Torso S-4 Sculpting Sampler
Cool, danke ! Bin echt mal gespannt.
Finde ja die Torso-Leute und ihren T1 Sequencer sehr sympathisch und innovativ und freue mich, dass sie jetzt ein zweites Gerät rausbringen, wahrscheinlich auch wieder mit einem eigenen Ansatz.
Leider ist der Link oben nicht mehr aktiv.
Aber im Elektron-Forum haben sie auch noch ein paar Infos rüberkopiert aus der Seite.
M.i.a.u.: Muggaseggl
Liest sich teuer.
Ich schätze mal so um die 1300€.
€ 799,00 :xenwink:
The S-4 is a sculpting sampler designed to capture and transform sounds. Merging tape-era workflows with cutting-edge technology, the S-4 redefines sound mangling by providing a futuristic platform for crafting unique soundscapes and compositions, using samples and real-time audio processing.
S-4 is a tool made for sonic explorers. It has four parallel stereo tracks, each with an audio engine featuring a chain of audio devices including samplers, live granular processing, morphing resonators, and a range of audio effects. A novel modulation system allows anything and everything to be modulated with 20 modulators per track. Capture sounds on the fly with the onboard microphone and stereo line input, or load samples from the four gigabyte internal flash storage.
Use cases​
The S-4 is a versatile powerhouse, capable of serving as an effects processor, transformative sound designer, tape machine, live looper, classic sample player, or textural synthesizer.
tape machine​
Capture your surroundings. Use S-4 as a transformative four-track tape machine.
effect processor​
Manipulate live audio, and add color and textures to your beats, melodies, and sounds
midi controlled sampler​
Hook up a MIDI keyboard or sequencer and use S-4 as a powerful textural synthesizer and sample player.
Audio engine​
Push the creative boundaries and transform audio into uncharted depths. S-4 has four parallel stereo tracks, each of which contains a chain of five audio devices tailored to cover specific sonic areas and applications. Create everything from glittering textures to broken soundscapes or evolving synth sounds. Together, the devices form a playful toolbox for sculpting sample material and live audio.
grafik
grafik1135×597 39.9 KB
Animate and bring life to any parameter using the rich and unique modulation system. Each audio device has four configurable modulators that can be mapped to any parameter with unlimited mapping destinations. It is even possible to do cross-modulation between modulators. In total S-4 has 20 modulators per track. Choose between a range of different modulators from complex LFOs, and generative sequencers to envelopes.
Performance in action​
At its core, the S-4 revolves around four action buttons that provide instantaneous and dynamic control. The behavior of the action buttons transforms with the flow of the interface, ensuring that you always have the control you need. Each audio device has a dedicated set of action buttons for controlling specific elements, such as triggering audio recording or freezing the granular processor’s buffer. The action buttons also provide quick access to essential functions like muting and selecting tracks, enhancing workflow efficiency.
Capture your surroundings​
Utilize the built-in microphone to record sounds, sample and loop your external gear with the stereo line input, resample the internal tracks, or effortlessly load samples from the S-4’s flash memory or an external drive.
grafik
grafik1163×413 41.3 KB
The S-4 is designed with durable RGB buttons offering tactile feedback and a high-quality 3.5-inch LCD display ensuring all the visual feedback you need. It features USB connectivity for seamless connection to class-compliant devices and effortless file transfers to and from your laptop. Moreover, it can function as an audio interface when you require a simplified setup. You can also expand the number of inputs and outputs by connecting a class-compliant external USB interface.
grafik
grafik1158×838 36.5 KB
Audio engine features​
4 parallel stereo audio tracks
Tape player with live looping capabilities
Polyphonic sample player
Live granular processing with time-warping and pitch-shifting algorithms
Morphing resonator (48-band filter bank)
Bit crushing, drive, and compression
Combined reverb and delay with pitch-shifting and shimmer
Modulation features​
4 modulators per device (20 per track)
Modulate any parameter of the audio engine
Modulator types:
– Complex LFOs
– Generative sequencing tools
– Envelopes
Hardware​
Quad-core 1.5 GHz processor
4 GB flash memory (sample pool)
24-bit / 48 kHz stereo audio in and out
I/O​
2 line-inputs
2 line-outputs
Built-in microphone
Stereo headphone output
MIDI in/out
Analog sync in/out
USB-C
Miscellaneous​
WiFi – Ableton Link
Class-compliant USB audio interface
Expandable number of inputs/outputs with class-compliant USB interfaces
User Interface​
High-resolution LCD color display, 3.5 inch
21 tactile RGB buttons
9 high-quality endless encoders
Physical​
Matte black aluminum casing
Dimensions: 242 x 156 x 39 mm (9.5” x 6.1” x 1.5”)
Weight: 820g (1.8 lbs)
grafik
grafik1189×239 17.2 KB
M.i.a.u.: robworld und oli
Wunsch oder Wirklichkeit? Oder Kickstarter Preis?
