Ich denke, es gibt so einige „problematische” Presets.Solche Digital Knackser hatte ich auch beim Orchid, wenn ich an dem Oktaven Rädchen gedreht habe
... oder nicht aufgefallen ist?nur dass die presets das vor dem update ja auch nicht hatten.
## Osmose Firmware v2.1.21 30/04/2025
### DSP
- Includes new EaganMatrix DSP version 10.52
- Fixed: Polyphony problems when transposing Osmose to the lowest and highest octaves
### Presets
- Added: Sound expansion 01 with 80 new presets
- Fixed: Several factory sounds that were transposed by default
### Presets menu
- Feature: Added remove preset function
- Feature: Added remove playlist function
- Fixed: Browsing issues when the same preset was added to a playlist multiple times
### Synth menu
- Improved: Reworked all global fx algorithms for better sound quality
- Feature: Added new "long reverb" algorithm
- Feature: Added new "drive" output stage
### Config menu
- Fixed: Wrong CC assigned to mod slider in "mpe" config preset
### Playing menus
- Feature: Added remove arpeggiator preset function
- Fixed: Notes still stuck in arpeggiator despite hold set to "off"
- Fixed: Arpeggiator issues when transposing octaves during playing
### Other fixes
- Fixed: Corruption of DSP settings upon fast preset changes
- Fixed: Receiving Program Changes causing freeze and reboot
- Fixed: Audio clicks when changing presets and/or the global fx algorithm
## Osmose Firmware v2.0.18 27/11/2024
### Presets menu & Config menu
- Fixed: Press Glide interval not being recalled correctly upon preset loading
### External MIDI Mode
- Fixed: random triggers of low notes when using Press Glide
### Backup
- Fixed: failure of backup procedure
## Osmose Firmware v2.0.15 04/09/2024
### Database
- Improved: Migrated sound presets from the Haken Audio DSP board to the Osmose mainboard, allowing a total of up to 2048 sound presets
- Improved: New sound preset format for reliable, comprehensive backup and transfer of sound presets
### Presets menu
- Feature: Added favorite function
- Feature: Added playlist function
- Improved: Reworked MIDI Bank and Program Change implementation
- Changed: Replaced factory tab with navigation tab
- Feature: Added "bank" filter
- Changed: Removed user tab and integrated user presets as a new user bank in navigation tab
- Feature: Added MPE arpeggiator
- Feature: Added Pressure-weighted Portamento (Press Glide)
- Feature: Added possibility to save custom MIDI configuration presets
### Global Settings
- Feature: Added option to restore last loaded preset upon startup
### Sensors
- Improved/Fixed: Sensors' sanity checks no longer report errors on all sensors when only single sensors are concerned
### Other fixes
- Fixed: Random crash after long operation times
- Fixed: Crash upon frequent preset saving
- Fixed: Crash when using the arpeggiator
- Fixed: Minor display glitches
## Osmose Firmware v1.4.4 28/12/2023
### Keys calibration
- Improved: Key calibration assistant
### Sensors
- Improved/Fixed: Sensors' initialization and sanity checks
### Other fixes
- Fixed: button LEDs not lighting up directly after boot
## Osmose Firmware v1.1.3 20/09/2023
### UI
- Improved: Reduced lag of GUI
- Improved: All sensitivity and playing parameters can be edited while freeze is activated
- Improved: Better description of factory reset process
- Fixed: Broken "restore factory sensitivity" function
- Fixed: Broken bending range after “keys factory reset�
- Feature: Added manual key calibration in calibration tab of global settings
- Improved: Key position detection
- Improved: Balance between left and right bend
### Other fixes
- Fixed: ghost notes
- Fixed: hanging note when changing octave in the middle of a note
- Fixed: pitch help behavior when set to 100%
- Fixed: some bugs on encoders / sliders
- Fixed: MIDI Clock not forwarded despite MIDI Thru active
- Fixed: Wrong icon on "dirt" macro
## Osmose Firmware v1.0.6 13/02/2023
### UI
- Fixed: Tags disappearing in bottom bar when navigating with buttons
- Fixed: Minor issues in preset filtering
- Improved: Behavior of Encoders
- Improved: Information displayed during update procedures
### Sensors
- Improved: Sensors' initialization and sanity checks
- Feature: Allow manual sensor reset from global settings
### Presets
- Fixed: Removed special characters “/� and “*� in user preset names to avoid issues with preset saving
## Osmose Firmware v1.0.3 12/01/2023
### UI
- Improved: display of instructions during dsp update in order to avoid impression of a stuck process.
