Kurzweil Forte
Der Forte bekommt OS 2.0, unter anderem mit User Samples (3,4GB). :phat:
Wenn ich dran denke, wie der Forte vor einem Jahr ausgeschaut hat, kann ich Kurzweil nur danken!
Version 2.00 Release Notes
WARNING: Objects created with Forte 2.00 are NOT compatible with previous versions of Forte. Of course, Forte 2.0 and later will read programs created with previous OSs.
STORAGE MODE
SAMPLE LOADING - Now you can load up to 3.375 GB of user samples into your Forte. WAVE and AIFF files can be loaded (8 or 16 bit, up to 96K sample rate). P3K, KRZ, K25, and K26 files with samples can be loaded. For example, see the Synthscapes and Take 6 libraries for PC3K available at kurzweil.com/product/pc3k8/downloads. User samples remain in memory across power cycles. Note: When transferring files to and from the Forte via the USB Computer Port, the maximum size of files that can be transferred is approximately 20 MB. This is suitable for most, non-sample, objects. For transferring audio sample files, use the USB Storage Port with a USB mass storage device such as a "thumb drive." When using the USB Storage Port to transfer files, the file size that can be transferred is limited only by the size of the USB mass storage device, and the Forte's available object and sample memory.
LOAD - The object Load function has a new feature "Fill from ID". When the User Type parameter on the Global Mode Main page is set to Advanced, pressing the Storage Mode Load "Fill" soft button will show the "Fill from ID" dialog. When you select a saved object file to load, "Fill from ID" allows you to choose the ID number at which you would like to begin loading objects. This allows you to load user objects to specific IDs, instead of always loading to the unused IDs starting at ID 1024. Fill from ID also shows a visual map of the used/unused object ID space, which is useful for finding unused ID ranges so that objects are loaded to adjacent IDs.
LOAD - Multiple object selection: The Storage Load page now has a Select soft button which can be used to select and load multiple objects in the list at the same time.
STORE ADVANCED - Browse Objects by Type: A new "Type" soft button has been added, which allows you to jump to the next different type of object in the list.
Fixes/Improvements:
LOAD & STORE - Improved speed of scrolling through the file/object list.
LOAD / OPEN - Now loads only the selected objects and other storage mode bugs
LOAD - Fixed an issue where user Per Key Velocity Maps could be loaded to the wrong ID.
MULTI MODE:
Features:
EDIT / AUDIO IN - Press the AUDIO IN soft button to access the Audio Input page. The Audio Input page allows you to choose an FX Chain to apply to the rear panel 1/8" (3.5mm) input signal, and enable or disable the use of any existing FX Mods in the selected Chain. Each Multi can be saved with it's own Audio Input settings, or be set to use the Audio Input settings set in Global Mode.
EDIT / FX - New FX algorithms: Spectral 4-Tap and Spectral 6-Tap with five FX box presets (IDs 176 and 178-181). These effects consist of a feedback delay loop with multiple output taps that can be set to tempo-based times. The feedback path contains a LPF, HPF, and a diffuser. The first tap has a shaper, and the other 3-5 taps each have a shaper plus a comb filter.
EDIT / FX - Aux FX now remain loaded when possible when switching from Multi to Multi. Previously Aux FX would always become muted when switching from Multi to Multi.
EDIT / MAIN - When the Global Mode User Type parameter is set to Advanced, a new parameter "Input Channel" is accessible. The Input Channel allows remapping of incoming MIDI data through specified zones. Here's how it works:
In Multi mode, an external MIDI device (such as a keyboard or sequencer) will play notes of a single program by default (if the Global mode Local Keyboard Channel parameter is set to off, see page 12-16 of the Forte Musician's Guide for details.) The played program will be on a Zone that has a Channel parameter (on the MAIN page) which matches the channel on which the external MIDI device is transmitting. (If no Zone's Channel parameter matches, the external device will play notes of the last program that was using that channel in Program Mode or from a previously loaded Multi.)
