves
32768 bytes = 128 cycles * 128 samples/cycle * 2 bytes/sample
16-bit signed integer
Waves 0 .. 31 RAM memory and are actually of no value.
Waves 32 ..127 ROM memory are standard wave set.
Notable ROM waves:
32 cosine
33 sawtooth
34 square
46 thin pulse 1
47 thin pulse 2
126 silence
127 bogus entry, as this specifies Prophet VS noise generator
Remember that single cycles themselves are not particularly
interesting. Stacking, detuning and timbral animation via vector
envlopes make the VS.
For convenience, I have left shifted the 12-bit data by 4 places to
align on a 16-bit boundary. In other words, the 16-bit samples offer
no more information than the original 12-bit samples. Soon, I will
create 32-bit floating point wave cycles with more samples/cycle and
publish tables of harmonic amplitude and phases for each wave.
Enjoy,
Gints Klimanis
Danke!
In dem ZIP versteckt sich eine .dat Datei. Kannst Du mir sagen wie sich daraus die Waves extrahieren lassen?
Danke Swissdoch und Cyclotron.
Ich hatte die Hoffnung gehabt alle Single Cycle Waves einzeln zu bekommen. Das was ihr geschickt habt ist, soweit ich es verstehe ein Wavetable aller VS Waves, richtig?
Ich wollte die Waves in meinen ASR 10 laden. Mit einem Wavetable kann der ja umgehen, nur ist die Frage wie ich die Waves einzeln "anfahre"...
Die Datei von Cyclotron kann nicht korrekt sein, da sie genau gleich gross ist und somit der WAV Header fehlt. Anbei eine korrigierte Version. Einfach in Stücke zu 128 Samples Länge zerteilen und Spass haben.
Keine Ahnung, was da los ist. Ich habe die Datei mit neuem Header gespeichert und konnte sie auch in Winamp abspielen. Wenn ich das Ding jetzt runterlade, ist der Header weg.
