Dirtywave M8 Tracker
Trash80gestern um 23:54 Uhr​
Version 6.0.0 Released.@M8s Firmware Update instructions have not changed.
Read the readme.txt file if you need instructions.
Current M8 Firmware:
https://github.com/DirtyWave/M8Firmware/raw/main/M8Firmware.zip
Headless Teensy 4.1 Firmware: (Updated for version 6.0.0)
https://github.com/DirtyWave/M8HeadlessFirmware
User manual has been updated as well - https://dirtywave.com/support
Thank you @Beta tester for testing. If you are running a beta version be sure to update!
Full changelog can be read here:
https://github.com/Dirtywave/M8Firmware/blob/main/changelog.txt
2025-05-01 - Version 6.0.0
- New: Various settings have been moved to new System Settings view accessible from the project view
- New: System Settings - Count-in metronome options for when recording audio
- New: System Settings - USB Audio input/output routing
- New: Song View - Rearrange tracks - Double tap [Up] on song row 00 to select a track, [Edit]+[Left or Right] to reorder selected track
- New: Sampler - PLAY:REPITCH modes to lock sample length to song tempo
- New: Sample Editor - Reverse and Invert processes added
- New: Theme colors can now be adjusted by HSV values. A global hue adjust has been added to the top by editing "<>"
- New: Post-filter LIMIT/CLIP distortion mode added: W3
- New: Soft clipping mode - Activated on the limiter/main mix scope view
- New: SNC (Oscillator Phase position) fx command added to Wavsynth
- New: Novation Launchpad MK3 note mode, sequencer mode, beat repeat
- New: NXT fx command - Triggers specified instrument on the adjacent track to the right
- New: ERR fx command - Randomizes pitch and other parameters by specified amount. Available for Wavsynth, Macrosynth, Sampler, and FMSynth.
- New: Table Tick mode - Octave map. Map table position to octave (TIC:FC)
- New: Table Tick mode - Velocity map. Map table position to velocity (TIC:FD)
- New: Added ALLPASS filter mode to EQs
- New: Phrase - Instrument pool popup is now only activated with EDIT+DOWN on instrument 00
- Improved: Model:02 minor battery percentage readout and battery life improvements
- Improved: USB Audio - Fixed audio dropouts when performing certain intensive tasks (rendering etc)
- Improved: Retrig of same instruments no longer resets oscillator to "random" position. Clickless retrig
- Improved: MIDI recording now allows legato and places note-offs next to the recorded notes
- Improved: On-screen keyboard character selection - Selectable ABCD/QWERTY mode
- Fix: Fmsynth - IMP OSC antialiasing was not working correctly
- Fix: Wavsynth - Small "SIZE" settings did not produce base shapes correctly
- Fix: Sampler - “OSC” playback mode was not working correctly
- Fix: Sampler - Short loop point samples might not loop correctly when interpolation was enabled
- Fix: Theme - Changing colors associated to the trig blocks on the info area did not use new colors unless reset
- Fix: Internal MIDI mode could cause hard-crash if the MIDIOut instrument was trigged by the track MIDI channel settings
- Fix: Theme color same as background issue
- Fix: "OFF" notes would not stop RET (retrigger) FX command
- Fix: Table & Aux table TIC FF improvements when triggered by phrase FX commands
- Fix: Long song name (all 12 characters) could not create bundles
Wahnsinn, was Dirtywave hier abliefert. Ich komme kaum mit dem Nachlernen hinterher :cool:
(Das ist was Gutes. Ich habe keine Zeit für GAS... Naja.... Jetzt will ich ein Novation Launchpad MK3).
Freue mich richtig darauf, mit dem M8 auf der Terasse und in den Ferien "rumzuspielen". Genau das Richtige für chilligen Jungle/DnB
Mal eine Frage: Funktioniert der M8 mit dem Launchpad Mini anstatt dem Novation Launchpad MK3?
Es geht mir um die Reisetauglichkeit und den Platzbedarf.
Leider wieder "SOLD OUT".... Zu spät zu sein, ist kein gutes Gefühl...
Das ist normal, da die Geräte von einer Einzelperson in kleinen Mengen produziert, verpackt und verschickt werden.
Es gibt meines Wissens eine Warteliste und einen Discord-Channel, wo es Infos über neue Geräte gibt.
Der Entwickler schafft als Einzelperson nur kleine Menge zu prodzieren und zu verschicken.
Als stolzer Besitzer kann ich nur sagen das Warten und der Kauf lohnt sich zu 100%, wenn man an so etwas Spaß hat.
Von Discord:
mikey30319.05.25, 16:42​
MODEL:02 PREORDER INFO,​
When will the MODEL:02 be available for preorder again?,​
  • It is expected that each M8 MODEL:02 batch will be open for preorder approximately every six weeks in 2025 given parts availability. The upcoming batch date is yet to be announced as of May 19th.,
How can I keep up to date with information regarding the next preorder batch?,​
    1. Subscribing to the email list via https://dirtywave.com/ (at the very bottom of the web page),
    1. Following the
📣announcements and
    1. 🕖preorder-info channels for updates.,
When will the current MODEL:02 preorders ship? [2025],​
  • The first batch preorders that were placed in January are expected to ship in February.,
  • The second batch preorders that were placed in February are expected to ship in April.,
  • The third batch preorders that were placed in May are expected to ship Mid-June
Also bei mir hat es mit der Preorder über die Webseite geklappt und Trash80 (der Entwickler) ist vertrauenswürdig.
