youkon
wie cool ist die denn??
hatte hier diesen Thread gelesen:
https://www.muffwiggler.com/forum/viewtopic.php?t=150299&postdays=0&postorder=asc&start=0
..ein paar Audio Demos angehört und erst gedacht, so ein üblicher Nerd hat seine Stimme hochgepitcht, aber nachdem ich nun dieses Video gesehen habe... WOW!! ne "Omi"! RRREEESPEKT! (wenn nur meine Mutti auch sowas machen könnte )
Ja, sie heisst Sandrine bei Muffs und es ist ein Foto mit weiblicher Person, aber in Foren weiss man ja nie...
Das Modul heisst Reflex Live Loop Sampler
und hat ne echt krass lange Feature Liste:
- 174 seconds in stereo at 48Ks/s. This isn't an "up to" spec., it's better than CD quality for almost 3minutes!
- 3 Main RP (Record/Play) Modes: Layer, Echo, R/P Sampler
- 3 PlayFX Modes to play sections of RP Sample at any time, plus Slicing at any time.
- 10 octave Sample Rate Playback range.
- Simultaneous Record and PlayFX/Slice to loop/echo out applied FX.
- Trigger Synchronization of Layer and Echo.
- Sample Slicing during any mode (Record/Play/Echo etc), up to 512 slices, via T/G input, or Slice button.
- Peak Auto-Slicing (Live) by audio levels and intelligent noise floor, amplitude angle/delta algorithm.
- Manual Panel and input CV/TG slice access for playback.
- Loop Start/End controls & CV's for Sample/MiniLoop/Slice/G-Move Playing
- Loop Position/Sizes & CV's for constant Loop size while panning through Sample/MiniLoop/Slice
- G-Move Flowing Granulizer Direction/Speed and Grain Size knob and CV controllable. Sizes: < 1 mS to 250 mS.
- G-Move Granulizer "roll space" can be defined by presently playing MiniLoop, Echo, Layer or Slice boundries.
- Layered PlayFX priority: MiniLoop/Granulize inside a Slice, Granulize inside of a MiniLoop, Slice over a MiniLoop.
- Play FX or a Slice while still Recording / Layering / Echoing via Buttons or T/G.
- Built in CV band controllable EQ for fine tuning feedback and FX output. Flat band mode for CV VCA FX.
- FX (Left) channel feedback insert for external send return filter insertion. Adjustable Send 10V P-P standard.
- Foot Switch compatibility Mode (S-Trig) for foot controlled sync'ed echo/looping/layering
- Reverse FX Play (in stereo) when in Start/End Play mode (by reversing Start and End controls)
- "Slice Groove" Automation feature: Record a tap sequence using selected slices, then change sample rates!
- CV Controlled Sample Rate with Attenuvertor.
- 32 LED Indicators
- 0V to 5V or Full Range Voltage Slice CV option
- Power up panel Last Settings memory
- Spectrum Analyzer for RGB "Color Organ" audio analysis.
- Zero Latency Audio
- Zero Crossing Point Loop Lock and Soft-Mute technology for click free speed looping.
- Blend Control to mix incoming audio with outgoing audio, intelligent auto fade-out for echo and layer stops.
- Feedback Level control for send, or third output channel of sample output only (for multiple amps)
- USART Interfaces for Future Expansion and MIDI control
- Standard Arduino Atmega 2560 R3 Board
- Firmware Upgrade-able
- 32 LED Indicators