When the Program of a Multi Zone is played from an external MIDI device, Multi MIDI parameters (most noticeably key range and transposition) will not be applied. If you want these parameters applied, set the Input Channel parameter to match the channel on which the external MIDI device is transmitting. See the Input Channel Settings section below for details on setting an Input Channel. (To play the entire Multi from an external MIDI device, see Local Keyboard Channel (Local Kbd Chan) on page 12-16.) When Local Keyboard Channel is set to something other than Off, the Input Channel parameter has no effect and will appear in parentheses.
Input Channel basically has the same effect as Local Keyboard Channel, except you can choose to play only one or some Multi Zones from an external device, instead of all Zones. To play more than one Zone from an external device, set each desired Zone's Input Channel parameter to match the channel on which the external MIDI device is transmitting.
When setting a MIDI channel number for the Input Channel parameter, channel 1 for example, you can choose "1 L+M" or "1 M" (scroll past "16 L+M" to see all the choices.) A channel number with a setting of "L+M" indicates that the zone will be playable from the Forte keyboard (L for Local) and from the external MIDI controller (M for MIDI.) A channel number with a setting of "M" indicates that the zone will be playable only from the external MIDI controller, and not from the Forte keyboard. You can also choose "Any L+M" or "Any M" for the Input Channel setting. "Any L+M" and "Any M" will make the zone receive MIDI on any channel that an external device is transmitting. This is useful if you are using a single external MIDI controller and are not sure which channel it is transmitting on.
Fixes/Improvements:
Fixed an issue where scrolling through Multis could cause the system to crash.
Fixed a problem that could cause changes to be lost when canceling the import of a Multi Zone.
Fixed a problem that could cause the Multi editor to show the "All Zones" indicator for parameters that only apply to one Zone.
Fixed a problem in the Multi Editor that could prevent the keypad from working for renaming Arp Presets.
Fixed a problem where deleting a Multi could cause the system to crash.
PROGRAM MODE:
Features:
EDIT / FX - (FX Chain editor) New FX algorithms: Spectral 4-Tap and Spectral 6-Tap with five FX box presets (IDs 176 and 178-181). These effects consist of a feedback delay loop with multiple output taps that can be set to tempo-based times. The feedback path contains a LPF, HPF, and a diffuser. The first tap has a shaper, and the other 3-5 taps each have a shaper plus a comb filter.
Fixes/Improvements:
Improved FX transitions between programs. Now you can have smoother transitions between programs even if both programs use both aux FXs. Keep the total number of FX units in each program under 15 for this to happen.
EDIT / COMMON - Numeric entry working now in Intonation Table Editor.
Fixed a problem that could cause the Global Tempo to revert to a previously set Global Tempo when selecting a Program.
GLOBAL MODE:
Features:
AUDIO IN - Audio Input FX: The previous 'Audio Input' parameter has been removed from the Global Mode Main 1 page, and replaced by the new Audio Input page. Press the AUDIO IN soft button to
access the Audio Input page. The Audio Input page allows you to adjust the input gain of the rear panel 1/8" (3.5mm) input using the "Level" parameter. Now you can also choose an FX Chain to apply to the input signal, and enable or disable the use of any existing FX Mods in the selected Chain.
MAIN / Sound Sel - ('Surf-n-Select') When the User Type parameter on the Global Mode Main page is set to Advanced, the Sound Selection parameter appears. The "Category Buttons" setting allows you to select Programs and Multis normally. The "Enter Button" setting allows you to scroll through the Program or Multi list without immediately loading the selected Program or Multi. This allows you to find the next Program or Multi to load without interrupting the Program or Multi that is currently being played. When scrolling through the Program or Multi list, Programs and Multis will appear with their names in parenthesis to indicate that they have not been loaded. Press the Enter button to load the currently selected Program or Multi. When switching to Program or Multi mode (either by using the Mode buttons or Favorites) the current Program or Multi will be loaded automatically.
