Elektron Digitakt II 1.15B
  • #962
1.10A ist draußen (Bugfixes):
  • Kits did not save correctly.
  • Using [FUNC] + [YES] to select a sample for an already populated sample slot jumped to the directory of the previously selected sample rather than the directory of the selected sample.
  • The LEN parameter on the SRC page was not updated on the device after it was first edited using the Overbridge plugin.
  • The Machine selection indication on the device was not updated after changing machine using the Overbridge plugin.
  • In some rare cases, the NOTE parameter setting on the TRIG page could be ignored after updating to OS 1.10.
  • The SRR ROUT parameter’s label did not show the correct name.
  • Previewing a trig with retrig added could sometimes make the sound play indefinitely
  • When loading a preset that previously has been transferred to the device using Transfer, sometimes an incorrect sample could be loaded with the preset.
  • Sample Select NRPN did not switch the sample slots correctly.
  • In rare cases, a sample already present on the device, could erroneously be added again to the device when transferring a project using Transfer.
  • Loading preset from Overbridge plugin didn’t override MIDI machine on device
  • Sometimes a preset’s name was lost after it was added to preset pool if the preset name contained lower case characters.
  • Adding parameter locks to all active trigs on a MIDI track did not work.
  • The SLEW parameter was missing in the modulation destination list.
  • SONG mode mutes were not swapped when performing a track swap.
  • The parameters on the SRC page were missing on the device after selecting a MIDI machine using Overbridge.
  • Removing send effects from main outputs, also removed them from their individual outputs.
  • Removing parameter locks on active MIDI trigs while holding [TRK] did not work.
M.i.a.u.: Soundwise unlike, finderzh, stuartm und 2 andere
  • #963
bin dann mal aufs "grosse" Update gespannt....ob man da ne neue Sample Engine erwarten kann?
  • #964
ich glaube irgendwie nicht. sowas wie modernes timestretching wird zuviel CPU power brauchen. Vor allem erwarten die Leute ja das das dann bitte auch auf allen 16 Stereospuren geht ;-)
ein Soundeditor mit dem man später noch vernündftig reinzoomen kann und samples bearbeiten , wäre aber was.
M.i.a.u.: tonstoff
  • #965
Jetzt bin ich auch Besitzer eine Digitakt 2, lange habe ich gewartet…
Und gleich eine Frage: Wackeln die Potis bei eurem DT2 auch so?
Insbesondere das Volume und Data Poti haben so viel Spiel, dass ich das eig einem Gerät dieser Preisklasse nicht durchgehen lassen möchte.
  • #966
Wir wissen ja nicht wie deine wackeln.
Die haben etwas mehr Spiel.
Das kannst du nur dir selbst beantworten.
Mein persönlicher Rat wäre:
Unter der Annahem das du kein fehlerhaftes Gerät hast: in der Regel sind elektron Geräte gut und stabil verarbeitet. Benutz ihn doch ne Weile und guck mal ob es dich stört. Mir ist das wackeln erst aufgefallen als mich mal jemand danach gefragt hat. Beim normalen benutzen spielt es keine Rolle - beim DT1 waren die nach zig Jahren immer noch stabil und zuverlässig.
  • #967
Das ist wohl wahr.
Sagen wir mal so, die Dinger haben so viel Spiel, dass es mir gleich aufgefallen ist.
Das ist schon mal ein guter Hinweis, vielen Dank!
  • #968
die Leute sind so unterschiedlich was das angeht. Wie gesagt, ja die Teile haben etwas mehr Spiel aber das sie jemandem abgebrochen, gefallen oder nach kurzer Zeit ausgenudelt wären hab ich zumindest noch nie gehört.
  • #975
Hallo liebe Gemeinde und erfahrene Digitakt User,
Nach längerer Pause bin ich wieder am Musik produzieren. Ich habe starkes Interesse, mir den Digitakt 2 zu kaufen. Habe mich gestern zu dem Gerät belesen, stehe jedoch mit paar offenen Fragen da in Bezug auf overbridge. Habe verstanden, dass man die Effekte beim Rekorden in ableton auf eine Spur zuweisen kann, jedoch wie sieht es mit dem Kompressor aus? Das komprimierte Signal scheint über overbridge ja nicht verfügbar zu sein!? Oder hab ich das falsch verstanden? Kann man nach der Aufnahme in ableton den Kompressor als vst einbinden und als Plug-in auf den Master Bus setzen? Mir gefällt der Kompressor sehr gut! Ich will so vieles wie möglich am digitakt produzieren und im Nachhinein nicht ewig den Sound des Kompressors in ableton replizieren wollen! Hoffe, ihr versteht, was ich damit meine! Wäre dankbar für euere Unterstützung. Beste Grüße
  • #976
Ich bin der Meinung, man kann den Kompressor mit abgreifen, wenn man den Master als Input nimmt.
