Studiologic Sledge Synthesizer – Blofeld with Knobs! by Studiologic + Waldorf
Studiologic Sledge Synthesizer. a knobbed Blofeld Digital Synthesizer – that’s what it is:
Gelber Sledge Sledge yellow version (1st edition) synthesizerStudiologic Sledge synthesizer
the Sledge Synthesizer – more info.
OSC Features wavetable fm sync ring filter fm samples
Wave Shapes digital pulse saw sine triangle noise coloured sample
3 OSCs + 2 SubOSCs info © sequencer.de
2 Filter lpf hpf bpf notch comb 2-4 Pole
3 LFOs sine triangle pulse saw s+h
4 Envelope Generators ADSR on panel – 2 direct access.
__
basically just comb filter tweaked in here / nothing special:
Namm2012 StudioLogic Sladge by Rock oN Report
some knobs – just „view“ on the NAMM-kind of video..
NAMM 2012 Studiologic Sledge Polyphonic synth powered by Waldorf
googlish (italian in original) – the Specs:
• 32 • 3 potentiometers rotary switches „chicken head“ (7 positions) • 1 rotary encoder with button function • Backlit LCD screen with 2 x 16 characters • Pitch and Mod Wheel • Up to 256 high quality sounds • Selecting sounds fast and effective on the numeric keypad • 2 fast LFOs per voice, each with Speed and Depth controls • 1 extra modulation routing for the Mod Wheel, with selectable speed and depth – Waveforms: sawtooth, square, triangle, sine , sample & hold, ramp – Destinations: Osc 1, Osc2, OCS3, PWM / Wave / FM, volume, filter cutoff • mono mode with single or multiple trigger • 3 oscillators per voice – range from 64 ‚to 1‘ for each – Waveforms: sawtooth, square, triangle, sine, pulse (with Pulse Width Modulation) – wavetable oscillator 1 with 66 of the original PPG • Frequency Modulation for sine wave and triangular Hardsync • Oscillator (Osc 2 in Osc 3) • Noise generator with selectable white noise or pink noise • Mixer with Volume and on / off switch for each oscillator and the noise generator • 1 Multi Mode Filter for each voice – 24 / 12dB – Low Pass – High Pass – Band Pass – Resonance up to self-oscillation and reaches beyond – Keytrack editable and Drive • 2 envelopes fast for each item (filter / amplifier) • Powerful Arpeggiator – Latch mode – Synchronize the Word Clock – Directions: Up , Down, Alternate – Range up to 10 octaves • 2 effects available simultaneously: – Effect 1: Chorus / Phaser / Flanger – 2 Effect: Reverb / Delay Chasse • rugged and lightweight (less than 10 kg) • Keyboard Fatar TP9 to 5 octaves high quality • Master Volume Control
• Power switch • Line Output • Stereo headphone output • Input for expression pedal • MIDI input and output • USB connection for MIDI in / out – use the standard USB MIDI driver provided by the operating system Computer – Windows Requirements: Windows ME, Windows XP or later – Mac Requirements: Mac OS X 10.2, Mac OS X 10.3 or later • Integrated power supply
as said – this looks like a repackaging of the Blofeld and that’s not bad since it has knobs – and it’s most likely it will do the same things incl. samples and manipulating wavetables via that special editor. hope so.
hmm, chicken head switches? – anyway – it’s a what it is.
home_news_studiologic_sledge2
Forum: Studiologic Sledge & viewtopic.php?f=47&t=64156&start=175#p671661
at the booth..
NAMM 2012 Studiologic Sledge polyphonic synthesizer interview
Related posts
One Thought to “Studiologic Sledge Synthesizer – Blofeld with Knobs! by Studiologic + Waldorf”
  1. […] – new 2 Casios – now with some more details PDF – Repackaged Blofeld with Knobs Studiologic Sledge (not on NAMM) just scroll down… – because that isn’t […]
Comments are closed.
