Moogulator
Admin
der Italiener kommt zurück - polyphon und analog
>>> DA ISSER: View post <<<
Analog polyphonic synthesizer
AnalogFusion is a top notch, no compromise instrument with 2 completely separated Analog and digital synthesizer engines. You decide wether creating warm analog sounds or pure digital or layer them. Massive features unlocking access to a new world of synthesis possibilities.
Discrete analog circuitry
The polyphonic analog synthesizer engine (6 voices) was developped to provide all the features you can dream off and usually find on prestigious vintage synthesizers. Each voice is composed with 2 oscillators (3 waveforms: Saw, Pulse, Triangle) with Pwm, 3 lfos, hard sync, ring modulation, multimode filter, white and pink noise generators. The Oscillators are detunable. All the analog circuitry is made with discrete components, no FPGA or ASIC.
Analog or digital question is over, Get both!
Additionally to its pure analog synthesis section, AnalogFusion also offers a complete digital synthesis engine capable of doing Virtual Analog (2 oscillators, multimode filter, 2 enveloppes, 3 LFO), FM (6 operators with multimode filter for each voice) or wavetable synthesis. A dedicated drum section is also present with 10 instruments.
Analog/digital layer mode
A layer mode allows to stack the analog and digital synthesizers, a perfect fusion to create incredibly fat sounds!
Complete control
A massive panel with encoders, buttons and all the knobs you want gives you the ultimate control on all the parameters of this amazing instrument. A color LCD with an intuitive interface let you see each and every parameter at a glance.
5 parts pattern sequencer and 3 arpeggiators
A 14 track step sequencer and 3 powerful arpeggiators are integrated. A switch and a knob allow to set the gain or mute each track easily for live sessions. A song mode is also available to assemble your patterns and make a complete song.
FX section with bypass
An FX section (digital) is present providing delay, chorus and distortion. This section was designed to be fully bypassable to allow pure analog output if needed.
Complete and professional connectivity
The presence of USB, MIDI and CV/Gate allows the instrument to be interfaced with the widest range of instruments and devices and become a key part of your DAW. In addition to the MIX and HEADPHONES plugs, separated audio outputs are available for each part of the synth (analog synth, analog bass, digital synth and drums) allowing you to record their raw ouput and apply your own external effects for example.
Developped and manufactured in Italy
AnalogFusion is handcrafted with passion in Italy.
Technical specifications
Polyphonic Analog and Digital, multitimbral synthesizer
CPU:
3 x ARM Cortex processors
Power supply
12v DC external adaptor (included).
Data storage
Internal memory
SDCARD
I/O:
USB 2.0 High speed B connector
6.35mm headphones
2 x 6.35mm Mix output (L & R)
1 x 6.35mm Analog synth ouput
1 x 6.35mm Analog Bass ouput
1 x 6.35mm DAC output
3 x DIN MIDI input, output, thru
3.5mm CV/Gate interface 1V/Octave
1 x 6.35mm Pedal input
Display
3.5″ 320×480 TFT LCD
Firmware
FingerSonic FaderOS AnalogFusion edition V 1.0
Analog Synth Engine
6 x 100% analog voices
2 x oscillators per voice (SAW/Square/PWM/Triangle/Noise)
3 x Hardsync mode and Ring modulation available
3 X lfos (SAW/Square/PWM/Triangle/Random) to modulate pitch, filter and PWM
Multimode filter LP24db/LP12db/BP/HP
Analog Bass Engine
1 x additional pure analog voice dedicated to Bass
1 x oscillator (Saw/Square)
1 x 24db VCF
Digital Synth Engine
6 x digital synth voices configurable as:
Virtual analog or
FM 6 operators or
Wavetable synthesis
10 parts digital drums
Sample rate 44,1Khz
Bit depth 16 bit
Channels: 1 stereo
Sequencer/arpeggiator
Integrated easy to use 14 parts sequencer
3 x arpeggiators
Dimensions
640 X 360 X 100 mm
Complete control
CPU:
Power supply
Data storage
Internal memory
SDCARD
I/O:
6.35mm headphones
Display
Firmware
Analog Synth Engine
Analog Bass Engine
1 x 24db VCF
Virtual analog or
FM 6 operators or
Wavetable synthesis
Sample rate 44,1Khz
Bit depth 16 bit
Channels: 1 stereo
3 x arpeggiators
Dimensions
640 X 360 X 100 mm
