Tempest als Midi Sequencer
Re: Neue Drummashine von Dave Smith: Tempest
* Each of the 6 analog voices has 2 analog oscillators plus 2 digital oscillators (with a large bank of included samples), Dave's classic analog low-pass filter with audio-rate modulation, an additional high-pass filter, analog VCA with feedback, 5 envelopes, 2 LFOs, an extraordinary variety of analog modulation routings, and stunning sonic quality, warmth and punch. Although optimized for drum sounds, it excels at tuned sounds as well, and even doubles as a 6-voice analog synth. In addition to the 6 direct voice outputs, there are stereo mix outputs and phones outputs, plus 2 inputs for foot switches or expression pedals, MIDI in/out and USB.
* The performance-oriented operating system, 90 panel controls, and bright 256 x 64 OLED display work together to provide a tightly integrated, non-stop workflow: record a drumbeat in real-time, switch to another drumbeat and use the lit pads to record it using step programming, switch to another drumbeat and record tuned keyboard parts, use the 2 touch controllers to to record real-time note or beat-wide parameter animations, use the generous sound controls to edit any of the drum sounds, tweak the analog effects or drum mix, arrange beats in real time and record the live arrangement into a song, enter/exit Song mode and much more, all without ever stopping play.
* 16 pressure- and velocity-sensitive lit pads are arranged in a 2x8 configuration, providing intuitive access to all your fingers and providing the ideal compromise between the popular 4x4 pad arrangement (popular for real time programming ) and 1x16 arrangement (popular for step programming) because Tempest does both. The pads can be used to play 32 drum sounds (2 banks), mute/unmute the 32 sounds on playback, play and arrange 16 beats in real time, play one sound at 16 tunings (in a variety of scales) or 16 velocities, or as 16 time steps for step programming. The ROLL button permits creating drum rolls or repeated groove patterns by varying pad pressure as the beat records, and doubles as a momemtary "stutter" effect when the pads are assigned to play beats. Use the Sustain button on tuned parts like a keyboard's Sustain pedal, or to choke drum sounds or drumbeats when the pad is released.
* Two pressure- and position-sensitive Note FX slide controllers permit real-time recording of note or beat-wide sound parameter changes into the drumbeat as you play. For example, record simultaneous filter frequency, tuning, envelope decay and pan changes for each note, or control similar parameters affecting the entire beat.
* A variety of unique effects are provided while maintaining a pure analog signal path: 1) Stereo analog compressor and distortion circuits affect the stereo output mix, 2) beat-synced delay is achieved by generating additional delayed note events within the sequencer, and 3) a beat-synced "stutter" effect is created entirely within the sequencer by looping short portions of the drumbeat on demand.
* The degree of swing timing can be adjusted in real time during playback. Roger used his entire bag of tricks to make the swing sound very human and natural.
* Compact and portable: 15.4" L x 9" W x 2.5" H
"Dave Smith called for a reboot, and the result will be not one but two drum machines. One will be released by Dave Smith Instruments, and another by Roger Linn Design."
Da kommt also noch mehr !
Re: TEMPEST von Roger Linn & Dave Smith
das teil sieht interessant aus.... aber 2000 dollar ist ein haufen holz!
Huch!
Sehr geil, da spielt nur mein Konto grad nicht mit!
...Sie betonen ja immer wieder da man "alles" bei laufender Maschine machen kann, heist das genau wie beider SPSUW samplen und resamplen bei laufendem Beat?
wow, grosse ueberraschung... bin schon gespannt und gespart wird jetzt auch gleich mal.
Wau, absoluter Kracher! Und wenn sie tatsächlich das kann, was versprochen wird, ist das nicht zu teuer. Qualität hat halt ihren Preis.
Coole Sache - wenn die so geil ist, wie ich mir das jetzt vorstelle ...
Allerdings: Die Vorführung im Video überzeugt mich noch nicht so - da müssen die zwei alten Knacker erstmal wen anders ranlassen ;-).
mfG Bruce
mann in usa gibet wohl keine krise mehr...2000bugs ...wow wie zu begin der machinedrum und was kostet die heute ...mann die fixen einen wieder ganz gut an :-=) das video ist jedenfalls ganz gut
C-O-O-L
Große Überraschung nach der Absage beider.
Komplett analoge Tonerzeugung mit Effekten plus digitale Waveforms. :)
Sieht schön aus und kann sogar Lauflicht als Zugabe. Reine Drummaschine, kein MIDI-Sequenzer, also kein MPC Ersatz.
Bin mal gespannt wie sich die deutlich günstigere, neue Konkurrenz von Arturia schlagen wird.
Das Teil dürfte wohl am meistem mit dem Speckie kämpfen, da oben ist mehr Luft als unten wo die Sumoringer um geiz kämpfen. Ein bisschen Evolverzergrooveboxung schadet ja nicht.
Wer das Interview nicht gelesen hat...hier nochmal zur Info...der Tempest ist ein vollwertiger polyphoner 6 stimmiger analoger Synth! Sozusagen ein "Hextra'". Und dafür ist der Preis durchaus gerechtfertigt.
Dies aber plus Sampling. Das ist doch was. Den DSI'schen HPF könnte man bei der Gelegenheit noch etwas verbessern, so wie den 12dB Mode.
Ich bin mal gespannt was dann von Roger Linn kommt, schließlich war ja von zwei Drummaschinen die Rede...
Bin sehr überrascht, ....als ich jedoch den Preis von 2000$ sah verging mir alles. Das geht mal garnicht. Schade, werd das gute Stück aus meinen Gedankengängen streichen müssen. Einfach viel zu teuer.
In Anlehnung an den Venom Thread... ;-)
Ein geiles Ding so rein auf dem Papier. Klar, der Preis ist nat. kein Schnäppchen, aber das waren gute analoge noch nie. Kann ja quasi mehr als ein Prophet :)
Amis, ...muss man da noch was erwähnen?
(zur Zeit laufen dort doch selbsternannte Superhelden herum und wollen Amerika retten) ;-)
Bei Tempest muss ich allerdings an Tempest 2000 (Atari Jaguar) denken. Super Spiel mit geilem Soundtrack!!
http://www.youtube.com/watch?v=ijjQpOuognI
http://www.youtube.com/watch?v=EfyCBtGy ... re=related
http://www.youtube.com/watch?v=8tUN5f9Y ... re=related
Naja, das Original waer' in deinem Fall der Tempest Automat...
Der Schriftzug erinnert mich an den Spectralis ;-)
Apropos Specki. Neben Tempest, Spark und Beat Thang müsste er mal wieder Flagge zeigen. :twisted:
Der Tempest ist ein vollwertiger polyphoner 6 stimmiger analoger Synth! Sozusagen ein "Hextra'". Und dafür ist der Preis durchaus gerechtfertigt
Du könntest auch dir selbst eine "Tempest" "lite" Drummachine basteln...mit 4 Stimmen...Man nehmen einen DSI Tetra und einen "Europa" Sequencer.
Wahlweise noch kombinieren mit einem Doepfer Dark Time. Dann noch eine MPC500 dazu...oh...das sind dann auch schon fast 2k... :cry:
Keine Konkurrenz, da anderes Obst. Spark ist wie Maschine, nur ein Midi Controller. Tempest ist ein 6 stimmiger polyphoner analoger Synthesizer.