SAMPLES / PREVIEW - Sample Preview functionality to create a basic Keymap and Program directly from any User or Factory sample in memory for easy sample audition.
SAMPLES - Sample page shows current free space in the user sample area.
DELETE - Multiple Object Selection: A new "Select" soft button has been added. Multiple objects can now be selected and deleted at the same time.
DELETE - Browse Objects by Type: A new "Type" soft button has been added, which allows you to jump to the next different type of object in the list.
Fixes/Improvements:
MAIN 1 - Fixed a problem where the "Program Tempo" parameter would not appear immediately when selecting Advanced User Type.
MAIN 2 - Numeric entry working now in Intonation Table Editor.
DELETE - Fixed a problem where Program and Multi 1024 were not being displayed.
DELETE - Improved speed of scrolling through the object list.
DELETE - Delete processing time is now much faster.
GENERAL:
Features:
Increased User ID space: User objects can now be saved to IDs 1024 through 4095 (previous range was 1024 through 2047). Note that some factory objects are also stored in this range (Chains, Samples and Keymaps).
The Storage Active LED now lights up whenever writing to the internal system memory (in addition to when writing to or reading from USB devices). For example, the Storage Active LED now lights up when saving objects such as Programs, Multis or Global Mode settings (when exiting Global Mode) to indicate that the Forte should not be powered off while writing to system memory, as this can cause data corruption.
Fixed a problem where the keypad "DELETE", "INSERT" and "SYMBOL" buttons did not work in some text fields.
Fixed an issue where quickly pressing Favorites buttons could cause problems with controllers.
Various minor bug fixes.
Also kann man den jetzt auch als Effektgerät nutzen wie PC3Kx und K2x00?
Ja, für den Audio Input stehen pro Multi eine Effektkette zur Verfügung. Ist halt ein Miniklinken Input.
Mit den 3,4GB Samplespeicher ist das jetzt ein extrem geiles Board als Zentrale des Setups.
Ein User auf Mastering VAST hat sich Kontakt Libraries in den Forte geladen. Geile Sache! :D
Hier der Link und das Posting, für die, die nicht angemeldet sind.
http://forums.godlike.com.au/index.php?topic=5050.0
This is long, not proofread, and from memory. Please PM me if I omitted anything or you are trying to follow along and get stuck. It is likely the fault is mine and not yours.
DO try this at home!!!!!!
Having been through it a few times, and wishing to 1. Use as few user ID's a possible, and 2. Not have to sample map on the Forte, I used this method today. It took
me fraction of the time it took to do my other sample libraries. Software involved was Kontakt, Chicken Sys Translator - Kurzweil version, KurzFiler.
I'm using Sampletekk's Rain piano - the same principles apply to other sample sets.
Sampletekk's Rain Piano has 11 velocity layers, all of which are consistent across the length of the keyboard. This is important. If your source sample set has different velocity transitions on different keys you will need to edit within Kontakt to make them even. It is OK to have the same sample in split into 2 to match its neighbor.
Open the full program and strip out all the release samples, pedal down, etc. You can add the releases later, or you can use a release layer native to the Forte.
Save.
For each of the 11 velocity layers, I created a separate .nki with just that layer by opening the full program, and deleting the other velocity layers. I then stretched the layer vertically to inhabit the full velocity range. If the reason for this is not obvious, it is to ensure that Translator would later populate the kHz keymaps with a 100% success rate. Using multiple velocity layers can either crash Translator (if too many) or result in samples not mapping. It also does not seem to like gaps in the velocity range. This is a little more work up front for MUCH less later. Name them in a logical way, so you know which layer is which later on.
Now use Translator to convert the 11 .nki programs to .krz programs.
In succession bring the 11 (or whatever) .krz files into kurzfiler. There should be 2 keymaps, one for the left, one right. Click on each keymap and hit consolidate keymap. This reduces all the samples in the keycap to one sample ID. Yea!!!!! Save as a renamed .krz.