Mir war es zwar auch etwas mulmig vorher einen Batzen zu überweisen und dann ein paar Monate zu warten.
Aber das ist normal: Man bezahlt vorab. Sobald genügend Bestellungen vorliegen wird ein Batch in Kleinserie speziell produziert (in China?) und dann (in USA?) verpackt und verschickt (nach Europa). Klar, dass das mehrere Monate dauert.
Und verständlich das der einzelne Entickler nicht alle Gerät im Vorfeld finanzieren kann. Das Risiko ist für eine Privatperson viel zu hoch.
Wie gesagt bei mir hat es geklappt und ich bin 100% zufrieden. Das Gerät ist halt kein Gerät von der Stange von einem anonymen Megakonzern.
Man merkt bei jedem der zahlreichen Updates und bei den Meetups (s. Youtube), dass der M8 ist ein Liebhaberprojekt aus Leidenschaft ist.
Ich habe zwar viel Musikspielzeug, dass deutlich teurer ist. Aber am M8 hängt mein Herz ganz besonders, gerade weil es ein spezielles Gerät aus einer Kleinserie ist.
Wer Infos über Bestellung haben will s. WEbseite: https://dirtywave.com/products/m8-tracker-model-02
Trash8016:43​
Version 6.0.2 Released - More less obscure bugs!
:stickbugged:
@M8s Firmware Update instructions have not changed. Read the readme.txt file if you need instructions.
Current M8 Firmware:https://github.com/DirtyWave/M8Firmware/raw/main/M8Firmware.zip
Headless Teensy 4.1 Firmware: (Updated for version 6.0.2)https://github.com/DirtyWave/M8HeadlessFirmware
Full changelog can be read here:https://github.com/Dirtywave/M8Firmware/blob/main/changelog.txt
Aus der aktuellen Charge kann immer noch bestellt werden. Früher war die immer nach spätestens zwei Stunden oder so ausverkauft. Sommerloch? Marktsättigung? Zölle?
Meiner ist auch einen Tag früher angekommen, allerdings für 151.- tax
Eine Frage bezüglich Anschluss habe ich. Ich wäre gerne über usb in den digitakt 2 gegangen, welcher aber belegt ist mit overbridge Anbindung. Kann man da einen Hub dazwischen hängen das beides geht?
uh yeah !
"mikey303
Howdy @M8s, please join us this weekend, Saturday, August 30th @ 3:00 PM PDT for our Beta Firmware Party as we show off some new additions to the upcoming firmware! That is Sonntag, 31. August 2025 um 00:00 in YOUR LOCAL TIME ZONE.
No song submissions this time. Please RSVP below!!!"
Update!
2025-09-30 - Version 6.2.0 Beta 1
- New: OTT (Over The Top) multiband compression effect added to main mix and sample editor process effect
- New: Chorus replaced with ModFX - Can set the ModFx type/mode to Chorus, Phaser, or Flanger
- New: Reverb - Shimmer parameter added
- New: Song Backups - When a song is overwritten, the previous version is saved in [path]/Backup/[song name]
- Improved: Phrase & Table - Cut/Copy/Paste selection (FX commands/values) between Phrase and Table
- Fix: Render - Song render directory was clipped to 3 characters
- Fix: Live mode playback - Issue when triggering multiple tracks of different chain lengths
- Fix: TBX (Aux table) - When CHA (Chance left) trigged on N or V columns, it could stay active longer than expected
- Fix: TBX (Aux table) - TIC00 would cause first table FX command to happen twice
- Fix: Table - Velocity map tic mode did not map correctly with MIDI
- Fix: FmSynth - Special CLK OP shape as modulator could reset OPs not assigned to it
Btw. Kann der thread hier nicht mal in "groovebox" verschoben werden? Ich finde die Größe als Kategorie umabhängig von den eigentlichen Features ziemlich strange...
Diese Diskussion hatten wir schon mehrfach. Auf meine Frage, unter welchen Maßen etwas als "mini" gilt, gab es keine zufriedenstellende Antwort.
Fakt ist, der M8 ist eine kleine Groovebox und viel mehr als ein Minisynth. Eine Rubrik "Kompaktgear" oder "Mobilzeugs" wäre sicher treffender als "Minisynths". Weil nicht alles, was mini ist, muss ein Synth sein. Die Frage, ab wann etwas mini ist, bleibt allerdings auch dann offen ;-). Davon abgesehen werden kleine, aber dadurch nicht weniger leistungsstarke Geräte durch diese Form der Kategorisierung schnell in die Spielzeugecke abgedrängt. Was sie aber nicht sind.
Und vor allem, bis wann ist etwas Mini, oder dann normal, Micro, tiny...warum gibt es keine Kategorie "Riesen-Synths"...?
