Roland TR-1000 Drummachine - Analog, Samples, FM, ACB
  • #1.561
Also, 2 Analoge (unterschiedliche) in einem Layer gehen!!! Siehe at: 53:00+
M.i.a.u.: dani und sllk
  • #1.562
sorry wenn das schon 48 mal gefragt wurde: gibt es nun analoge effekte und wenn ja welche?
  • Hmm
M.i.a.u.: dani
  • #1.563
FAQ Info zum External Sync, wenn man mit externem Master arbeitet:
HOW DOES THE TR-1000 HANDLE TIMING AND SYNC WHEN USED WITH EXTERNAL GEAR?
The TR-1000's internal timing is very tight - it synchronizes all 10 tracks (including layers) together to play back simultaneously with minimal error, no small feat for the mixture of sound engines it accommodates.
The sequencer/system is tuned for TR-1000 to act as the clock source, keeping its internal tracks tightly locked while closely syncing any connected gear set as clock destinations. While the TR-1000 will accept an external clock and follow as a clock destination, some latency can occur due to its internal timing design.
To improve performance in these setups, we added two key features:
Track Sync (found in Project Settings): switches between "All Tracks" and "Layered Gens". AlI Tracks is the tightness internal timing, though has the most latency when externally clocked. Layered Gens loosens the internal track timing a bit (while keeping the Layer timing tight) with the benefit of reducing the external latency substantially.
Nudge (found in Tempo screen): Acts as a clock offset that can be used to fine-tune timing even more. This works for both Track Sync modes.
  • Hmm
M.i.a.u.: dubsetter, verstaerker, dani und eine weitere Person
  • #1.564
In der "Analog FX" sind Filter (SVF mit Resonanz) und Drive analog. Der Drive lässt sich wirklich sehr feinfühlig einstellen - super! Dazu kommen die ganzen digitalen Effekte auf Track und Master-Ebene.
M.i.a.u.: TopperHarley
  • #1.566
mag ich sehr
M.i.a.u.: Casetti, Linear Displays, Kevinside und eine weitere Person
  • #1.567
Was kann nun dieser Morphcrossfader?
Wie viele Sounds, Parameter beeinflusst er.
Gibt es Funktionen, die nur in der App vorhanden sind, oder ist die App eine Zugabe, aber ALLES funktioniert auch ohne App und Cloud und Registrierung und Gedöhns...
  • #1.569
auf den Morph-Fader kann man alle Knobs der Effekte sowie Instrumente legen
ich denke geht alles auf dem Gerät, ausser das was du halt im Computer machen willst: Editor sowie brauchts Treiber für das Multi-Channel-Streaming (auf letzten Satz keine Gewähr, habe das Ding nicht)
  • #1.570
Ich finde grundsätzlich, dass eine Drummaschine in 2025 so aussehen, finde das Konzept schon richtig gut. Aber wie weit kann man sich mit den Analog Engines von 808/909 entfernen? Ist das ähnlich flexibel wie beim Rytm?
  • #1.571
Anders, in einigen Videos wird das gezeigt, es ist mehr Range und ein paar Parameter - es ist klanglich natürlich 808/909 oder auch wie bei den ACB Modellen - oder einem Modul wie Tubbutecs 606 Angebot - also zB die Cowbell ist stimmbar - die Spreizung der Oszillatoren kann man setzen. Es gab sowas auch mal als MOD für die 808. Das war ganz interessant.
Ja, man könnte es mit der Offenheit der Rythm vergleichen, weitgehend - nur luxuriöser, weil es analoge Instrumente sind, bei der Rytm ist alles teilanalog gemischt mit Sampling. Das hier ist noch eine kleine Stufe weiter.
M.i.a.u.: Chris, elbonzoseco und sllk
  • #1.572
Also nachdem ich jetzt einige Videos angeschaut habe, fällt mir auf, dass die Sounds der analogen 808 auf der TR-1000 sehr gut reproduzierbar zu sein scheinen. Was mich aber etwas verunsichert, ist die Kick der analogen 909 in der Tr-1000. Die Kickdrum meiner original 909 klingt für mich wesentlich besser als die der TR-1000. Die Kickdrum meiner 909 geht schon fast in Richtung 808.
  • #1.573
Mein Frage warum wurde ACB entwickelt plus riesige Erklärungen dazu wenn es aufeinmal doch voll Analog ging.
Welcher Sinn steckte dahinter?
M.i.a.u.: Karmaloge
  • #1.574
solang sie nicht jittert sind mir bis zu 30-40ms Latenz relativ egal.
Vielleicht mag das jemand mal testen?
