Novation Circuit Mono Station
darsho
Sö Sünteßeisör !
Quelle: https://www.prodjstore.nl/novation-circ ... encer.html
Novation Circuit Mono Station synthesizer / sequencer
Circuit Mono Station is a next-generation sequenced monosynth that originates from the Bass Station II, with three sequencer tracks that benefit from the 32 velocity-sensitive RGB pads found on Circuit.
The synth has two oscillators, three distortion modes, plus one multi-mode filter with high-pass, low-pass or band-pass. With Circuit Mono Station, the sync and tuning parameters of its two oscillators can be individually controlled. It also offers four waveshapes (sawtooth, triangle, square and sample + hold), a sub-oscillator, ring modulation and noise generation. Users can get the frequency band they want by applying high-pass, low-pass and band-pass filters with slopes of 12dB and 24dB.
In addition, Circuit Mono Station introduces a powerful overdrive. Both monophonic and paraphonic modes are available, with each oscillator individually controlled by its own sequencer. There are three sequencer tracks: two oscillator sequencers and one modulation sequencer. Users can alter Gate length, switch patterns instantly, choose sync rate and mutate patterns.
A four-by-eight modulation matrix makes it possible to route from LFO with four waveshapes, envelope, sequencer or velocity, enabling complex modulation for pitch, pulse-width, amp, filter, distortion or CV. Up to 64 patches can be loaded and saved on the device, right at the user's fingertips. Circuit Mono Station controls separate hardware via CV, Gate and modulation outputs, and has MIDI In, Out and Thru, so other MIDI gear can be connected. Via USB, Circuit Mono Station can be plugged into Mac or PC, where unlimited patches can be managed using Components.
Two oscillators with individual control of sync and tuning parameters
High-pass, low-pass and band-pass filters with slopes of 12dB and 24dB
Three distortion modes
Choose monophonic or paraphonic modes with individual glide control
Four-by-eight modulation matrix that enables complex alteration and routing
Load and save up to 64 patches on the device
Three sequencer tracks (two oscillator sequencers, one modulation sequencer)
16 scale types
Changeable sync rates
CV/Gate, CV mod plus MIDI In, Out and Thru for connecting and controlling separate hardware
Backup patches and sessions with Components
499 find ich human, Man wie geil. Ich verkaufe definitiv BSII und Microbrute und hol mir entweder nen AS1 oder das Ding hier. Ist ja besser als Weihnachten.
Schade, dass er (außer Distortion) keine Effekte hat. Wenigstens ein einfaches Delay wäre nett gewesen.
Das fand ich auch grad! Der Sequencer vom Circuit kann ja auch die FX automatisieren (zumindest die Sends), das wäre hier super gewesen!
Finde ich auch. So ein portabler Synth und dann muß man doch wieder massenweise Trampelkisten oder 19" Racks dabei haben.
Würde man damit einzig und allein Basssounds produzieren, wäre eine Distortion sicherlich völlig ausreichend. Reverb und Delay sind da sicherlich weniger angebracht.
Aber so ist das für mich dann doch ein K.O.-Kriterium. :cry:
Ein Knopf mehr und den Code vom Circuit. Wäre für die Novation-Entwickler sicherlich auch keine Rocket science gewesen.
Ich habe eine CMS im Betatest und darf ab jetzt drüber sprechen und videos posten. Gleich montag nach der superbooth werde ich berichten. Habe meine unit erst gestern bekommen. ;)
Oh, wie cool. Mich interessiert, ob man, anders als beim Circuit, die Gate-Länge pro Step auch kleiner als 1/16 wählen kann!?
+1
und ob man die Midikanäle selber wählen kann?
und ob es nun 64 Session-Speicher anstatt der 32 beim Circuit gibt?
Green Dino schrieb:
Ich hab eben was von 64 Patchspeicher gelesen. Session = Patch beim Circuit?
Session ≠ Patch beim Circuit
Session = Sequencen, Effekte, Makroeinstellungen usw. (Circuit = 32 (zu wenig!), Mono Circuit = ?)
Patch = Patch (Circuit = 64, Mono Circuit = 64)
Ganz Deiner Meinung darsho.