Auf jeden Fall ein interessantes Gerät! Ne Mischung aus Make Noise Morphagene, Tasty Chips GR1, TE OP1 und ihrem eigenen T-1 im Design vom Polyend Tracker. Ich hör schon brutale Amen Breaks, gemixt mit sanften Flächen und fiesen Bass Drops....muaaaharhar!
M.i.a.u.: Discordia
Nu isses offiziell. 899 EUR. Ab März 2024 soll ausgeliefert werden.
M.i.a.u.: Artur Ria und SirAdrianFish
Für die "Early-Supporters" gibt es einen Rabattcode in Höhe von 10%, d.h. der Torso S-4 liegt dann preislich, einschließlich Steuern und Versand, bei € 809,00. Die Early-Supporters-Aktion läuft bis einschließlich 30. November 2023.
Auslieferung des ersten Gerätesbatch(es) soll dann im März 2024 sein.
Inzwischen wurde, neben verschiedenen Teaser-Clips auch ein wenig aussagekräfitges Video gepostet:
Also für alle "Early Supporters - "No risk, no fun... :xencool: "
M.i.a.u.: Klangzaun und Artur Ria
ich seh nichts aussagekräftiges an dem Video. wo muss ich suchen ?
zu "Granular" und was das bei denen bedeutet seh ich auch keine konkreten infos auf deren Seite.
Das ganze steht und fällt dann in den Details.
auch bzgl. -> ob es ne Konkurrenz für ein softwarebasiertes setup sein könnte oder nicht ?
Wer ehh HW will, für den erübrigt sich die Frage natürlich ;)
Für "ohne infos" 900.- hinlegen ?
Danke, ciao, nein....tschüss !
M.i.a.u.: Klangzaun und Xenox.AFL
S-4 top
Das Design ist absolut überragend.
Hoffentlich ist dies die finale Version - und nicht die im Eingangspost.
M.i.a.u.: robworld, Tyskiesstiefvater, kernelkid und eine weitere Person
Ja.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Nützt nix.
GAS.
M.i.a.u.: banalytic und monoklinke
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Ich brauche nix.
Nützt nix.
GAS.
Bin ich bei Dir.
Habe keinen Sampler, wollte nie einen und kann auch keinen gebrauchen.
Aber die Kiste ist so unverschämt sexy.
Bin sehr gespannt auf erste Demos.
Allerdings... wenn die Kiste dann bunt leuchten sollte, ist die Errektion dahin.
M.i.a.u.: kernelkid
M.i.a.u.: Lauflicht, banalytic, oli und eine weitere Person
Gibt es schon Infos, ob der S4 Sampler besonders gut mit dem T1 Sequencer genutzt werden kann? Also ich meine nicht nur via MIDI/CV Befehlen, sondern mittels einer tieferen Integration, falls das prinzipiell überhaupt möglich sein sollte?
Finde ich hochspannend. Hat keinen Sequenzer. 100 Prozent Sounddesign. Also T1 als natürlicher bedfellow. Mit dem T1 und dem S4 werden sich schöne Gigs spielen lassen.
Minimalistisches Setup. Passt in den Rucksack.
Und was mach ich jetzt mit dem GR-1?
M.i.a.u.: SirAdrianFish
ja das er kein sequenzer hat ist blöd.
aber sieht spannend aus.
Mit morphenden Resonatoren (48 band Filterbank) sowas wie ein Morpheus 2024. Mit eingebautem Mikro direkt sampeln. Gut! Leider kein Batteriebetrieb.
Bin gespannt auf die Kiste und die ersten Demos.
Eigentlich unterstütze ich ja gern und viel solche Projekte von kleinen Läden weil die oft sehr gute Sachen machen wo bei großen Firmen oft viele Kompromisse eingegangen werden, aber hier sieht man noch zu wenig um die Pre-Order button zu clicken...
Optisch super, von den Möglichkeiten liest sich das auch alles sehr gut, aber ich will auch was hören und da ist es mir noch zu wenig, da müssen sie noch eine Schippe drauflegen weil nur alleine von der Optik her, kauf ich natürlich kein Gerät, möchte schon hören was damit möglich ist....
Frank
M.i.a.u.: Discordia, banalytic, oli und eine weitere Person
Der S-4 ist mit seinen 4 Spuren wohl vierfach multitimbral. Damit verhält er sich wie der GR-1.
Das ist nicht viel, aber wenn man ausgiebig modulieren kann, reichts.
