Dirtywave M8 Tracker
Trash80gestern um 23:54 Uhr​
Version 6.0.0 Released.@M8s Firmware Update instructions have not changed.
Read the readme.txt file if you need instructions.
Current M8 Firmware:
https://github.com/DirtyWave/M8Firmware/raw/main/M8Firmware.zip
Headless Teensy 4.1 Firmware: (Updated for version 6.0.0)
https://github.com/DirtyWave/M8HeadlessFirmware
User manual has been updated as well - https://dirtywave.com/support
Thank you @Beta tester for testing. If you are running a beta version be sure to update!
Full changelog can be read here:
https://github.com/Dirtywave/M8Firmware/blob/main/changelog.txt
2025-05-01 - Version 6.0.0
- New: Various settings have been moved to new System Settings view accessible from the project view
- New: System Settings - Count-in metronome options for when recording audio
- New: System Settings - USB Audio input/output routing
- New: Song View - Rearrange tracks - Double tap [Up] on song row 00 to select a track, [Edit]+[Left or Right] to reorder selected track
- New: Sampler - PLAY:REPITCH modes to lock sample length to song tempo
- New: Sample Editor - Reverse and Invert processes added
- New: Theme colors can now be adjusted by HSV values. A global hue adjust has been added to the top by editing "<>"
- New: Post-filter LIMIT/CLIP distortion mode added: W3
- New: Soft clipping mode - Activated on the limiter/main mix scope view
- New: SNC (Oscillator Phase position) fx command added to Wavsynth
- New: Novation Launchpad MK3 note mode, sequencer mode, beat repeat
- New: NXT fx command - Triggers specified instrument on the adjacent track to the right
- New: ERR fx command - Randomizes pitch and other parameters by specified amount. Available for Wavsynth, Macrosynth, Sampler, and FMSynth.
- New: Table Tick mode - Octave map. Map table position to octave (TIC:FC)
- New: Table Tick mode - Velocity map. Map table position to velocity (TIC:FD)
- New: Added ALLPASS filter mode to EQs
- New: Phrase - Instrument pool popup is now only activated with EDIT+DOWN on instrument 00
- Improved: Model:02 minor battery percentage readout and battery life improvements
- Improved: USB Audio - Fixed audio dropouts when performing certain intensive tasks (rendering etc)
- Improved: Retrig of same instruments no longer resets oscillator to "random" position. Clickless retrig
- Improved: MIDI recording now allows legato and places note-offs next to the recorded notes
- Improved: On-screen keyboard character selection - Selectable ABCD/QWERTY mode
- Fix: Fmsynth - IMP OSC antialiasing was not working correctly
- Fix: Wavsynth - Small "SIZE" settings did not produce base shapes correctly
- Fix: Sampler - “OSC” playback mode was not working correctly
- Fix: Sampler - Short loop point samples might not loop correctly when interpolation was enabled
- Fix: Theme - Changing colors associated to the trig blocks on the info area did not use new colors unless reset
- Fix: Internal MIDI mode could cause hard-crash if the MIDIOut instrument was trigged by the track MIDI channel settings
- Fix: Theme color same as background issue
- Fix: "OFF" notes would not stop RET (retrigger) FX command
- Fix: Table & Aux table TIC FF improvements when triggered by phrase FX commands
- Fix: Long song name (all 12 characters) could not create bundles
Wahnsinn, was Dirtywave hier abliefert. Ich komme kaum mit dem Nachlernen hinterher :cool:
(Das ist was Gutes. Ich habe keine Zeit für GAS... Naja.... Jetzt will ich ein Novation Launchpad MK3).
Freue mich richtig darauf, mit dem M8 auf der Terasse und in den Ferien "rumzuspielen". Genau das Richtige für chilligen Jungle/DnB
Mal eine Frage: Funktioniert der M8 mit dem Launchpad Mini anstatt dem Novation Launchpad MK3?
Es geht mir um die Reisetauglichkeit und den Platzbedarf.
Leider wieder "SOLD OUT".... Zu spät zu sein, ist kein gutes Gefühl...
Das ist normal, da die Geräte von einer Einzelperson in kleinen Mengen produziert, verpackt und verschickt werden.
Es gibt meines Wissens eine Warteliste und einen Discord-Channel, wo es Infos über neue Geräte gibt.
Der Entwickler schafft als Einzelperson nur kleine Menge zu prodzieren und zu verschicken.
Als stolzer Besitzer kann ich nur sagen das Warten und der Kauf lohnt sich zu 100%, wenn man an so etwas Spaß hat.