  • Hmm
M.i.a.u.: dani
  • #1.575
ACB ist doch hier extrem erweiternd, die ganzen anderen Instrumente und auch solche, die eigentlich Samples haben wie die TR707/727 haben ja hier dadurch Pitch und Co - du kannst durch die ACBs auch noch weitere Instrumente aus anderen Geräten nutzen, die die TR1000 so nicht physisch 2x hat. Es gibt also schon einige Gründe dafür, macht die Maschine flexibler, gerade wo es ja auch Dual-Layer Sounds gibt.
M.i.a.u.: MartYATARI, dani und Golden-Moon
  • #1.576
Ich bin von den Digitalen Effekten in der TR 1000 sehr enttäuscht, die klingen echt nicht gut für diesen Preis.
Die Analoge TR808 und 909 klingen Super aber der Rest ist mir das Geld nicht Wert.
Ich bin etwas enttäuscht von der TR 1000.
Ich werde noch ein paar Tage weiter Testen aber momentan würde ich sie wieder zurück schicken.
Die Analogen FX finde ich auch eher Mittelmässig im vergleich zu meinen Erfahrungen mit Tr808 und Verzerrungen.
  • Hmm
M.i.a.u.: MartYATARI, jpher, finderzh und 3 andere
  • #1.577
Das erklärt vieleicht warum ACB in der Tr-1000 mit integriert ist aber nicht warum sie es erst entwickelt haben und dann aber 808 und 909 doch als richtiges Analog kommt.
Erklärt wurde ja als Begründung für ACB das es anders nicht geht wenn ich mich recht erinnere.
Aber gut die frage geht an Roland selbst eigentlich.
Die müssten das ja jetzt beantworten.;-)
  • #1.578
@Sticki:
Ein Erklärungsversuch ...
"Im März 2022 löste der Brite Gordon Raison als CEO und repräsentativer Direktor den bisherigen Präsidenten Jun-ichi Miki ab, der seit 2013 im Amt gewesen war. Gordon hatte ab 2013 die europäischen Aktivitäten von Roland geleitet."
Die TR-1000 wurde in den letzten 4 Jahren entwickelt.
M.i.a.u.: Sticki
  • #1.580
Roland baut prinzipiell ungern analog, bei Drummachines ist das seit 1983 so, also nach der 909. Bei Synths ist das fast ebenso, weil digital auch günstiger ist. Die könnten natürlich auch einen Jupiter 8 oder System 700 bauen, was aber ebenso ein Luxusgerät wäre und teuer.
Die ACBs wurden zudem "hinzugekauft", man hat sie also entwickelt als Aira Serie, und das kam gut an, weil das endlich wieder gut klang, bei den Drums ist das ähnlich, aber die ersten ACBs waren die drei Klassiker.
Und generell kann ACB auch andere Strukturen ermöglichen, theoretisch könnte man da auch mehrere LFOs und so weiter einsetzen und vieles mehr.
Es gibt daher auch für Roland eine stringente Regel, die sie mit der TR1000 gebrochen haben, was viele freut.
Aber ACB bleibt weiter hochinteressant. Gern auch als Basis für neue Instrumente und Variationen, die nicht nur nahe der Struktur der Originale sein müssen.
Sollte man die ACB Elemente allerdings extern coden lassen, so haben sie das nur als geschlossenen Abschnitt, da gab es in der Vergangenheit Hinweise, die sich aber später etwas verstreuten durch Kombinationen und andere Anwendungen. Spekulationen über neue Jupiter und SH Synths - bleiben damit natürlich offen. Ich denke, dass sie das so nicht unbedingt nochmal machen.
Aber - man weiss nie.
M.i.a.u.: kybernaut_01, dani und Sticki
  • #1.581
Ich würde vermuten es fehlt an Innovationsideen. Die versuchen ihre Legenden in irgendeiner Weise neu auszuschlachten.
Keine Frage, die Roland'schen Digitalen klingen gut aber die Konkurrenz ist sehr stark. Und das Beste was sie machen konnten war die alten Legenden Analog erneut auferstehen zu lassen. Sprich Analoge Reinkarnation von den "echten" Erschaffern der Legenden.
Klanglich nimmt sich das alles nicht mehr viel.
M.i.a.u.: Sticki
  • #1.582
Weil die 808 im Falle von Claves und Congas nicht analog, sondern per ACB nachgemodellet wurde. Somit keine 100%ige analoge 808 in der TR1k. Ich denke aber, das ist absolut irrelevant, sonst hätten sie es wahrscheinlich nicht so gemacht.
  • #1.583
Naja Tonale Unterschiede zwischen acb und Analog spielen sich wahrscheinlich wirklich nur im Kopf ab.