If you like, and just because you can, open one of the consolidated .krz files into kurzfiler, then import the rest. You can now save the whole shebang as one krz file.
Import that krz file into the Forte. Go to the 1st program. On the layers page, change enable to Attack Velocity. Range to pop/fff, key range from bottom to top. This is so that when you duplicate layers, you will not have to do this for each layer. So.....duplicate this layer as many times as necessary. In this case 10 times, giving you 11 layers.
Go to the keymaps page. Scroll up to layer 2 and change the keymaps to the next velocity layer. Continue on through all 11.
It still will not sound like anything as all (or no) samples are triggering depending on the velocity. Time to split up the layers.
Open the full version in Kontakt, on the mapping editor page, as a visual reference. This will make it easy to see where the velocity transitions are. On the layers page(s) in the Forte, set the low and high values for the velocity enabling to match the original Kontakt program.
Now it should sound like something. Not perfect, but getting there. You will note that the releases are abrupt, and that the dynamics might not be how you would like them to be,
Let's fix the releases. 2 things. First - for each layer set the amp release to .500 or so. I don't have it in front of me - you can look at another program to check if that sounds wrong. The releases should sound natural but still a LITTLE more artificial than having release samples involved. So.....go into a factory piano program you like, find the release layer, go back to the original program and import it. Set volume to taste. Make sure the trigger is set to reverse on this, if you just brought it in as opposed to importing.
Dynamics are a matter of personal taste, and interact with the velocity curve you have selected under global. I use "piano touch". On the DSP MOD page, I start by setting all of the output levels the same, then change the Velocity tracking on volume to 20db. What happens next is really all about taste and the specific instrument. Play a bit, see if it feels right. If not dynamic enough, you can raise the Velocity tracking. Or, you can get into messing with the individual layer volumes. I like to have somewhere to go near the top of the velocity range so I usually boost the last couple of layers successively higher. If the low velocities are too loud, tweak them down. There is a lot of trial and error here, and this can REALLY customize the samples to your taste. Do not skimp on time here. Of course, you can always come back to it, save a few versions, etc.
It should be sounding and feeling pretty great now. It is time for the special sauce. Go through the factory pianos and see which FX you like. Copy both the insert FX and the sends, some of which are enabled by the sustain pedal being down and emulate the resonance caused by this. ALSO - with the insert FX - if you grab one with Sympathetic Resonance, and you should, go to the keymaps page and turn on sympathetic resonance for each layer other than the releases.
This will likely be enabled by one of the front panel buttons, and the amount controlled by the fader underneath. Not too much!!!! If it is not there - go in and turn up the wet/dry manually.
Live with it - tweak it. Experiment with different FX chains.
I now have Scarbee Wurly, Sampletekk White Grand, and Sampletekk Rain Piano living in my Forte.They are there when I turn it on - no laptop, no Receptor, no computer. It's a beautiful thing. The 2 pianos provide grittier and extremely playable compliments to the factory pianos, and the Scarbee Wurly is a bread and butter sound for me, plays SOOO well in the Forte, and applying the VAST FX to it is amazing.
@duplobaustein:
du hast einen FORTE, oder?
ich hab den bei JM angspielt (hatte vor ganz ganz vielen jahren schon einen k2500 und später noch kurz einen K2600)
aber der FOrte kam mir "fetter" klingend vor. Täuscht das? Oder gibt es da tatsächlich Hardware Unterschiede, also außer anderen Programmen?
Und: Hast du schon mal analoge Synths gesampelt und dann mit VAST bearbeitet bzw hättest dafür Klangbeispiele oder weißt, wo man was dazu findet?
(ich weiß, der Forte kann selbst nicht sampeln)
Und hältst du es für wahrscheinlich, dass noch ein Synth von Kurzweil kommen wird?