- Improved: calibration initialization
- Fixed: erratic behavior that occurs sometimes when keys are pressed very lightly and bent to one side
### Other fixes
- Fixed: Wrong behavior when activating freeze in playing menu with no playing option selected
- Fixed: Popups not appearing when Osmose was turned on for a longer time
## Osmose Firmware v1.0.0 22/12/2022
original release
## OsmoseUpdater v2.1.24 30/04/2025
### Compatibility
- Compatible with 2.1 firmwares
### Backup
- Fixed: global settings are excluded from the backup procedure if they are detected as being corrupt, avoiding problems during restoring user data
## OsmoseUpdater v2.1.14 27/11/2024
### Backup
## OsmoseUpdater v2.1.11 04/09/2024
### Database
- Compatible with Osmose firmware 2.x.x
### Backup
- Improved: User data backup now comprises the entire user data: all sound presets and MIDI config presets incl. custom sensitivity and playing options, as well as sensitivity presets and arpeggiator presets of both modes
### Advanced Mode
- Feature: Added possibility to upload future sound banks
## OsmoseUpdater v1.2.2 21/12/2023
### Backup
- Fixed: Failed preset transfer from Osmose to computer on some machines
### Compatibility
- Fixed: Osmose detection issue on some macOS machines
### UI
- Improved: Osmose serial number shown with upper case
### Other fixes
- Improved: information saved in log files
## OsmoseUpdater v1.2.0 24/10/2023
### Notarization
- macOS: added Apple notarization to avoid warning when launching installer
### Compatibility
- Fixed: Osmose detection issue on Japanese macOS systems due to MIDI ports name changing
## OsmoseUpdater v1.1.8 26/05/2023
### Backup
- Improved: Reduced transmitted data to shorten loading time
## OsmoseUpdater v1.1.7 13/02/2023
### Advanced mode
- Feature: added an advanced mode, allowing users to update Osmose step by step
### UI
- Improved: Design of User Interface
- Improved: Accuracy of the progress bar
- Improved: Coherence between OsmoseUpdater and Osmose
- Improved: User presets management
## OsmoseUpdater v1.1.4 12/01/2023
### UI
- Improved: better instructions during update to avoid confusion during the update process
### Compatibility
- Fixed: Osmose connectivity issue due to MIDI ports name changing depending of language
### Other fixes
## OsmoseUpdater v1.1.0 22/12/2022
original release
Und warum postest du das jetzt hier?Changelog:
Code:## Osmose Firmware v2.1.21 30/04/2025 ### DSP - Includes new EaganMatrix DSP version 10.52 - Fixed: Polyphony problems when transposing Osmose to the lowest and highest octaves ### Presets - Added: Sound expansion 01 with 80 new presets - Fixed: Several factory sounds that were transposed by default ### Presets menu - Feature: Added remove preset function - Feature: Added remove playlist function - Fixed: Browsing issues when the same preset was added to a playlist multiple times ### Synth menu - Improved: Reworked all global fx algorithms for better sound quality - Feature: Added new "long reverb" algorithm - Feature: Added new "drive" output stage ### Config menu - Feature: Added remove preset function - Fixed: Wrong CC assigned to mod slider in "mpe" config preset ### Playing menus - Feature: Added remove arpeggiator preset function - Fixed: Notes still stuck in arpeggiator despite hold set to "off" - Fixed: Arpeggiator issues when transposing octaves during playing ### Other fixes - Fixed: Corruption of DSP settings upon fast preset changes - Fixed: Receiving Program Changes causing freeze and reboot - Fixed: Audio clicks when changing presets and/or the global fx algorithm ## Osmose Firmware v2.0.18 27/11/2024 ### Presets menu & Config menu - Fixed: Press Glide interval not being recalled correctly upon preset loading ### External MIDI Mode - Fixed: random triggers of low notes when using Press Glide ### Backup - Fixed: failure of backup procedure ## Osmose Firmware v2.0.15 04/09/2024 ### Database - Improved: Migrated sound presets from the Haken Audio DSP board to the Osmose mainboard, allowing a total of up to 2048 sound presets - Improved: New sound preset format for reliable, comprehensive backup and transfer of sound presets ### Presets menu - Feature: Added favorite function - Feature: Added playlist function - Improved: Reworked MIDI Bank and Program Change implementation - Changed: Replaced factory tab with navigation tab - Feature: Added "bank" filter - Changed: Removed user tab and integrated user presets as a new user bank in navigation tab ### External MIDI Mode - Feature: Added MPE arpeggiator - Feature: Added Pressure-weighted Portamento (Press Glide) - Feature: Added possibility to save custom MIDI configuration presets ### Global Settings - Feature: Added option to restore last loaded preset upon startup ### Sensors - Improved/Fixed: Sensors' sanity checks no longer report errors on all sensors when only single sensors are concerned ### Other fixes - Fixed: Random crash after long operation times - Fixed: Crash upon frequent preset saving - Fixed: Crash when using the arpeggiator - Fixed: Minor display glitches ## Osmose Firmware v1.4.4 28/12/2023 ### Keys calibration - Improved: Key calibration assistant ### Sensors - Improved/Fixed: Sensors' initialization and sanity checks ### Other fixes - Fixed: button LEDs not lighting up directly after boot ## Osmose Firmware v1.1.3 20/09/2023 ### UI - Improved: Reduced lag of GUI - Improved: All sensitivity and playing parameters can be edited while freeze is activated - Improved: Better description of factory reset process - Fixed: Broken "restore factory sensitivity" function ### Keys calibration - Fixed: Broken bending range after “keys factory reset� - Feature: Added manual key calibration in calibration tab of global settings - Improved: Key position detection - Improved: Balance between left and right bend ### Other fixes - Fixed: ghost notes - Fixed: hanging note when changing octave in the middle of a note - Fixed: pitch help behavior when set to 100% - Fixed: some bugs on encoders / sliders - Fixed: MIDI Clock not forwarded despite MIDI Thru active - Fixed: Wrong icon on "dirt" macro ## Osmose Firmware v1.0.6 13/02/2023 ### UI - Fixed: Tags disappearing in bottom bar when navigating with buttons - Fixed: Minor issues in preset filtering - Improved: Behavior of Encoders - Improved: Information displayed during update procedures ### Sensors - Improved: Sensors' initialization and sanity checks - Feature: Allow manual sensor reset from global settings ### Presets - Fixed: Removed special characters “/� and “*� in user preset names to avoid issues with preset saving ## Osmose Firmware v1.0.3 12/01/2023 ### UI - Improved: display of instructions during dsp update in order to avoid impression of a stuck process. ### Keys calibration - Improved: calibration initialization - Fixed: erratic behavior that occurs sometimes when keys are pressed very lightly and bent to one side ### Other fixes - Fixed: Wrong behavior when activating freeze in playing menu with no playing option selected - Fixed: Popups not appearing when Osmose was turned on for a longer time ## Osmose Firmware v1.0.0 22/12/2022 original release --------- ## OsmoseUpdater v2.1.24 30/04/2025 ### Compatibility - Compatible with 2.1 firmwares ### Backup - Fixed: global settings are excluded from the backup procedure if they are detected as being corrupt, avoiding problems during restoring user data ## OsmoseUpdater v2.1.14 27/11/2024 ### Backup - Fixed: failure of backup procedure ## OsmoseUpdater v2.1.11 04/09/2024 ### Database - Compatible with Osmose firmware 2.x.x ### Backup - Improved: User data backup now comprises the entire user data: all sound presets and MIDI config presets incl. custom sensitivity and playing options, as well as sensitivity presets and arpeggiator presets of both modes ### Advanced Mode - Feature: Added possibility to upload future sound banks ## OsmoseUpdater v1.2.2 21/12/2023 ### Backup - Fixed: Failed preset transfer from Osmose to computer on some machines ### Compatibility - Fixed: Osmose detection issue on some macOS machines ### UI - Improved: Osmose serial number shown with upper case ### Other fixes - Improved: information saved in log files ## OsmoseUpdater v1.2.0 24/10/2023 ### Notarization - macOS: added Apple notarization to avoid warning when launching installer ### Compatibility - Fixed: Osmose detection issue on Japanese macOS systems due to MIDI ports name changing ## OsmoseUpdater v1.1.8 26/05/2023 ### Backup - Improved: Reduced transmitted data to shorten loading time ## OsmoseUpdater v1.1.7 13/02/2023 ### Advanced mode - Feature: added an advanced mode, allowing users to update Osmose step by step ### UI - Improved: Design of User Interface - Improved: Accuracy of the progress bar - Improved: Coherence between OsmoseUpdater and Osmose - Improved: User presets management ## OsmoseUpdater v1.1.4 12/01/2023 ### UI - Improved: better instructions during update to avoid confusion during the update process ### Compatibility - Fixed: Osmose connectivity issue due to MIDI ports name changing depending of language ### Other fixes - Improved: information saved in log files ## OsmoseUpdater v1.1.0 22/12/2022 original release
Ich dachte das wäre der Osmose Thread wo ein user berichtete das seit dem aufspielen des 2.er Firmware bei manchen Presets ~knackser auftreten. Da der Osmose seine updates dokumentiert dachte ich es könnte nützlich sein nachzulesen was alles nach und nach ge'updatet wurde um daran zu spekulieren was evtl. eine Ursache des Problems sein könnte.Und warum postest du das jetzt hier?
