Controller
Oval – Hang-Style Instrument (sends & senses MIDI)
Das Instrument hat den Hang ein wenig wie ein Hang auszusehen, ist aber elektronisch. Es hat mehrere X/Y-Felder mit jeweils 5 Drucksensoren – und es gibt ein Video dazu – die Macher brauchen noch etwas Support.
  • Dimensions: 420 x 420 x125 mm
  • Weight: 3,1 kg
  • Materials: Solid Surface with acrylic, quartz, marble and bauxite.
  • Rechargeable long-lasting lithium battery via USB.
  • Class-compliant MIDI over USB connectivity through Lightning on iOS and USB on Android and any other operating system.
  • Bluetooth BLE connectivity with Apple BLE MIDI compatibility on iOS8 and OSX Yosemite
  • External input for a pedal or external controller
  • ARM Cortex M3 microprocessor
  • Bluetooth 4.0 Low energy
    oval bunt
bei / at ovalsound.com
oval instrument
this instrument looks a lot like a hang but it’s electronic – just found it because I was following Hannah Peel, who is in a studio that looks a lot like that of John Foxx’es, in’it?
the instrument needs support, so..
here’s where to go – you can control and set it up with an app.
note – it has reached the Kickstarter goals – but you can only get one THERE, so..
these „pads“ are registering x/y position and pressure – it’s 5 sensors per pad and a multicolour LED showing what it is sensing..
Hannah2
->Another MIDI Hang but seams without those 5 sensors:  Digital MIDI Hang?
Related posts
