Modular Omi baut Loop Slicer
youkon
youkon
wie cool ist die denn??
hatte hier diesen Thread gelesen:
https://www.muffwiggler.com/forum/viewtopic.php?t=150299&postdays=0&postorder=asc&start=0
..ein paar Audio Demos angehört und erst gedacht, so ein üblicher Nerd hat seine Stimme hochgepitcht, aber nachdem ich nun dieses Video gesehen habe... WOW!! ne "Omi"! :phat: RRREEESPEKT! (wenn nur meine Mutti auch sowas machen könnte :selfhammer: )
Ja, sie heisst Sandrine bei Muffs und es ist ein Foto mit weiblicher Person, aber in Foren weiss man ja nie...
Das Modul heisst Reflex Live Loop Sampler
und hat ne echt krass lange Feature Liste:
- 174 seconds in stereo at 48Ks/s. This isn't an "up to" spec., it's better than CD quality for almost 3minutes!
- 3 Main RP (Record/Play) Modes: Layer, Echo, R/P Sampler
- 3 PlayFX Modes to play sections of RP Sample at any time, plus Slicing at any time.
- 10 octave Sample Rate Playback range.
- Simultaneous Record and PlayFX/Slice to loop/echo out applied FX.
- Trigger Synchronization of Layer and Echo.
- Sample Slicing during any mode (Record/Play/Echo etc), up to 512 slices, via T/G input, or Slice button.
- Peak Auto-Slicing (Live) by audio levels and intelligent noise floor, amplitude angle/delta algorithm.
- Manual Panel and input CV/TG slice access for playback.
- Loop Start/End controls & CV's for Sample/MiniLoop/Slice/G-Move Playing
- Loop Position/Sizes & CV's for constant Loop size while panning through Sample/MiniLoop/Slice
- G-Move Flowing Granulizer Direction/Speed and Grain Size knob and CV controllable. Sizes: < 1 mS to 250 mS.
- G-Move Granulizer "roll space" can be defined by presently playing MiniLoop, Echo, Layer or Slice boundries.
- Layered PlayFX priority: MiniLoop/Granulize inside a Slice, Granulize inside of a MiniLoop, Slice over a MiniLoop.
- Play FX or a Slice while still Recording / Layering / Echoing via Buttons or T/G.
- Built in CV band controllable EQ for fine tuning feedback and FX output. Flat band mode for CV VCA FX.
- FX (Left) channel feedback insert for external send return filter insertion. Adjustable Send 10V P-P standard.
- Foot Switch compatibility Mode (S-Trig) for foot controlled sync'ed echo/looping/layering
- Reverse FX Play (in stereo) when in Start/End Play mode (by reversing Start and End controls)
- "Slice Groove" Automation feature: Record a tap sequence using selected slices, then change sample rates!
- CV Controlled Sample Rate with Attenuvertor.
- 32 LED Indicators
- 0V to 5V or Full Range Voltage Slice CV option
- Power up panel Last Settings memory
- Spectrum Analyzer for RGB "Color Organ" audio analysis.
- Zero Latency Audio
- Zero Crossing Point Loop Lock and Soft-Mute technology for click free speed looping.
- Blend Control to mix incoming audio with outgoing audio, intelligent auto fade-out for echo and layer stops.
- Feedback Level control for send, or third output channel of sample output only (for multiple amps)
- USART Interfaces for Future Expansion and MIDI control
- Standard Arduino Atmega 2560 R3 Board
- Firmware Upgrade-able
Feedback
Feedback
Individueller Benutzer
Ich kenne den Loop Slicer Thread und dachte auch Sandrine ist ein Mann. Gibt halt nicht so viele Frauen, die sich mit Elektronik beschäftigen. Da denken wir etwas eindimensional.
Allerdings passt das Bild nicht zu den Händen und der Stimme. Ok, meins hier auch nicht... Scheiß Internet.... :nihao:
Der Slicer ist cool, aber für mich dann doch zu viele Funktionen. Bis ich das alles nutze, bin ich in Rente... aber ich warte ab, ob das Ding in irgendeiner Form kommt...
youkon
youkon
[quote="Feedback" Da denken wir etwas eindimensional.[/quote]
auf alle Fälle.
die Mädels, die unser Spielzeug toll finden, sind ja schon rar. Die, die damit selber rumspielen noch rarer. Und die, die es selbst bauen können... :roll: (hoffentlich gibts da irgendwo noch mehr davon!)
siebenachtel
siebenachtel
die Dame als "Modular Omi" zu bezeichnen finde ich jetzt etwas abschätzig.
so meine Meinung.
was die Mädels angeht: das dort drüben ist amerika :lollo:
jau, geiles maschinchen das die da zusammenbrutzelt.
mein modular wird sicher auch eins bekommen, zu wheinachten, ostern oder sonst so für zwischen durch :lollo:
youkon
youkon
Überschrift mit Absicht kontrovers benannt.
Habe Respekt vor der Dame, wäre sicher ein Zugewinn sie als Freund bezeichnen zu können! find sie sehr sympathisch
aber sie könnte locker meine Mutti sein und meine Ma ist halt schon Omi
youkon
youkon
ich glaube, am anfang grosse lernkurve, aber sehr gut durchdacht.
footswitches kann man auch dran hängen
youkon
youkon
Features at a glance:
•174 seconds of 16 bit recording @ 48KHz sample rate in Stereo, up to 90 minutes @ 1.5KHz
•Playback +/- 5 octaves
•Delays from milliseconds to minutes, with pristine clarity
•PlayFX Windowing over samples/slices in forward, reverse, granular tracking
•Slicing of samples up to 400 slices manually, by trigger, automatically, or by audio peaks
•Slice modifier and overdubbing, CV controlled selection/triggering
200 note real time Slice Sequencer built in
•Clock sync I/O
•Built in 3 band EQ for tailoring Karplus Strong FX, decays, and delays
•Guitar Looper style mode for controlled Layering/peeling of SOS
•Easy to use single button and hands off foot switch control of sampling
•Firmware Updateable / expandable
Dimensions: width 16HP, height 128.5mm, depth 4.6cm
Price $400
Status: In production, availability by end of April
TonvaterJan
TonvaterJan
Wie geil ist das denn?
Darauf warte ich jetzt schon seit 3 Jahren, bis mal einer sowas entwickelt.
Und dann auch noch so günstig?
Hab ich sofort bestellt...
