drdel
hier für alle eine Nachricht von Scott zur Kenntnis, auf meine Nachfrage zum Funktionieren des Gate Controlled Mute am Division-6 SQ816 Mattson Sequenzer:
If you look on the back of the sequencer's expansion board, there's a white 2-pin connector labeled "CNXD12". That's basically there to do fun extra stuff with. With the current firmware version, that's the Gate Controlled Mute input. If you connect a gate voltage to that input, it will mute the sequence stages until you release the gate again.
The easiest way to connect the feature up and use it is to unhook one of the wired jacks on the sequencer that you aren't using, (Gate X In is a good one, but Var X In, Var Out or even Footswitch would work) and connect it to CNXD12. Then the jack you rewired would be the Gate Controlled Mute jack. The white connectors pull right off of the pins, so it's fairly easy to switch back and forth.
What you do with this feature is up to your imagination, but you could mute stuff with a keyboard, foot pedal, LFO, touch-controller, another sequencer; basically anything that would give you a voltage you could use as the gate.
Viele Grüße!
drdel
Viele Grüße!
drdel
