KORG SQ-64 Polyphonic Sequencer
Ich kopiere mal von der Webseite hierhin (falls sie wieder offline geht):
The SQ-64 is an incredibly powerful and compact Polyphonic Step Sequencer with amazing hands-on intuitive controls and deep editing options to give you all the flexibility and sequencing power needed for all your musical projects.
With its 64 step pad Matrix, Crystal clear OLED display, sturdy and elegant aluminium body, a wealth of connections and a variety of modes and features, the SQ-64 will become the central piece of your music studio providing total and seamless control over all your instruments so you can focus on what matters most; your music!
Connection you said?
Despite its compact size, the SQ-64 has unparalleled connectivity and will allow you to easily control, connect and make the most of all your analog and digital gear.
MIDI IN (x1) and OUT (x2), micro USB type B, Sync IN & OUT, 3 Melody tracks each with MODULATION, PITCH and GATE outputs and a DRUM track with 8 individual trigger outputs for controlling analog synths, Eurorack, and drum machines.
Each of the Melody tracks (x3) has 16 Patterns of up to 64 steps each, and the Drum track (x1) has 16 Sub-tracks also with up to 64 steps each, that can be played, chained and edited in a variety of ways. Melody tracks and patterns can be edited in several modes (GATE, PITCH and MODULATION) so you can alter the information sent by your sequencer on each of these steps in many interesting ways. The DRUM track outputs can be fine-tuned to match the polarity and voltage of your connected device(s).
Its audio Sync In & Out connections will allow you to seamlessly control all your other Korg gear such as the Volcasynthesizer series, Minilogue, Monologue, Minilogue XD, prologue and many others!
One to rule them all
Whether you are into Analog synths, Eurorack semi-modular synths, Digital drum machines, or do everything on your DAW with digital plugins, the SQ-64 will give you instant and precise hands-on control of each and all of these.
The SQ-64 has 64 beautifully LED-lit Step button pads that not only let you see the whole picture at once, but also allow for super-fast and satisfactory editing with its encoder knobs and dedicated mode buttons that will simplify and speed up your workflow. Each step has graduated lighting; the higher the modulation value, the stronger the button lights up to give you a clear visual on what’s going on in the sequence.
The OLED Display is crystal clear, bright and visible from any angle, so you can have access to all the information you need no matter whether you are making music at home, in the studio or playing live!
The 3 melody tracks include a MODULATION output, so every step on your sequence can be creating complex modulations on your gear of choice, greatly expanding your options and possibilities for sound creation.
It has never been easier to create polyphonic chords patterns, melodies, complex poly-rhythms and modulations on the fly and record them as data on each of the 64 project slots available.
Real-time Control
The SQ-64 won’t just allow you to create incredible sequences; it packs several features and modes that will let you edit on the fly and play any of your gear real-time.
The 64 pad Matrix can be also be used as a Keyboard, allowing for several layouts to be used for maximum flexibility (several scales can be assigned to any of these and a number of other parameters can be easily changed)
Keys: Your traditional piano layout.
Isomorphic: the notes are displayed symmetrically in rows, you can easily transpose the same chord pattern up and down without changing its shape
Octaves: one scale displayed in 3 different octaves on each row
Go deep
With its powerful built-in Arpeggiator you can easily bring to life and create interesting patterns out of any of your soft plugins, analog or digital synths, for immediate inspiration.
Break free with 4 alternative sequence playback modes! Reverse, Bounce, Random, and Stochastic can be selected independently and on the fly to each track to add variety and intrigue.
All your patterns can also be freely chained and looped, making this the ultimate device for machine live!
Sleek, Rugged Design
Despite its wide array of features, controls and connections, the SQ-64 is just 18mm thick (38mm including the knobs and rubber legs) and is housed in a highly portable and elegant yet robust solid aluminum body that will provide years of reliable service.
Powered through USB or external 9V DC adaptor, a choice of power options offer both versatility and flexibility.
Free bundle of music software
The SQ-64 comes with a diverse variety of music software from Izotope including “Ozone Elements” which lets you not only create songs but also master them using AI, “Skoove” which will help you improve your keyboard playing skills, “Reason Lite” DAW software, as well as software synths from KORG and other brands.
In other words, the moment you get your hands on this sequencer you'll have a variety of tools to help you take your music to the next level.
