Currently we have prototypes of three totally different types of thru-zero VCOs to be in the starting blocks:
a quadrature version with sine/cosine outputs (prefect sine/cosine outputs, much better than sine waveshapers): A-110-4
a triangle core version (with waveshapers for saw, rectangle and sine): A-110-3
a trapezoid core version (with waveshapers, based on Don Tillman's idea and with his permission): A-110-5 (?)
A-110-4 will be manufactured early in 2015. We still have some problems with the A-110-3 and A-110-5 because the prototypes produced
so far behave a bit different and we still have to find out the reason and fix the problems.
A-110-2 (final version), A-110-3 and A-110-4 will be introduced at NAMM in January (as well as A-147-2, A-138u, A-160-2, final
versions of A-101-6, A-190-5 and A-157, and maybe some more).
Best wishes
Dieter Doepfer
citric acid schrieb:Die neuen Doepfer module sind echt spitze.
Toll ist auch bei Döpfer das die auf Kundenwünsche ein gehen.
Habe heute noch eine Idee zum neuen Ratcheting modul gehabt undes wurde direkt umgesetzt
Döpfer eben.
bartleby schrieb:frag doch mal beim dieter nach. der antwortet in der regel schnell, freundlich und aussagekraeftig...
