Elektron Analog Rytm - 12 Pad Analog-Filter-Drummachine
Mal eine Frage zu dem SDS Drop Programm für den Mac: Läuft dieses Programm nicht mehr mit der aktuellen OS Version vom Rytm?
Und gibt es mittlerweile schon ein ähnliches Sample-Drag&Drop Programm für Windows?
Eine evtl. etwas seltsame Frage, da ich aktuell Rytm MK II nicht zur Hand hab und nicht mehr weiß, ob das funktioniert.
Und zwar ob ich ein Sample im Sound Browser - anstatt wie üblich mit Yes-Taste - durch das Drücken auf "TRACK LEVEL" Encoder auswählen kann?
Könnte das jemand ausprobieren?
Update auf Firmware 1.70
Euclidean sequencer mode
The Elektron sequencer is getting a new mode. And we can’t wait for you all to get stuck into it.
Euclidean sequencer mode offers a new way to unleash your Elektron superpowers.
Euclidean rhythms come from algorithms that divide ranges of time into equal parts, controlled by three parameters: steps, pulses, and offset.
We have added two Euclidean generators that you can combine to create complex patterns on your sequencer. Giving compositions so much unique adaptability, and so much potential for unexpected fun, all at the twist of a knob.
New machines
There are five new Machines arriving on the Analog Rytm. Bringing it up to a whopping 33.
The new arrivals are HH LAB, a laboratory for the most outrageous of metallic experiments. SY CHIP, a mini celebration that echoes the SidStation, Elektron’s very first machine. BD and SD ACOUSTIC bring a fresh kick and snare to proceedings, with which to erupt to your heart’s content. And finally, there’s SY RAW, a versatile favorite from Syntakt using Rytm waveforms, that can conjure deep bass tones, towering leads, and melodic percussion.
More parameters. More melody.
Four existing machines are getting new parameters to play with.
Square waveform has been added to BD SHARP’s WAV parameter.
A new pitch envelope parameter has been added to BT CLASSIC.
Two new pulse width parameters are available in both CB CLASSIC and CB METALLIC.
With the arrival of new melodic machines and even more parameters, it’s only right that we add refined tuning, hi-res semitones, pad scales, and fold functionality when using the pads in Chromatic mode. And that’s what we’ve done.
Page loop
The newly added Page Loop lets you work continuously with a specific sequencer page. Easily replay the page and take your time to get the sound just right. Or go nuts in a live setting.
Plus lots more
Additionally, we’ve added sound saving from sequencer trigs, random Slew option for LFOs’ RND waveform, customizable record length for sequencer in sampler, advanced parameter lock preview, random pattern name generator, GUI improvements, performance improvements, and plenty more. For a full list of all the new features, improvements, and bug fixes - please check the release notes.
Calibration
Please calibrate your Analog Rytm after upgrading. You will be prompted after rebooting to begin calibration, and this is necessary for certain feature improvements such as tuning to be functioning correctly. Please bear in mind that calibrating can take 2-3 hours.
Overbridge
To use the upgraded Analog Rytm OS with Overbridge, please update Overbridge to 2.7, via the new version released today to accompany the new firmware 1.
Geil,
auf Euclidean Sequencer stehe ich, cool dass sie das nun im Rytm haben.
Bin gespannt wie das funktioniert und werde das Update diese Woche noch testen.
Danke für den Hinweis !
Kompletten Release Notes
Improvements​
Added five new machines: SY CHIP, SY RAW, BD ACOUSTIC, SD ACOUSTIC, and HH LAB.
Added an Euclidean mode for the sequencer.
You can now save a Sound from a specific trig on the sequencer, complete with its sound- and parameter locks applied.
Added the possibility to set a specific number of sequencer steps as record length in the sampler, resulting in loops with the exact length.
Added pad scales and fold functionality for when playing the PADS in CHROMATIC mode.
Implemented functionality that makes it possible to loop selected pattern pages.
Added the square waveform as a parameter value for the WAV parameter in the BD SHARP machine.
The BT CLASSIC machine now has a new PITCH ENVELOPE parameter.
Added two new PULSE WIDTH parameters for the CB CLASSIC and CB METALLIC machines.
Added slew functionality to the RND waveform for the LFOs. When RND is selected for the WAV parameter, the SPH parameter now sets the amount of slew.
[MKII] Added an LED brightness setting parameter in GLOBAL SETTINGS > SYSTEM.
It is now possible to see which PARAMETER PAGES contain parameters with parameter locks. When pressing and holding specific trig in STEP RECORDING mode, the [PARAMETER] keys that contain parameters with locks light up.
Improved oscillator tuning by adding new calibration functionality.
Implemented the possibility of generating a random name from the naming screen when naming a Sound or a pattern.
The NOTE parameter on the TRIG page now shows the note value and the number of semitones in the screen UI.
Improved the naming of the DUAL VCO, IMPULSE, and NOISE GEN machines by adding machine type group naming. The new names are SY DUAL VCO, UT IMPULSE, and UT NOISE.
The sample STA and END parameters are now high resolution. It is also now possible to snap to integers for the STA and END parameters. This, together with now showing true integrers in the display, makes it easier to find the exact start and end points in samples, especially in longer samples such as sample chains.
Added the functionality that when selecting an empty sample slot and then pressing [YES], now opens the +DRIVE sample list.
Improved the screen UI and navigation for the machine selection list and the Sound Manager.
Several analog machines are now scaled in semitones and with high resolution.
It is now possible to also click DATA ENTRY KNOB D to assign a sample from the sample list that is opened when accessing the SMP parameter on the SAMPLE page.
[MKII] Implemented a new LED boot sequence.
Implemented minor improvements of the LED color scheme to better harmonize between different devices of the product line.
Ja das Update hat schon was. Ich dachte mittlerweile auch das dort nur noch altes aufgewärmt wird und gar nichts mehr kommt. Aber das ist schon ein cooles Update für den Rytm. Bin mir auch sicher das der A4 auch das Update + mehr bekommt. Hätte der verdient.
Leider immer noch kein zweiter LFO, aber schon ein sehr cooles Update.
Zumindest gibt es hierzu seitens Elektron ein Statement:
We know an extra LFO was a much-hoped-for feature addition (for all of us!), but unfortunately it is not currently feasible due to hardware limitations. It wasn’t for want of trying, and we’ll keep searching for a solution, but we trust that this OS will bring a ton of fun to all Analog Rytm owners - both MKI and MKII. Enjoy!
/The Elektron Team
Ich mag die Schweden einfach.
Bin mir einigermaßen sicher, das Digitone, A4 und Syntakt ebenfalls zeitnah das Euclidean Feature bekommen werden.
Vielleicht sogar der OT - wenn noch Platz im Flash ist ...
Einiges davon war ja echt überfällig. Bin ich glatt versucht mir die MKII nochmal anzuhören.
Sagt über Elektron was ihr wollt. Aber dass man für die uralte AR Mk1 noch solche Updates bekommt, ist schon bemerkenswert
Klar ist das grundsätzlich löblich. Aber was sollen sie auch sonst updaten? Wirklich was Neues gibts ja seit 10 Jahren nicht mehr. Am ehesten noch den Digitone.
Ich bin jetzt echt getriggert.
Muss ich dann doch endlich ausprobieren. Ein Brüderchen für die x0x.