Bin ja eigentlich zufrieden mit den ACB Sachen.
Wichtigste für viele ist ja die 808 und 909 Bassdrum gibt's jetzt wieder voll Analog von Roland. :-)
Wenn auch etwas anders klingende.
  • #1.585
Gerade bei den Elektronauten gelesen: Ein Patternwechsel ohne Dropouts scheint nicht zu den Kernkompetenzen des dicken Rolands zu gehören.
M.i.a.u.: MartYATARI, dubsetter und dani
  • #1.586
Congas sind Variationen mit Schalter zu den Toms im Original - müsste man mal sehen, ich habe die sehr gern als Zusatz für Snares oder sowas verwendet. Ja, es sind nicht alle Instrumente - aber die meisten - die "wichtigsten". Maracas? Man kann natürlich diskutieren, ob das ein Bruch wäre.
Ich mag die Rimshot der 808. Also - für mich ist das "okay". Auch wenn ich die Congas schon auch gern analog hätte, aber - naja, man musste sich wohl für 16 entscheiden, ich hätte die 909 Toms auch eher ausgelassen, aber da sie dehnbarer sind, sind die ggf. nutzbarer als die echten, Ansichtssache.
Also - kritisierbar ist das schon - aber mit ACB kann man diese Sounds bekommen,
  • #1.587
Wahrscheinlich steckt das Geld eher in der Klangerzeugung als in den Effekten. Es gibt Einzelausgänge. Damit dann in den Behringer WING rein oder in den Eventide H9000 usw.
M.i.a.u.: Novex
  • #1.588
Ja, man könnte es mit der Offenheit der Rythm vergleichen, weitgehend - nur luxuriöser, weil es analoge Instrumente sind, bei der Rytm ist alles teilanalog gemisch mit Samling. Das hier ist noch eine kleine Stufe weiter.
Rytm ist komplett analog bei den Engines, wie der tr1000, aber bietet sehr viel umfassendere Klangbearbeitung und Möglichkeiten, Multimode Filter, Overdrive Pro Stimme und Kompressor + Distorion auf Masterbus ist ebenfalls Analog, nur gewisse Effekte sind Digital, und auch der integrierte Sampler, man hat beim Rytm halt beides, voll analog und Sampler, und zusätzlich noch drum pads usw. der tr1000 kommt da in Sachen Umfang nicht annähernd ran, auch nicht in der Klanggestaltung der Engines, Samples, Sequenzer und Effekte. Genau so wenig wie mit der nahtlosen und perfekten DAW Integration. Alles lässt sich auch einfach per VST Editor steuern wenn man denn will.
Was im Rytm nicht analog ist, ist das noise, aber das ist eine Designentscheidung und nicht weils billiger ist.
M.i.a.u.: TotalKaputteKampfmaschine, jpher, C0r€ und 3 andere
  • #1.589
Leider ist die Rytm einfach sehr viel umständlicher zu bedienen. Insbesondere die Speicherphilosophie ist für mein Gehirn einfach nur "quer". Die Rytm ist eher Groovebox, kann sicherlich mehr (ein Poly-MIDI Upgrade würde ich gerne sehen). Den Euclidischen-Mode mag ich auch. Der fehlt (noch) bei der TR. Aber letztendlich sind das zwei sehr verschiedene Geräte.
Was den Tonaussetzer angeht: das trifft nur zu, wenn Pattern mit Kit-Wechsel verbunden ist. Weiß nicht, ob der wirklich ein großes Problem darstellt.
M.i.a.u.: alexpen, tunerexpro und Golden-Moon
  • #1.590
Leider ist die Rytm einfach sehr viel umständlicher zu bedienen. Insbesondere die Speicherphilosophie ist für mein Gehrin einfach nur "quer".
Ein paar Regler mehr am Rytm wären sehr wünschenswert, aber der kann halt auch einfach sehr viel mehr und ist dementsprechend kompliziert zu bedienen.
Trotzdem gefällt mir das Layout vom TR1000 so viel besser. Ich hätte ohne zu zucken 2,4k für den Rytm ausgegeben, wenn dafür noch ein paar Fader und Regler mehr gehabt hätte. Ich finde die Designentscheidung von Elektron, einfach alles verschalten zu müssen, ziemlich schwachsinnig. Auf der anderen Seite muss man auch gestehen, kennt man das Gerät mal richtig, klappt alles direkt, ohne auf den Bildschirm zu schauen, meistens so designt, dass man die 2 Knöpfe mit einer Hand drücken kann, um in das entsprechende Menü zu gelangen.
Von der Menüführung her, Sampleauswahl, kopiert da Roland ja eher schlecht als Recht, das finde ich im Rytm viel besser.