Software for Mac/Windows
KORG Collection - M1 Le (synthesizer sound module)
UVI Digital Synsations (synthesizer sound module)
AAS Ultra Analog Session (synthesizer sound module)
AAS Strum Session (acoustic guitar sound module)
AAS Lounge Lizard Session (electric piano sound module)
Propellerhead Reason Lite (DAW music production software)
Skoove free 3 month trial of Skoove Premium (online piano lesson)
Korg Gadget 2 Le for Mac (DAW music production software)
iZotope Ozone Elements (Audio Mastering Plug-in Software)
Specifications:
Sequencer: 64 step sequencer with 3 melodic tracks with up to 8 note polyphony, and 16 monophonic rhythmic tracks
Tempo: BPM30.0 - 300.0
Inputs: MIDI IN connector (φ3.5mm stereo mini-phone jack, use a type-A MIDI converter cable), SYNC IN jack (φ3.5mm monaural mini-phone jack, 20V maximum
input level)
Outputs: MIDI OUT1, 2 connector (φ3.5mm stereo mini-phone jack, use a type-A MIDI converter cable), SYNC OUT jack (φ3.5mm monaural mini-phone jack, 10V
maximum input level), CV GATE output A/B/C jack (φ3.5mm monaural mini-phone jack, 10V maximum output level), CV PITCH output A/B/C jack (φ3.5mm monaural mini-phone jack, 10V maximum output level), CV MOD output A/B/C jack (φ3.5mm monaural mini-phone jack, 0V maximum output level), TRIG output 1~8 jack (φ3.5mm monaural mini-phone jack, 10V maximum output level)
Power: USB bus power, or DC 9V AC Adapter KA-350, separately sold)
Dimensions: (W x D x H): 368 Å~ 144 Å~ 74 mm / 14.49 Å~ 5.67 Å~ 2.91 inches
*Kommentar: Angström??*
Weight: 1.0 kg / 2.20 lbs
Included items: Owner’s Manual, USB cable
Accessories: (separately sold): KA350 AC Adaptor, Patch cables MS-CABLE-18
M.i.a.u.: molemuc und oldwired
Liest sich gut. Könnte spannend sein. Full Size DIN hätte ich natürlich besser gefunden (und dafür ein paar mm dickeres Gehäuse).
Das Gerät ist weit mehr als nur ein Step-Sequenzer.
M.i.a.u.: Audiohead
Vor allem passt er mit seinen paar Hundert Angström hervorragend in die moderne Nano-Welt. ;-)
Was erste Preis?
M.i.a.u.: Beiträge 800, notreallydubstep, VEB Synthesewerk und eine weitere Person
Ah:
3295 schwedische Kronen = 321,07 Euro
M.i.a.u.: island, verstaerker und Audiohead
Endlich bekommt Arturia mal Konkurrenz in dem Segment!
M.i.a.u.: noir, verstaerker, Audiohead und eine weitere Person
Von den Beschriftungen der rückseitigen Anschlüsse auf dem oberen Teil ,sieht das dem KeystepPro gleich aus.
Wenn das Teil zu NAMM vorgestellt wird,braucht Korg i.d.R. 3 Monate bis zur Erhältlichkeit.
Mit anderen Worten Arturia hat bis April/Mai Zeit ihren verbugten Scherbelhaufen in Ordnung zu bringen, wenn keine Gebrauchtschwemme einsetzen soll.
Das sollte machbar sein.
M.i.a.u.: Sven Blau
klingt spannend! Frage mich ob unterschiedliche Steplängen & Geschwindigkeit pro Track möglich sein wird... das ist am beatstep pro ja lange nicht so gewesen, hat ihn aber dann schließlich massiv aufgewertet mE.
Es gibt einen Polyrhythm Button, rechts unten. :)
M.i.a.u.: verstaerker und Audiohead
Was ich bei den Arturia Teilen vermisse: Accent und Slide. Slide hatte zumindest der SQ-1... bitte Korg geht das?
Ich muss wohl oder übel dran gewöhnen, dass Handys immer größer und Musikgear immer kleiner wird.
M.i.a.u.: Beiträge 800, Summa, Tom Noise und 5 andere
  • #26
Mir doch Schnuppe, ob die da was wegretuschieren oder neue Bilder machen - wir haben ihn gesehen! Pech, Korg! ;)
Der SQ-64 wildert ungeniert im BSP Territorium. Find ich gut :fressen:
Bin gespannt, ob und wann Arturia reagiert, denn der BSP hat seit Mai 2018 kein Update mehr erhalten.
M.i.a.u.: Sven Blau
