Schönes Euro Teil
island
Modelleisenbahner
da könnet ich glatt schwach werden :mrgreen: Zum erstem mal das mir diese "kLEINTEILE" rein Optisch gefallen :opa:
Von Matrixsynth kopiert:
http://www.matrixsynth.com/2013/09/muta ... quare.html
New modules (release expected in december 2013 Could change)
SHADES :
- Utility Module mixing / mitigation / voltage shift (offset) .
- 3 channels is adjustable attenuator in either polarizer (' atténuverteur ') .
- Standardized +5 V or +10 V constant voltage generation (offset ) Hall.
- Outputs strung together in other to use blender.
- High accuracy and transparency Amplifiers .
- 6HP
PEAKS :
- Utility Multifunction Module generating CV or audio signals from triggers: envelope , LFO generator 808 percussion type, all on two channels.
- Two trigger inputs , two outputs.
- Two editing modes : coupled (both channels share the same parameters, but are triggered independently ) or separated ( one control two parameters for each channel ) .
- 8HP
features :
ADSR envelope * / AD
* LFO with sinus shape / square / triangle / slots / with random variations ( duty cycle , slope)
* LFO with tempo setting .
* Generator BD and SD TR- 808, after modeling the original circuits.
YARNS :
- Interface MIDI manager up to 4 channels : either 1, 2 , 3, 4 sections
independent ( each with its own MIDI channel ) is a section
polyphonic 2 or 4 channels .
- Each section has its own arpeggiator and step sequencer
( 64 steps ) , inspired MIDIpal .
- Each CV output may be replaced by a digital oscillator
Simple ( waveform 5 ) assigned to a section .
- 12 HP
The module is equipped with a MIDI output allows controlling
instruments with external sequencer / internal arpeggiator , or
to " spill over" notes exceeding the polyphony to a second
interface or a MIDI synthesizer.
TIDES :
- Function Generator can be used as AD / AR envelope , LFO , or oscillator.
- 3 frequency ranges , the module containing in all 0.001 Hz to 15kHz .
Operating cycle (LFO / oscillator ) in single pass (AD ) or single pass with steady ( AR) . Calibrated V / Oct to be "played" on musical scales .
- Adjust the ratio of rise time and fall ; waveshaper
with various forms of curves uphill and downhill , and wavefolder filter to smooth the curve or dent - all controllable CV .
- CV controlling the output level (and therefore requires no external VCA ) .
- CLOCK input to (in addition to a conventional sync with division / multiplication of frequency) to "learn" the module output in a rhythmic pattern sequencer . The CLOCK input operates as a PLL for audio frequencies.
- Gate -end attack / decay outputs for chaining multiple
shell segments .
- Outputs "unipolar" and "bipolar" - with a positive bump in the attack phase , and a negative bump during the decay phase or loosening .
- At audio frequencies , the module behaves as a synthetic route
digital to very special stamp .
- 14 HP
FRAMES :
- Module morphing . Used in blender, generator CV or router / signal distributor 4 channels (or even combinations mixing these functions). The module allows you to store multiple (up to 64 ) different configurations gains of each of its four channels (or output CV for unconnected inputs ) , and then allows
to interpolate from one to the other - the movement being controlled by the
middle button or a CV.
- 20 HP
Surprises !
Braids Easter Egg : write " 49" in the text editing to ear a morse code. It's an extract of the book Thomas Pynchon's "The Crying of Lot 49"
Braids update ( in 10 days) Will add :
* Adjusted wave tables in memory to minimize
phase difference / amplitude between shapes and textures generate
more uniform.
* New WLIN mode to scan all the forms
wave of wavetable mode on a single dimension using the button
STAMP . The COLOR button selects different modes of interpolation /
resolution.
* New fashion DRUM generating a metal percussion deaf can
be " held " in drone.
CVpal : USB- > CV / Gate dual channel kit - easy to
DIY beginners ! Eurorackable or small independent housing. iPad
/ OS X / Linux.
Shruthi XT version of " one knob per function" of Shruthi , size
compact on a single PCB .
And to finish ... there is more to find easter egg ... will you find 'em ? Olivier Will reveal em When He will come back for the 2nd Release Party !
