Cubase 13 Leak + Release am 02.11.2023
ganje
Benutzerdefiniert
Edit: Hier enden die Spekulationen:
Jetzt ist Cubase 13 offiziell verfügbar: https://www.steinberg.net/cubase/
Hier der Ursprungsthread:
Da gab es wohl einen Shop, der die Artikelseite vorzeitig veröffentlichte, wodurch Folgendes entnommen wurde (kopiert von Gearslutz):
WHAT’S NEW IN 13?
CHANNEL TAB
Mix on the go
The new channel tab in the Project window gives you direct access to your mix, without leaving the arrangement.
The new design means you can intuitively find what you need, letting you mix on the go in a compact, per channel view.
(PRO-ARTIST-ELEMENTS)
MIXCONSOLE
Slick, streamlined, focused
The MixConsole has been given a fresh overhaul with a slick, streamlined design to help you focus on your mix.
RANGE TOOL
Increase your range
The Range tool is one of the most powerful tools in Cubase and it’s now available in the Key Editor as well as the Drum Editor.
EDITOR
A new editor experience
Edit multiple parts from within the Key Editor and Drum Editor, switch between tracks with the Visibility tab and maintain an overview with the new Track display
(PRO)
VOCAL PRODUCTION
The ultimate vocal chain
Vocal processing is an art of its own, taking a lot of expertise and experience to master the different processing steps. The VocalChain plug-in provides dedicated modules for each step, helping to turn your recordings into professional-sounding vocal tracks.
(PRO-ARTIST)
CHORD PADS
Progress your progressions
The new chord pads make it easy to find creative chord progressions. New presets give you excellent starting points and enhanced functions make it even simpler to create unique music.
ORCHESTRAL LIBRARΥ
Sketch out your scores
Iconica Sketch allows everyone from beginners to professional composers to create full orchestral scores of the highest quality with 140 articulations for 34 instruments in a compact 5GB library.
SAMPLER TRACK
Τweak it
The Sampler Track is even more creative, thanks to stunning new Spectral Warp modes for extreme manipulation and powerful envelope creation.
VOCODER
Τhe return of a legend
Create classic robotic vocals or add analog flavor to your instruments with the legendary Steinberg Vocoder. Use up to 24 filter bands, sidechain input, and enjoy in-depth control over the sound.
(PRO-ARTIST)
COMPRESSION
Compression with character
Black Valve is a classic tube compressor with lots of warmth and character. Its sonic detail makes this tribute to one of the most iconic studio processors really stand out
(PRO)
EQUALIZER
Add class with frequency
Two new equalizers, the EQ-P1A and the EQ-M5, add a classy sound to your productions.
(PRO-ARTIST)
COMPRESSION
Be a vocal specialist
The new VoxComp is a compressor specifically designed for vocals, gently taming your recordings without compromising clarity, transients, or expression.
(PRO)
SAMPLE PACKS
Creative starting points
Be inspired by five exclusive new sample packs by Grammy-winning producer Beat Butcha, creative mastermind Sharooz, and acclaimed sample boutiques 91Vocals and Touch Loops.
STEP & MIDI INPUT - The Step and MIDI Input features are now more even powerful. Modify note lengths on the fly and add voices on top with the new polyphonic note input feature.
KEY EDITOR - MIDI CCs can now be recorded in simplified ramps to make it quicker and easier for editing the controller events afterward
TRACK VERSIONS FOR VIDEO - Working with new video edits is now more convenient with new Track Versions for the VideoTrack.
START MODES - Do you want to start from the cycle marker, the last position or your selection? Configure where playback starts to precisely match your workflow.
TRANSPORT BAR - Easily adjust the project tempo to the beat with the new Tap Tempo feature in the Transport Bar.
CHANNEL CONFIGURATION - Change the channel type from mono to stereo or vice versa with just one click
VERTICAL ZOOM - Zoom in and out vertically with the mouse wheel and decide whether you want to zoom to transport or selection.
KEY COMMANDS - The new Key Command dialog makes managing your short cuts quick and easy. Find commands easier with the dynamic filter and try new macros on the fly.The new Key Command dialog makes managing your short cuts quick and easy. Find commands easier with the dynamic filter and try new macros on the fly.
IMPORT TRACKS FROM PROJECTS - There are several new options that give you more flexibility and control when importing tracks, events, and time ranges.
MIDI PLUG-INS - MIDI plug-ins have had a design overhaul with a fresh new look
MIDI 2.0 - With support for high resolution velocity, CC, aftertouch, pitch bend, and poly pressure data, Cubase 13 is ready for the widespread adoption of MIDI 2.0.
