Status
Schade, finde ich, das wenn man sich eine eigene Expansion baut, man sie zwar einladen kann aber keine Bilderchens hat im Browser, das finde ich schade, aber hätte man sich ja denken können, man möchte ja eben die eigenen Expansions supporten...
Frank
Kann man die Maschine + irgendwie reseten? Beim Aufstarten in den Standalone Modus will Sie sich immer Updaten (obwohl das neueste OS drauf ist), dies gelingt jedoch nicht und wenn ich Sie dann Reboote oder Shutdowne komme ich immer wieder an den Punkt, dass Sie sich Updaten möchte.
Aus dem NI Forum:
It's a new Reset tool, just useful if you can't Reset your unit normally. For your your issue, you can try this:
Go to SETTINGS > SYSTEM, hold SHIFT and press RESET (soft button 4).
(Notice that this will delete all your settings and preferences, including favourites/starred items)
Frank
MASCHINE+ 2020 Wrap-up and what to expect in 1.2.15
Hi all,
We hope you are keeping healthy and making a lot of music!
As we wrap up the year and following up on Kai @ NI's post, I would like to give you an idea of what to expect on our next update for MASCHINE+, 1.2.15. We are working hard on it, and here are the features that are already built and being tested internally:
  • More stability, with an upgraded kernel version. The kernel is a central part of the operating system, and this new version is proving to be much more stable so far in our internal tests.
  • Support for NI controllers: full integration for KOMPLETE KONTROL S and A-Series and M32 Keyboards. You might be asking yourself: "What about Jam?" (drum roll...) I'm excited to say that it will work too! We can't guarantee full support and some of the features might not be available, but no major blockers.
  • Save with Samples: while saving a project, you'll be able to have your samples saved in the project folder, and choose to automatically delete unused samples.
  • Fix to activation issues that some users experienced issues with Kontakt or Reaktor.
  • Fix to freezes and crashes when browsing through Character tags.
  • Fix to missing images in the Library tab.
There are a few things we are still working on, and we expect to see in the update in January - unless we find any blocking issues.
We are looking forward to shipping all of this. : )
Some organisational updates, as you might have read in Kai's post:
From January on I am leaving MASCHINE+'s steering wheel and moving on to another product. Something you will definitely hear about next year!
So all communications around MASCHINE product line, including MASCHINE+, are now in the experienced hands of Chris @ NI , who has been the driving force in the hardware development of MASCHINE MK3, MIKRO MK3 and MASCHINE+ for years now.
I would like to take this opportunity to thank you all for the participation in this forum - your feedback definitely helps us improve this product. Special and big thanks to our Beta testers and community moderators - your contribution is really invaluable! Thank you for all your support.
I would also like to leave a note of deep appreciation for all the teams in Native Instruments that helped building this product, as well as to Customer Support for helping us help our users overcome issues. There is so much great work and dedication behind all this.
Our motivation is to hear that this piece of gear is inspiring you to create even more and better music. We hope that is the case for you during the holidays and the new year to come.
All the best,
Mariana
Aus dem NI Forum:
Frank
Danke aber da komme ich nicht hin da ich die M+ "nur" im Controller Modus verwenden kann. Sobald ich Sie Standalone starten / benützen will, möchte Sie ein Update machen was nicht geht :sad: Vermutlich habe ich Sie im "Airplane Modus" und diesen kann ich nicht deaktivieren, solange ich nicht in die Standalone Funktion komme.
Habe den NI Support angeschrieben, mal schauen was dabei raus kommt.
Soviel ich weiß, funktionieren alle class compliant Audiointerfaces.
Ich betreibe an meiner Maschine+ erfolgreich das Tascam Model 12.
ich habe auch ein model 12 und habe das nicht hinbekommen, magst du mir ein best practise geben? hab mich bestimmt dumm angestellt: bei mir wird auf dem display des model 12 wenn ich per usb an die maschine+ anschließe "usb fs mismatch" angezeigt.
ansonsten wäre doch das der weg: settings - audio - interface (dort auf m12 umstellen hw:m12,0)
dann channel - output - und wie bekomme ich dann einzelne gruppen oder sounds auf die einzelnen kanäle des m12? da habe ich ext.1 -16
oder gehen nur die inputs?
Wic
Wichtig ist erstmal, dass du das Model 12 an einem der beiden USB A Ports anschließt und nicht am USB B Port. Da muss man sich ein USB C zu USB A Kabel kaufen. Leider gibt es das nicht beim Model 12 dazu, zumindest nicht bei mir.
kann ich denn die ins und outs per usb nutzen - also einzelne sound oder gruppen an das m12 schicken oder nur vom m12 empfangen
Du kannst Ins und Outs nutzen. Soviel ich noch weiß 8 In- und 10 Outputs. Gruppen habe ich noch nicht rausgeroutet, müsste aber auch gehen.
ich scheitere nach wie vor sounds raus- oder reinzubekommen. wenn du mir in kurzen schritten erklären würdest was du eingestellt hast wäre ich dir sehr dankbar.
Ich habe keine Ahnung, was du falsch gemacht hast, denn so wie du es beschreibst, funktioniert es bei mir: „Settings-Audio-Interface“ und M12 einstellen. Dann kann man in den Channels/Macros für Sound, Group und Master seine Ausgänge mit ext1-16 routen.