:nihao:
V au schrieb:
@duplobaustein:
Hm, das ist schwer zu sagen. Er hat auf jeden Fall mehr Effektpower, nämlich 32 Blöcke (viel mehr als die K Serie) und den Master Kompressor am Panel. Wenn der an ist, dann drückt es schon deutlich mehr. Der große Hardware Unterschied ist Flash Play, also ein Flash Speicher, von dem gestreamed wird.
Der Forte kann selbst nicht samplen aber eben samples laden. Ich habe mal eine gängige VST Moog Emulation abgesampelt. Das funktioniert schon gut, allerdings ist das Editieren am Gerät schon sehr mühsam, wenn man so viele Samples in eine Keymap ladet. Hier gibts zb den Kurzweil Creator, der gerade heraus gekommen ist. Auch ist das Portamento, wenn man samples verwendet, nicht so gut. Das klingt nicht ganz flüssig. Also monophone Leads haben da eine Einschränkung. Wenn man VA OSC verwendet ist das kein Problem.
:nihao:
Für nicht wahrscheinlich. Die haben mit dem PC3 und dem PC3Le jetzt gerade voll die Kurve gekratzt und sind stabil. Die bauen jetzt mal Stage Pianos, wobei der Forte eigentlich eine Workstation minus Sequenzer ist. Der kommt aber wohl auch irgendwann. Der Forte/Forte SE wird die schon noch bis weit ins nächste Jahr beschäftigen bevor die vielelicht ein neues Board mal angehen. Und dann dauerts noch sehr lange.
Danke für die Infos.
Dann werden sie wohl die neuen Forte auch mit dem LENA Prozessor ausstatten?
Mal sehen...
Mal eine frage, wie macht sich das größere Display des Forte so beim editieren ? gerade im Unterschied zum PC3K.. Auch so beim routing der DSPs im VAST editing ect.. ist beim PC3K ja schon einer Herausforderung..
Da ist nicht viel um. Ein paar Pages wurden zu einer zusammen gefasst, was da schon praktisch ist, ansonsten ist es nur hochauflösender und sieht moderner aus.
Im Multi (Setup) Mode kann man sich Zonen Informationen anzeigen lassen.
So , da mein Forte 7 die Tage aufschlägt wollte ich diesen Thread mal wieder aufwärmen. Mitlerweile ist das OS ja auch schon wieder etwas weiter , was genau passiert ist sieht man ja an der kompletten und vorbildlichen Update Liste welche jenem im ZIP beiliegt...
Wenn man wie ich in andere Workstations gewildert hat , liest man das Kurzweil Manual doch mit viel mehr Ruhe. Nicht das es komplex und damit schwer zu durchsteigen wäre , nein .. Für die Komplexität ist es einfach verdammt logisch aufgebaut , es ist halt einfach viel Kram..
Ja genug geschwafelt
Eventuell hat ja hier jemand TIP s , wie zb gut gemachte kostenpflichtige aber auch kostenfreie Programme , Dinge die man haben muss / kann. Soundtower ? gut schlecht bäh ?
Im Grunde finde ich gibt es hier viel zu wenig zu der Kiste zu lesen, VAST allgemein - nicht das Cunka schlecht ist - aber hey ! ist nicht ausgerechnet VAST ein Grund informationen zu tauschen ? ( schon wieder geschwafelt, mist )
Mich persönlich interessieren vor allem Samplemanipulationen und Erfahrungen , das ist ja ein schwieriges Thema da vieles geht , aber auch oft mit Artefakten belastet ist..
Bei mir ist es das Ziel möglichst viele Artefakte aus dem Forte zu bekommen;-)
Man kann schon ungewöhnliche Dinge mit Vast bauen. Vorher hatte ich den K2000 aber das Dynamic Vast kann doch eine Menge mehr.
Was ich schade und merkwürdig finde ist, dass der Forte Se besser mit Feature Updates und Addons versorg wird als der Forte. Hoffentlich bekommen wir auch bald Sequencer und VSTPlugin...
