Raspberry Pi5 Warning! All Pi guides are obsolete! No Midi Uart!
R
Rappel
Hello. I want to warn every potential raspberry Pi5 buyer, to think it twice.
Becuase it introduced the rp1 monitor chip, changed Pins allocation, 99% of old libs do not work anymore.
The most famous DIY Synth using raspberry Computer module Pi5 at its core, is having lots of problems adapting
broken libs to make DIN MIDI work, and to many DIY Zynthians users, that don't have the full Zynthian V5 package,
things don't go well.
I recently bought a Slim Midi Hat just to get Midi In OUT. My previous 6N138 simple Octocoupler circuit didn't work
so I bought the Hat thinking it might solve my problems, but only PiSound HAT, that passes MIDI through an ARM chip with SPI
protocol seems to work for non full Zynthian users. All others don't have DIN MIDI WORKING.
On Bookworm it's even worst. Every lib has to be rewritten, most libs simply has been written to work for all Pi untill vers 4B.
No guide has been updated to say instructions won't work on PI5, so even basic google search will give you results for older Pi, not Pi5.
And none works. The most important part, GPIO lib, WiringPi, lgpio, GPIOZERO and others, still works on PI ZERO, PI3, 4... but not
one specify they will not work on Pi5.
Be careful if you wish to build anything with a Pi5 as your base module.
Hallo. Ich möchte jeden potentiellen Raspberry Pi5 Käufer warnen, es zweimal zu denken.
Weil es die rp1 Monitor-Chip eingeführt, geändert Pins Zuordnung, 99% der alten Libs nicht mehr funktionieren.
Der berühmteste DIY-Synthesizer, dessen Herzstück das Himbeer-Computer-Modul Pi5 ist, hat viele Probleme mit der Anpassung von
kaputten Bibliotheken, um DIN-MIDI zum Laufen zu bringen, und für viele DIY-Zynthian-Benutzer, die nicht das vollständige Zynthian-V5-Paket haben,
läuft es nicht gut.
Ich habe kürzlich einen Slim Midi Hat gekauft, nur um Midi In OUT zu bekommen. Mein vorheriger einfacher 6N138-Octocoupler-Schaltkreis funktionierte nicht
, also kaufte ich den Hat in der Hoffnung, dass er meine Probleme lösen würde, aber nur der PiSound HAT, der MIDI durch einen ARM-Chip mit SPI
-Protokoll weiterleitet, scheint für Nicht-Zynthian-Vollnutzer zu funktionieren. Alle anderen haben kein funktionierendes DIN MIDI.
Auf Bookworm ist es sogar noch schlimmer. Jede Lib muss neu geschrieben werden, die meisten Libs wurden einfach so geschrieben, dass sie für alle Pi bis zur Version 4B funktionieren.
Keine Anleitung wurde aktualisiert, um zu sagen, dass Anleitungen nicht auf dem PI5 funktionieren, so dass selbst eine einfache Google-Suche Ergebnisse für ältere Pi liefert, nicht für den Pi5.
Und keine funktioniert. Der wichtigste Teil, GPIO lib, WiringPi, lgpio, GPIOZERO und andere, funktioniert immer noch auf PI ZERO, PI3, 4... aber nicht
man gibt an, dass sie nicht auf Pi5 funktionieren.
Seien Sie vorsichtig, wenn Sie etwas mit einem Pi5 als Basismodul bauen wollen.
Übersetzt mit DeepL.com (kostenlose Version)
Ist das hier kein deutschsprachiges Forum mehr?
Der Kollege @Rappel ist ziemlich engagiert im Jeannie-Entwicklungs-Thread. Da er Italiener ist, schreibt er meist in Englisch und manchmal auch in echt ordentlichem Deutsch (ich wünschte ich könnte Italienisch genauso gut wie er Deutsch).
Ich schreib auch manchmal in italienischen oder französischen Foren. Die einfachen Texte schreib ich zwar in der jeweiligen Landesprache, aber wenn es inhaltlich zu komplex wird, weiche ich dann schon auch mal auf Englisch aus..
Es gibt ja sogar schon Foren mit automatischer Übersetzung = Sprache egal in der man seine postings schreibt.
Dank KI wird die Qualität der Übersetzung auch immer besser .
It was the excitement of his article that bothered me, not the language in which he wrote it.
But back to the topic:
It is actually known that the assignment of the GPIO connection has changed. There is a new “high speed” port. Therefore, 8 channel audio is now possible, for example.
I am trying to adapt a PCB for the Raspi 4 to a Raspi 5. Then I will know exactly what has changed.