In der Tat ein bisschen so, als hätte man die Bitrazer, Demoras + Co von Roland an ein Launchpad getackert......
Finde 549 Euro auch ein wenig zu viel für so ein Gerät.
:peace:
Ja,Ober und Unterseite passen für mich auch nicht wirklich gut zusammen.Der Sequencer verspricht aber fun pur.Curcuit ist klasse,habe den aber letztenendes wieder abgegeben weil mich der Parameter Blindflug gestört hat.Könnte aber irgendwann wieder kommen.Oder das hier wenn's mal cheap ist.Und wenn der Grundklang identisch zur BS2 ist.
Aber für 500€ steht bei mir erstmal ein System 1m ganz oben auf der Wunschliste.
Ja...Irgendwie ne komische Kiste.
Obwohl...Der Sequencer scheint doch recht ausgefuchst zu werden, wie man so sagt.
https://m.youtube.com/#/watch?v=j3oJoeQmVxE
Wenn man mal genau zuhört...Schon geile Sachen. Man kann z.B. ein 16 Step Pattern verketten mit einem 8 Step Pattern und dann noch ein 8 Step Pattern auf Random gestellt - Ergibt 4 Bars mit der letzten Bar als quasi Fill.
Osc2 oder Noise können am Filter vorbei geroutet werden, volle Automatisierung der Parameter, Mod Matrix Ziele sind nicht exklusiv.
First Step und Last Step können gesetzt werden, Sequencer Richtungen Vor, Zurück, Ping Pong und Random. Da geht einiges mit.
Hat jemand das mit den Hüllkurven richtig gesehen? Wieviele gibt es?
Irgendwo auch Youtube hab ich gelesen, dass auch triolische Sachen gehen, was beim Circuit ja nicht geht.
Ah, cool. Dann hoffe ich mal, man bleibt nicht nur auf 16tel beschränkt.
Dann wäre die Kiste eigentlich ziemlich gut und preislich auch nicht so abgehoben wie ich anfangs dachte.
darsho schrieb:
Den Namen 'Circuit Mono Station' finde ich übrigens nicht so dolle, das führt zu Verwechselungsfefahr mit dem Circuit, außerdem betonen sie ja dauernd, dass das Gerät paraphon ist.
Ich dachte in der Tat zuerst, es sei 'ne neue Klopfe. Quasi ein Circuit mit mehr Lametta.
"Dazu zwei simpel gestrickte Analogsynth Spuren"
Also ist der Monosynth nun zweimal im Gerät vorhanden oder sind die 2 Spuren für OSC 1 und 2?Vermutlich letzteres.Für mich eher nicht so interessant.Könnte im Zusammenspiel mit Sync ein paar nette Sequenzen ergeben,leider bin ich nicht so der Sync Freund.
Schade,das sie ihm (bei nur einer Hüllkurve)nicht noch ne orgelige Gate Hüllkurve für den VCA spendiert haben.Sieht nicht so aus als hätte der LFO ne One shot Funktion.
1x paraphone Sythengine.
ich dachte im ersten augenblick es sei der "circuit" mit intigriert. schade eigentlich. somit uninteressant. häte mich auch gewundert wenn en groovebox aus england kommt :selfhammer: :lollo:
  • #26
Es ist ein sequenzer drinn. Ich poste in den nächsten tagen mal erste soundfiles. Habe bei meinem testgerät bei den ersten spielerrein was mitgeschnitten.
  • #27
Für mich ist das Ding irgendwie ein Rätsel, was soll das sein?
Ausser paar Piepstöne hab ich da noch nichts vernünftiges von gehört.
Oder ist das eher eine weitere Modulations-, Sequenz-, Arp- Quelle (z.b. für den Peak?) ?
Kannst du das mal erläutern/zeigen ?
  • #28
Leute das Gerät wurde erst vorgestellt mit einer betasoftware, das teil ist noch in der beta Phase, es ist ein vollwertiger synth mit nem mono Sequenzer mit div extras.
Wartet einfach mal ab. :-) Ihr seid immer so voreilig
Ist eine BassStation 2 mit zusätzlichen funktionen... also schon was feines !
