R
Rastkovic
Wenn der Synth den Qualit
Wenn der Synth den Qualitätsstandard der Effekte hält... :)
Spectra by Kjaerhus Audio - Release January 3, 2006
Spectra is a synthesizer plug-in which combines multistage additive synthesis with traditional subtractive synthesis giving you strong sound possibilities ranging from classic synthesizer sounds to re-synthesized instrument sounds and sound morphing. It features a 250 partial additive engine with up to 8 detune-able oscillators per Voice. Up to 100 harmonies can be made on a timeline for re-synthesis and harmony morphing. An audio analyzer is available to convert wave files into harmonies. The subtractive part includes 12 analog modeled filters with resonance, two of those to self-oscillation. Two LFOs are available for tremolo, vibrato and filter modulations. Five flexible multipoint envelopes with looping and time-stretch capabilities are available to control amplitude, filter cut-off, pitch and modulation level for each of the two LFOs. The effect section features Chorus / Flanger, Delay, Phaser and Reverb. A two bank preset system is available for easy program handling; you can for instance browse through one bank and easily save your favorite sounds to the other bank. There is no latency, which makes this the ideal instrument for real time performance in the studio or on stage.
Key Features
Multistage additive and subtractive synthesis
250 partials additive engine
8 detune-able oscillators per voice
Harmony morphing with looping and time-stretch
Analog modeled filters
Polyphonic portamento
Audio Analyzer
2 LFOs with 12 waveforms, sync and sample / hold
5 multipoint envelopes with looping and time-stretch
Waveform presets
Full pedal implementation
Midi Modulation
Midi Learn
Parameter Automation (VST)
256 Voices
Chorus / Flanger, Delay, Phaser and Reverb effects
Sample accurate processing
2 banks preset system for easy program handling
MIDI range filtering
Transpose
Zero Latency
Key Features
Audio Analyzer
Waveform presets
Midi Modulation
Midi Learn
256 Voices
Transpose
Zero Latency
