neutral-labs
neutral-labs.com
Liebe Freunde der obskuren Klangkunst! Heute erscheint die Neutral Labs Luna, ein Synth im Stil der "Lunetta"-DIY-Büchsen aus den 70ern. Hier ein paar Infos auf angelsächsisch:
Logic, Unbound. Meet Luna. The first serious Lunetta synthesizer.
Look beyond clean waveforms and predictable polyphony. Luna will take you back to a time when digital didn’t mean perfect. It meant raw. Inspired by the subterranean DIY culture of the 70s and 80s, Luna is a love letter to the Lunetta machines of old: Living, breathing organisms built from CMOS logic chips. But where those machines were fragile experiments, Luna is a weaponized instrument of sonic confusion.
The Nervous System Exposed. True to the Neutral Labs philosophy, we don’t believe in hiding the magic behind an opaque face plate. Luna features exposed CMOS inputs and outputs right on the front panel. You're not just patching cables, you are rewiring the brain of the synthesizer itself. Combine signals, bend logic, and physically intervene in the computation to create sounds that shouldn't exist.
Rhythm is Timbre. Timbre is Rhythm. In the world of Luna, there is no difference between a sequencer and an oscillator. The same digital pulse that drives a bass line can be accelerated into a screeching lead or folded into a metallic drone.
5 oscillators provide the raw material. A chaotic array of logic blocks (XOR, NOT, AND, shift registers, counters, multiplexer) will chew up those signals and spit out complex, evolving mathematical noise.
Taming the Digital Mess. Raw logic can be harsh. To turn this binary chaos into music, Luna feeds its digital soul through 3 organic low-pass gates. These analog circuits impart a natural decay and percussive punch to the madness, transforming mathematical errors into bongos, plucks, and thumping basslines.
Drench it in Atmosphere. Once you’ve constructed your signal, destroy it again. Luna comes equipped with a suite of effects — distortion, delay, reverb, chorus, bitcrusher, phaser and more — to smear your logic into a wash of ambient bliss or gritty industrial texture.
Features:
- 5 oscillators
- logic gates (2 XOR, 2 NOT, 2 AND)
- 5 logic blocks (5-step ring counter,4-bit binary counter, 2 shift registers, 4-channel multiplexer)
- 3 touchpads that generate logic signals
- 3 channels for audio manipulation (low-pass gates with adjustable decay and switchable trigger mode, gain, tilt EQ)
- 13 audio effects that can be freely assigned to 2 effect slots running in series (drive, delay, reverb, 6 filter types, bitcrusher, phaser, chorus, comb filter)
- CV control for effects and 2 oscillators
- MIDI control over 2 oscillators, all 3 low-pass gates, and 3 logic outputs
- 2 sequencers with up to 64 steps, syncable to clock or MIDI
- audio output is headphone compatible
- available as a desktop synth or 42 HP Eurorack module (desktop version comes with a 12-pack of black/gold braided patch cables)
Mehr Infos hier.
Heute kommen noch ein paar Demos auf Youtube, die ich dann hier posten werde.