Soundtower: mach dir selbst ein Bild, sehr stabil ist er nicht, aber durchaus manchmal praktisch
Das klingt jetzt hier blöd, aber im Nachbarforum ist eine sehr starke Kurzweil Community und der Forte Thread wird da inkl. Wiki von mir betreut.
Der Editor hat einen sehr guten Program Librarian und Programs lassen sich ganz passabel editieren. Es gibt auch ein paar nette Ansichten/Übersichten, die man am Gerät so nicht hat. Multi Edit kann man komplett vergessen und die ST Editoren sind bekannt instabil.
Das kann ich jetzt überhaupt nicht nachvollziehen. Seit ich den Forte gekauft habe kamen folgende Features hinzu:
1. 16 Zonen statt 4
2. volles VAST Editing
3. volles FX Editing
4. 3,3GB User Sample Speicher
5. Audio In mit FX Chain global oder per Multi
6. individuelle Velocity Response pro Taste
7. Multi Overview Ansicht
8. Surf‘n‘Select Auswahl
9. Arpeggiator
10. Step Sequencer
11. String Resonance FX Alg
12. hunderte Bugfixes
Aktuell ist auch wieder der Forte in der Entwicklung. Mal sehen was noch kommt. :)
Konkrete Fragen gerne hier. Ansonsten kann ich eben den Forte Thread drüben empfehlen.
schon richtig, am Anfang war es nur ein Stagepiano:)
Dann wurde daraus ein sehr guter Synthesizer :))
Daraufhin wurde er auch teurer, was auch ok ist.
in den neuen Release Notes zu 2.11 habe ich noch nicht so spannendes neues (für mich) gefunden.
Ich habe mich schon mehrfach gefragt, ob der SE nicht die bessere Wahl (für mich) gewesen wäre.
Klar wurde der Forte mehr aufgewertet als der SE, letzterer ist ja auch jünger;-)
ich benötige keine GB Pianos, sondern nutze den Forte nur als Synth. Ich käme auch mit dem kleineren User-Samplespeicher gut aus.
gerne hätte ich den integrierten Sequencer und das VSTPlugin.
Klar, das Display ist schön, aber sonst...
Das ist auch meine Meinung, ich hatte jetzt aber einen Forte 7 für 2200 über den Händler schiessen können , sonst wäre es auch der SE geworden.. Aber das Display hat mich schon angesprochen. Gerade Keyzones profitieren von der beseren Darstellung :)
Der SE hat den Sequenzer, weil er das selbe Display wie der PC3 hat und deswegen kein neues UI nötig war. Grundsätzlich ist er im Forte schon drinnen, sonst würden die Demo Songs nicht laufen. Die Frage ist jetzt nur mehr, wann sie die Zeit finden, das auch für den Forte zu implementieren. Fakt ist, dass der Sequenzer das wohl am meisten gewünschteste Feature ist. Geduld, der kommt schon noch, da bin ich mir sicher. Ich denke das selbe gilt auch für das Plugin.
Ich denke am Ende des Tages wird der SE kein Feature haben, dass der Forte nicht auch hat.
:) genau, das hoffe ich auch.
Als der sp6 dann aber wieder mit dem alten Display herauskam, da habe ich Zweifel bekommen.
Für Kurzweil wäre es doch einfacher ein einheitliches GUI zu haben und bei Bedarf abzuspecken, Features ab- oder einzuschalten. So ist der Forte eher eine Insel. Ich habe das Gefühl, Kurzweil entwickelt immernoch auf ihrem alten Display mit ihrer alten GUI und portiert das Ergebnis mühevoll auf den Forte.
Da bin ich mal gespannt wie der kommende Sequenzer von dem Display
profitiert ..
Ich denke da hast Du recht und es ist ja offensichtlich dass nur das Interface angepasst wird, wahrscheinlich verkauft sich der SE besser und daher dort mehr Druck .