ROUTING - You can now set instrument tracks/racks/sampler return channels as inputs for audio tracks, as well as FX and group channels.
DEMO PROJECTS - Explore three new excellent showcase demo projects, including productions by Austin Hull and Azodi.
WINDOW MANAGEMENT - Cubase now features Windows-compliant multi-window handling.
VIDEO ENGINE - The Windows video engine has been improved, including GPU hardware decoding for H264 and better overall performance
FEATURE Cubase Pro 13 Cubase Artist 13 Cubase Artist 13
Number of audio/MIDI/Instrument tracks Unlimited Unlimited 48/64/24
Physical inputs and outputs 256 32 24
Group channels 256 32 16
FX inserts/send/return channels 16 / 8 / 64 16/ 8 / 64 8 / 8 / 8
Number of included Audio effect plug-ins 87 65 45
Included VST instruments Groove Agent SE, HALion Sonic, Sampler Track, Iconica Sketch, Flux, Retrologue, Padshop, Verve, Trip Groove Agent SE, HALion Sonic, Sampler Track, Iconica Sketch, Flux, Retrologue, Padshop, Verve, Trip Groove Agent SE, HALion Sonic, Sampler Track, Iconica Sketch, Flux
Number of included instrument sounds > 3,000 >2,600 >1,000
Sample and Loop Packs 18 (> 20Gb) 18 (> 20Gb) 18 (> 20Gb)
External instruments / effects Yes (Yamaha Motif only) (Yamaha Motif only)
Scoring and notation Full Basic Basic
Chord track & Chord Pads Yes Yes Yes
Advanced comping Yes Yes -
Phase-coherent multi-track AudioWarp Yes Yes -
VariAudio pitch correction Yes Yes -
TrackVersions Yes Yes -
Advanced Audio Export Yes - -
Audio Alignment Yes - -
Control Room monitoring environment Yes - -
Dolby Atmos for music Yes - -
SYSTEM REQUIREMENTS
Operating systems (Windows) 64-bit Windows 11 (version 22H2 or higher) and 64-bit Windows 10 (version 22H2 or higher)
Operating systems (Mac) macOS Ventura and macOS Monterey
Apple silicon-based Mac Native App and Rosetta 2 App
CPU minimum (Windows) Intel® Core™ i5 (4th Generation) or AMD Ryzen™
CPU minimum (Mac) Intel® Core™ i5 (late 2015 or later) or Apple silicon
CPU cores 4 or more
RAM minimum 8 GB
Hard disk free space (full installation) 75 GB (55 GB for Elements, AI and LE)
Display resolution minimum 1440 x 900 (at 100% UI scaling)
Graphics minimum (Windows) Graphics card with native Windows 10 support (Microsoft Basic Display Driver is not recommended)
Graphics recommended (Windows) AMD R or RX series and later or NVIDIA Series 700 and later
Graphics (Mac) Graphics card with Metal support
Graphics (GPU memory) 4 GB or higher for 4k displays
OS compatible audio hardware. ASIO-compatible audio hardware is recommended for low-latency performance.
An internet connection is required for activation, account setup and personal/product registration. A download is required for the installation.
Note: This software version does not support 32-bit plug-ins. VST 2 plug-ins only run in Rosetta 2 mode on Apple silicon-based Mac computers.
Cubase does not support VST 2 when running natively on Apple silicon Macs
M.i.a.u.: intercorni
IKlingt ganz gut, würde updaten.... ich dachte es kommt am Mittwoch....oder nächsten Mittwoch? Oder den darauffolgenden Mittwoch
WAS? Immer noch keine eingebaute KI, die auf Knopfdruck den ultimativen Nr. 1 Welthit raushaut? :mrgreen:
Wenn das so kommt, wäre es in der Tat ein schönes Major Release.
Bin mal gespannt, ob die jetzt endlich das Apple Trackpad unterstüzen, oder weiter -wohl aus reiner Gehässigkeit- nicht .
M.i.a.u.: notreallydubstep
Die Veröffentlichung verzögert sich, wahrscheinlich, weil Asknet Insolvenz angemeldet hat.
M.i.a.u.: ganje
Ob es wohl nochmals einen Sale gibt um von Cuabse 11 auf 12 upzudaten? Schon zweimal verpasst...
Dieser seitliche Mixer im letzten Bild ist jetzt nicht so die riesen Innovation ;-) - gibt es ja ähnlich schon immer und in der unteren Zone hat man ja auch schnell Zugriff darauf etc. Naja
M.i.a.u.: Paradiddle
Da ich mit dem Mixer in der unteren Zone nie viel Anfangen konnte, finde ich das für flottes Gain Staging ganz nett.