Verstehe ich nicht, sorry...bin nicht so tief in der MaterieAm Changelog könnte man z.B. erkennen, dass auch der Synthesizer ein Update erhalten hat.
U. a. das könnte Auswirkungen auf die alten Presets haben.- Improved: Reworked all global fx algorithms for better sound quality
Oder das neue nochmal drauf spielen, falls das geht?Test ob es generell von dem update kommt:
Sehr Zeitaufwendig :-( wäre den Osmose mit einer alte Firmware Version, wo das knacksen noch nicht aufgefallen ist, aufzuspielen.
ChatGPT meinte ja
Und ob sie nicht vielleicht ganz woanders auftauchen. Bei mir war es mal ein falsch eingestellter Hardware-Limiter in einer bestimmten Konfiguration. Solltest du den KH direkt am Osmose haben, kann es immer noch der KH sein. Man muss den Fehler schon so eingrenzen, dass wirklich alles andere ausgeschlossen werden kann. Ansonsten sucht sich der Entwickler dumm und dämlich. Und das will er halt ausschließen.Der Support meinte, ich solle erstmal prüfen, ob die Knackser auch über die Line-Ausgänge
Wenn die neuste DSP firmware Version installiert ist nicht zwingend nötig IMHO, laut Osmose_FirmwareUpdateInstructionsFW2.1_EN.pdfOder das neue nochmal drauf spielen, falls das geht?
ChatGPT meinte ja, ich solle den Haken-DSP isoliert flashen. Aber habe jetzt gar kein Update für den Haken-DSP sperat gefunden.
update haken firmware
This operation flashes the Haken DSP Firmware only. It takes about 55 minutes to
complete.
⚠️ Updating the DSP firmware will delete all your sound presets if you are still on an
Osmose firmware with version 1.x. Use the ‘back up user data’ and ‘restore user data’
functions if you wish to keep your sound presets. If you have already updated to a 2.x
firmware, then your presets aren’t stored on the Haken DSP anymore and won’t be
touched during the Haken DSP update.
To launch the update, click “Update Haken Firmware” and choose the
*.osmoseupdate file contained in the zip file you downloaded. When the update is
complete, a message on your Osmose will prompt you to power cycle. Please do as
instructed before launching any other advanced mode action.
Lass es reparieren und lass dir vom Verkäufer die Übernahme etwaiger Reparaturkosten bestätigenDer Expressive E Support hat geantwortet;
Zum Problem selbst: Uns liegen keine spezifischen Fehlermeldungen für „Astral Titans“ oder „Azure Key“ vor. Da das Problem nicht nur diese, sondern mehrere Presets betrifft und auch nach einer erneuten Durchführung des Updates bestehen bleibt, deutet dies eher auf einen DSP-Defekt des Geräts hin als auf ein Problem mit den Presets.Eine CPU- oder DSP-Überlastung kann genau das von Ihnen beschriebene Knistern und die Tonausfälle bei „AlterSaw“ und „aplassian“ verursachen.