Vielleicht fehlt dir ein Update der M12?
Vielleicht stimmen ja auch Einstellungen bei deiner M12 nicht? „USB Audio„ auf „Multi“ stellen usw. Kanäle der M12 für PC freischalten per Schalter usw.
Was bringt das Teil, wenn man Logic und Komplete 13 hat ? Es sieht aus, als würde man sich nur eine weitere Fussfessel ans Bein hängen statt dawless Workflow ? Die Frage ist ernstgemeint, ich habe gestern geordert, aber nach Recherchen fehlt mir heute die Begeisterung
Wenn du etwas von einer Firma kaufst, egal ob NI, Akai oder wer auch immer, hat man im Prinzip immer Fußfessel angelegt weil man ja nacht den Vorstellungen der Firma arbeiten muss...
Aber zu deiner Feststellung, ja, du bist im Prinzip an NI gebunden, keine Frage, alle Plugins sind noch nicht in der Maschine, das macht aber nichts, wie ich finde, solltest du mit der Software auf dem Rechner auch arbeiten und bist daran gewöhnt, kannst du das genauso jetzt in der M+ machen, ich find's bisher ganz cool obwohl ich natürlich auch Logic und alles möglichen kram habe...
Frank
es fehlte mir tatsächlich eins das am 15.12 rauskam aber das fixte das prob auch nicht - trotzdem valider punkt
usb audio stand auf multi und die kanäle auf pc - letztendlich habe ich dann das prob per hinweis der anleitung gefunden - ich habe doch oben gepostet wenn ich das m12 anschliesse kommt die fehlermeldung "usb fs mismatch" bedeutet abstastraten stimmen nicht überein zw. interface und m+ - es war also die abtastrate des songfiles was aufgerufen war. nur wenn 44khz & 24bit ausgewählt ist bei der erstellung geht es.
trotzdem danke für deine unterstützung scaramouche, ohne deinen hinweis das du es nutzt & deine posts hätte ich es gar nicht weiter probiert.
jetzt bin ich happy und baff wie flawless das läuft ...
Frank
Danke, und was macht das Arbeiten mit Maschine+ besser als nur mit Logic? Ich meinte Fussfessel eher im Sinne Umweg oder wie bekomme ich meine Resultate von Maschine in Logic?
Für mich war der Grund die M+ zu kaufen der, das ich einfach mal vom Rechner weg wollte, meine Idee war für mich einfach einen Synth zu nehmen und damit zu spielen, Sounds basteln, Phrasen oder was auch immer und diese dann direkt in die M+ zu sampeln... Einfach mal wieder etwas kreatives machen anstatt den ganzen Tag Sounds zu schrauben....
Auch deswegen habe ich mir vor Monaten schon den Polyend Tracker vorab bestellt, genau aus dem selben Grund, kreativ zu sein/werden. Natürlich kann man das alles in der DAW machen, sicher genauso schnell oder sogar schneller, ohne auf CPU zu achten oder was auch immer... Aber wenn man eh schon den ganzen Tag vor der Kiste sounds schraubt, muss man irgendwann auch mal davon weg. Is für mich so wie andere sich ans Piano setzen!
Einfach gesagt: Rechner, Logic und Co ist "job", alles andere ist Spaß haben!
Aber wo wir gerade von Expansions reden, ich hatte mal meine eigene angefangen und dachte, schiebst die mal in die M+ was nicht zu gehen scheint, das ist jetzt schon mal der erste Kritikpunkt von mir, das würde mich jetzt traurig machen wenn ich "meine" eigenen Gruppen/Samples etc. da nicht aus der Software rüber schieben kann, es gibt ein USER CONTENT Ordner aber da sehe ich zwar die ganzen Projekt von mir aber wenn man eines einlädt, gibt es eine Fehlermeldung (missing samples)... Das ist blöde! Hm.. :sad:
Frank
Sorry, hatte ich vergessen zu beantworten, es gibt verschiedene Möglichkeiten seine Projekt zu exportieren. entweder als ganzen Song oder als "stems", diese kannst ja ohne Probleme als WAV in die Logic einladen.
Aus der Anleitung:
7.2.6. Exporting Audio
Use Export Audio to export your complete arrangement as audio from the Song view, or render individual Scenes or Sections as audio files in from the Ideas view.
Export Audio is available from the File page.
• In Ideas view, it is used to export individual Scenes, or all Scenes at once.
• In Song view, it is used to export your complete arrangement or individual Sections of the arrangement depending on the Loop range.
The exact length of the exported audio file depends on the Loop Optimize setting (see description below). Export Audio also contains options that allow you to select the source you want to export such as the Master, Groups, or Sounds.
To export Ideas or a Song as audio:
1. Enter Ideas or Song mode by pressing IDEAS, then SHIFT.
→ This will determine if you are able to export ideas or your whole song. 2. Set the Loop Range to the region that you want to export.
Die M+ ist eben so wie für mich die Elektron Kisten, ich glaube, man findet sie gut oder nicht, viele Feiern den Sequencer von den Elektrons und ich komm damit nicht so wirklich zurecht und habe bisher alle gekauft schnell wieder abgegeben, so wird es auch mit der M+ sein, man mag die Idee dahinter oder nicht, letztendlich kann man sie ja trotzdem auch noch als Controller benutzen, zwar dafür ein wenig zu teuer aber besser als nichts...
Status