  • #977
Erst mal Danke für deine Antwort!
Also du meinst den Master out vom Digitakt? (Klinke) oder in overbridge? Weil ich will ja eigentlich schon die Einzelnen Kanäle in overbridge nutzen zum Aufnehmen! Geht über den Master dann nicht alles raus? Also auch der Reverb etc. und die gesamte Summe? 🧐
  • #978
Ich meinte schon Overbridge Summensignal, warte ich schau mal in den Signal Flow.
  • #979
Hier die Signalkette und grün ist, wo Ad und DA sitzt.
M.i.a.u.: frixion
  • #980
Das wäre aber der gesammte Summensignal! Verstehe..
Kann man den Kompressor allein über Overbridge als VST nutzen? Zum Beispiel am Master von Ableton?
  • #981
Du könntest den Input nutzen und den dann über den Master wieder ausgeben… Weiß aber nicht wie praktikabel das ist. Ableton hat ja selbst schon Verzerrer und Kompressor .. Ich nutze Overbridge leider nicht aktiv, aber spiele mit dem Gedanken..
  • #982
Danke dir Plasmatron! Da ich kaum noch Hardware habe will ich das Gerät voll ausnutzen! :) Und weg vom Bildschirm soweit es geht! Bin echt angetan vom Digi.. Overbridge ist fein wenn es denn funktioniert.. früher war das ja eher schlecht als recht..! Mit was für weiterer Hardware nutzt du Ihn? Hätte gerne wieder ein kleines Setup um dawless die Bude zu rocken 🎧😅
  • #983
Ich nehme den wirklich als Sampler , was er ist aber auch als Midi Machine für externe Klangerzeuger. Den Rechner nehme ich nur als Mischpult+ Mastering.
Der ist als MIDI Sequenzer das beste Teil überhaupt.
Also ich kann dir das Teil nur empfehlen.. Overbridge nutze ich nicht aktuell, was aber mehr an meinem Chaos liegt und ich bekomme den Grundmix schon ordentlich aus der Kiste. Also ich bastel am Grundgerüst, auch mal Athmos oder Effekte, das das Pattern auch Standalone funktioniert, kopiere dann aber das Pattern weiter und nehme Sounds dazu oder eben Midi Machines, in meinem Fall den Cascadia oder den Töröö und den GR Mega ( den wollte ich ersetzen durchn IPad, aber das Teil bleibt doch ..)
  • #984
Ich hatte eine Zeitlang 2 Elektrons, weil ich die MidiMachines vom Digitone 2 genutzt hatte. Aber irgendwann kam es mir, anstatt innerhalb eines Pattern zu Muten, einfach zum nächsten schalten. 16 Spuren sind eigentlich immer genug- gleichzeitig. Ein zweiter Digitakt 2 juckt immer noch in den Fingern, Aber ich zwinge mich zum Umdenken..
  • #985
theoretisch sollte es gehen.. aber hinbekommen hab ich's nicht. (audio in Sidechain 1/2 geroutet und sidechain 1/2 in den Master LR... blieb leider stumm)
Da es kein FX plugin ist kannst du es leider nicht direkt als compressor plugin auf m Master nehmen.
M.i.a.u.: Plasmatron
  • #986
Vielen lieben Dank euch beiden! Hat mir sehr geholfen! @Plasmatron der Tööröö scheint mir eine interessante Maschine zu sein.. :)
  • #987
Ja eine gute Ergänzung für das kleine Set. Ist ja alles auch relativ und vom Musikstil abhängig. Aber was mir wichtig ist, er ( der kleine Töörö) klingt lebendig und auch selbstständig.. So für Pads und Acid nehme ich den gerne.
Du kannst im Digitakt ja auch super Synths bauen. Die Filter geben das her. Manchmal wünscht man sich dann aber doch mal einen anderen Geschmack , oder mal was Polyphones..
  • #988
Überlege gerade auch wieder einen digitakt zu holen… Das was mich immer gestört hat, ist das fehlende slicing. Bei nun aber insgesamt 16 Tracks bekommt man das aber auch hin…
Eine Frage: Editieren von langen samples… Ist der Umweg über resampling und dann Editor praktikabel? Oder nervt es einfach nur?
  • #989
Digitakt 1 hatte doch slicing.....wenn auch keine verschiebbaren slices
Den umweg übers resampling beim 1er muss man mögen...schätze das ist ähnlich beim 2er?
  • Hmm
M.i.a.u.: frixion
  • #990
Als Workaround:Du kannst sowieso durch die Parameterloks zb ein Drumsample Slicen, da du ja bei jedem Takt den Start und Endpunkt des Samples definieren kannst. Dann musst du nur noch den jeweiligen Takt kopieren. Also als Workaround.
Es gibt einen Algo, der Teilt Rythmisch auf, aber der macht nicht das, was man unter AutoSlicing versteht.