Steinberg lässt sich echt viel Zeit. Ähnlich wie bei Bugs oder Serviceanfragen 🥊🥊🥊.
Ah ... Nein, ich bin ja eigentlich zufrieden und läuft rund bei mir. Aber schon seltsam.
@Zaphod Bei mir hat sich die untere Zone fest im Workflow integriert. Sowohl für Edit als auch Mixer. Nutze beides nur noch so.
Ich bin seit 1,5 Jahren hochzufrieden mit Studio One unterwegs. Hab zwar Cubase 12 noch drauf, aber nur für alte Projekte nochmal zu laden. Hab ich letztens gemacht. Och Gott wie grausam schlecht Cubase doch im Vergleich zu Studio One doch ist. Nie im Leben steig ich da nochmal um.
Studio One ist wie man sich Cubase wünscht und nie bekommen wird.
Wer gerne Studio One nutzen möchte, aber am Anfang mit dem Umstieg nicht so klar kommt und keine Lust hat dich einzufuchsen, dem kann ich es gerne per Videochat in kurzer Zeit zeigen ohne Stress und was da so alles besser ist.
Alles was ich mir in Cubase immer wünschte und nie kommen wird und all die Workarounds ist in Studio One da und normal. Auch die Rechnerauslastung hat in Studio One eine höhere Grenze.
Wer will einfach mich anschreiben.
All die mit Cubase glücklich sind find ich super. Ich hatte es seit SX3 genutzt und wurde immer ausgebremst.
Was genau hilft dir in Studio One? Was ist genau besser? Damit ich mir das irgendwie vorstellen kann, ob sich das lohnt. Im Prinzip habe ich wenig Kritikpunkte an Cubase, aber wenns noch besser geht, warum nicht.
Das müsste ich dir zeigen.
Aber hier ein paar Kleinigkeiten.
- Alles Drag & Drop
- Splitter Mode in jedem Kanal um den Sound separat frequenzgeteilt Plugins zu nutzen.
- Analoge Hardwaresynths wie Plugins nutzen. Keine Midi und Audio Spur. 1 Spur kann alles. Einmal angelegt ist der Analogsynth ein Plugin. Reinziehen und los gehts.
- Einzigartiger Rhytmusanalyzer den nur Studio One bei Audiospuren hat. Groovet bei manchen Instrumenten besser.
- CPU Auslastung besser als bei Cubase
- Extra Mastering Mode
- Übersichtlicher
- Multitool. Schneiden, verschieben und Klick in einem ohne umschalten zu müssen.
Und vieles mehr...
Muss ich zeigen...
Dafür klingen Onboardmittel bei astudio One nicht so gut und es ist funktionell zumindest anders. Auch die Behandlung der VST Fenster ist etwas irreführend.
Für mch wars nicht besser - nur anders.
Aber es flutscht besser, wirkt wesentlich flüssiger
Also die VST Fenster sind genial. Man muss es halt verstehen.
Es ist alles besser.
Das versteht man halt erst, wenn man sich mit Studio One so gut auskennt und der Groschen fällt.
Ich hatte es 1 Monat intensiv gelernt und mich reingefuchst. Alleine in diesem Monat sind mir die Schuppen von den Aufen gefallen wieviel genialer und besser es ist als Cubase. Jetzt nutze ich es 1,5 Jahre und kann nur sagen, Studio One ist das moderne Cubase das man sich schon immer wünschte aber nie bekommen wird. Was in Cubase nie ging geht hier und was in Cubase ein Workaround ist, ust hier eine normale ausgereifte Funktion. Es ist auch nicht so kompliziert verschachtelt. Alles Drag und Drop und die selbe Funktionen auch als Shortcut. Alles Direkt oder 1 Ebene entfernt. Nix verschachtelt. Einen solch schnellen Workflow wird es in Cubase nie geben.
Und die CPU Auslastung ist weitaus besser.
Um das zu verstehen muss man halt erst mal tiefer eintauchen. Aber es lohnt sich.
Herzlichen Dank für deine Meinung, bezüglich der Überlegenheit einer anderen DAW.
Bringt dem Thread natürlich nichts und hat ganz wenig mit seiner Intention und den Informationen, die hier Sinn ergeben können, zu tun. Ich lasse mich jetzt auch auf keine Diskussion ein und behalte für mich, dass Cubase z.B. inzwischen auch ein Multitool hat.
M.i.a.u.: Jörg, McModular, Mr.Pink und 2 andere
Das ist nicht meine Meinung, sondern meine realistische Erfahrung. Ich hatte Cubase seit SX3 genutzt und Cubase 12 noch installiert. Aber nur um alte Orojekte zu öffnen. Ich bereuhe es nur nicht früher umgestiegen zu sein.
