1010 Bitbox
siebenachtel
siebenachtel
Für die bitbox MK2 gibt es eine neue Firmware, damit zieht die bitbox MK2 mit der blackbox gleich.
Bitbox MK2 version 2.1.0
Today, 01:58 AM
Bitbox MK2 Version 2.1.0 is a version that includes all the latest updates and bug fixes:
  • LFO per voice with the option for beat sync. This applies to sample, clip, granular, and slicer modes
  • Modulation of the envelope Attack, Decay, and Release, including control via MIDI CC
  • Resonance control on the filter, including the ability to modulate it
  • Enhanced Delay algorithm with integrated band-pass filter and the ability to play just a single echo
  • More advanced granular controls, including density, scatter, and pan spread
  • MIDI based recording of cells. Be sure to switch MIDI Rec to ON in the TOOLS/Rec page. Here is the layout for notes received on the MIDI Pads channel(s) :
    • Notes 68-75: Record pads 1-8. The pad needs to be empty in order for recording to happen.
    • Notes 84-91: Clear pads 1-8
    • Note 100: Select the previous pad
    • Note 101: Select the next pad
    • Note 102: Play the currently selected pad
    • Note 103: Record the currently selected pad assuming it is empty
    • Note 104: Clear the currently selected pad
  • New SD Mode to enable the hardware to work with more micro SD cards
  • New, more convenient layouts with onscreen knobs and fewer screens
Was sind denn die Unterschiede zwischen Mk. 1 und Mk. 2 der Bitbox?