Das Gerät muss also repariert werden (CPU- oder DSP Wechsel), zu Expressive eingeschickt werden. Ich checke gerade, ob das der Original Besitzer/Käufer machen muss und ob das noch unter Gerantiefall fällt, die längst abgelaufen ist.
Der Vorbesitzer hat mir schriftlich zugesagt, dass er mir das Geld zurück überweist, wenn ich ihm das Teil zurück sende.
Osmose ist nun bei 2.3.14 und kann mehr.
## Osmose Firmware v2.3.14 - 24/09/2026
### Major changes
- Feature: Added new DAW Control Mode incl. Ctrl-e integration
- Feature: Added new bottom action bar incl. semitone-transposition and playing feature toggle
- Improved: Reworked large parts of the firmware code for better stability
- Improved: Reorganized USB MIDI ports: 1-play, 2-sound engine, 3-din midi interface, 4-daw control, 5-haken
### Sound Engine mode
- Fixed: Lagging replay of Osmose MIDI performances when routed through a DAW/sequencer
- Fixed: Mod Slider values not sent on USB MIDI sound engine port
- Improved: Macros and Global FX parameter changes taken into account bidirectionally on USB MIDI sound engine port
- Fixed: DSP muted when playing notes while receiving program change messages
- Fixed: Type filter in navigation menu resetting when marking a preset as favourite
### External MIDI mode
- Fixed: Poly Aftertouch messages sent for wrong keys when using octave transposition while keys are still pressed
### Sensitivity menu
- Fixed: Activation modes (latest key, highest key etc.) not taken into account or saved properly
### Playing menu
- Fixed: Crash when making extensive use of arpeggiator
- Fixed: Arpeggiator not synching (new quantize parameter in adjust tab)
- Fixed: Swing timing issues when activating ratcheting
- Fixed: External clock BPM value jumping when receiving MIDI CC messages
## Osmose61 Firmware v2.1.23 04/02/2026
### Sensors
Overall stability improvement of the 61 keybed, incl.:
- Fixed: ghost trigger of short block/cluster chord during auto sensor reboots
- Fixed: single keys stopping to work after a while for some users
### Other fixes
- Changed version number to 2.1.x to avoid confusion compared to Osmose 49 firmware feature set
## Osmose61 Firmware v2.0.25 12/11/2025
original release with the same feature set as firmware v2.1.21 for Osmose 49
## OsmoseUpdater v2.3.14 - 24/09/2026
### Compatibility
- Compatible with 2.3 firmwares
### UI
- Shows adapted product image depending on whether Osmose or Osmose CE is connected
## OsmoseUpdater v2.3.4 15/01/2026
first release compatible with Osmose 61
oder rückwärts drehen ;)Ein Wunsch wäre das die Encoder bei schnellen bewegen auch schneller die Werte durchfährt. Der Horror für mich ist wenn ich von z.B. 0 auf 127 will, gefühlte ~4000 Umdrehungen.
eigentlich adressieren sie diverse longstanding Probleme und verbessern die Integration mit anderen Synths. Ich find das sehr begrüßenswert.Also für mich ist da irgendwie nichts dabei. Hauptsächlich auf Software fixiert, die ich dann noch kaufen muss, was ich aber nie machen werde. Nützt mir ein solcher DAW-Steuerungsmodus beim Aufnehmen?
Im letzten Teil wird eine Art Shift Funktion vorgestellt, wo das ohnehin unübersichtliche UI unten noch eine extra Dimension bekommt. Wahnsinn. Welcher Interface-Designer denkt sich sowas aus? Das Gerät ist in erster Linie ein Controller für Live Spielen und sollte einfach zu bedienen sein.
Ich wünschte mir einen viel einfacheren Aufbau der Menüs, wo nicht alle Encoder unten und links, die Taster oben, und nun auch eine Shift Funktion irgendwas bewirken und zum Navigieren nötig sind. Ist beim Ext-MIDI Mode irgendwas anders als vorher? Das ist meine Hauptnutzung. Als First-Adopter bin ich nach wie vor etwas unbefriedigt. Dazu kommt die miese ("unpräzise") Encoder und Tasterhardware, die in meinen Augen wenig professionell rüberkommt und solch teurem Gerät mit tollem, neuartigen Tastaturmechanismus nicht würdig ist.