Jeder Anfang ist schwer.
Aber wenn man Studio One verstanden hat schnallt man erst wie viel genialer es ist.
Cubase auf Steroiden.
Und ich war mal ein echter Cubase Fan.
Aber nie 100% zufrieden.
Jetzt schon.
Mein Leidensdruck ist nicht groß genug für nen Umstieg. Hab mir die anderen Hersteller schon mal angeschaut und getestet, aber wurde nie richtig warm damit.
Habe meinen Workflow und der ist mit mir zusammengewachsen.
Auch bei Adobe komme ich nicht weg. Einzig DaVinci Resolve hat Premiere ersetzt. Aber in Premiere war ich auch nie so richtig drin, dann fällt das leichter.
Wann soll denn Cubase 13 raus kommen?
@Offtopic
Ist doch schön wenn einem andere DAWs besser gefallen, hier sollte es aber um Cubase 13 gehen. Ich bin von Bitwig auf Cubase umgestiegen und hatte auch schon andere DAWs am Start, das bring den Thread hier aber kein Stück weiter. Ist genauso wie wenn einer in einem Plugin Thread was davon erzählt wie toll doch seine Hardware klingt, alles ganz super, nur bringt es ncht viel das zu wissen.
M.i.a.u.: 987654345dhshj, [dunkel] und Deak Ferance
- Alles Drag & Drop
- Übersichtlicher
Und vieles mehr...
Muss ich zeigen...
Nichts für mich persönlich entscheidendes dabei. Aber ich glaube schon, dass Studio One sicherlich einige Vorteile hat. Cubase hat das Problem, sich nicht zu stark verändern zu können, weil die Leute galt XY so gewohnt sind. Das blockiert sicherlich.
Jetzt schon.
Ich bin auch seit Studio One V2 intensiver user. zuzüglich der Hardware. Allerdings kapiere ich deine Intention nicht. Hier geht es um Cubase 13. PUNKT !!!!!
Das ist zuerst einmal offtopic und wahrscheinlich sowas von uninteressant für die user und Leser in diesem Thread.
Mach doch einfach nen Faden auf, indem du Kurse, Tipps und Tricks für S1 anbietest und / oder bereitstellst. Allerdings gibt es diese aber auch auf YT en masse.
In diesem Faden hier, meiner Meinung nach völlig unangebracht.
M.i.a.u.: McModular, [dunkel], 15025 und 5 andere
  • #26
Sorry wenns unangebracht war.
War halt lange Cubase User und weiss wie es ist wenn man immer wieder updatet und nicht merkt, dass es eine bessere Alternative gibt.
Ging eigentlich auch nur an Interessierte die den Schritt wagen möchten, sich aber nicht trauen.
Nun gut.
Wer Interesse hat ich helfe gerne.
Ansinsten bin ich mal weg hier und dem Rest viel Spaß bei der neuen Version.
M.i.a.u.: Deak Ferance und sdvkaeälkjb848
@Offtopic:
Alles gut, ich denke allerdings, die meisten werden selbst auch mal eine andere DAW angetestet haben oder haben schlicht nicht das Bedrüfnis dies zu tun. Ich hatte auch Studio One mal getestet und es war damals schon nicht schlecht, bin trotzdem dann bei Cubase wieder gelandet. Mag sein, dass der Workflow woanders besser ist, für mich haben halt alle Reisen in andere DAWs(Reason, Bitwig, Ableton, Studio One 3.5, Renoise) mich immer wieder zu Cubase zurück kehren lassen, auch wenn ich weiß, dass man Vieles viel besser lösen könnte.
  • #28
Von Cubase 7 bis 10 war Cubase tatsächlich zum wechseln, seit 11 läufts eigtl richtig gut.
Da ist nichts, was ich vermisse, ausser zwei Dinge:
-Anpassungsmöglichkeiten an andere Auflösungen/Monitore (Ableton macht das super!)
- Warum ist der Minisampler immer noch so verkrüppelt? Anstatt den vollends zu integrieren, achtet man lieber darauf, dass er nicht hauseigener Konkurrent wird.
Insb on the fly durchswitchen von Samples innerhalb eines Ordners. Warum geht das nicht?
  • #29
Ich bin ab Cubase 7.5 gewechselt und jetzt bei Cubase 12 wieder zurück und bin mir sicher es werden noch viele Workflow Verbesserungen kommen. Die gucken sich ja oft gegenseitig was ab, wie eben in fast jeder Branche.
