highsiderr
In beta20 gibt es nun wieder ein paar kleine Änderungen.
Grüße
- New feature - there’s now a “PREViewing” setting in the settings menu, to control whether samples will preview audibly in the file browser. Settings are ON, OFF, and CONDitional - under which previewing will only occur if playback is off. This setting replaces the old method of holding shift before pressing the audition pad of the row you’re going to browse for - that will no longer work. Default is ON for existing devices, but will be COND for new devices in the future.
- Rearranged a couple of other things in settings menu - the LAYOut submenu is now renamed to PADS - which is a bit easier to make sense of on the 4-digit display. And the MONItoring setting is moved into the RECOrding submenu, and its SMARt option is renamed to CONDitional, to match the new PREViewing setting and make a bit more sense.
- Muting Instruments in arranger now stops them echoing or being sounded by MIDI input. As discussed in a thread a couple of days ago. I'm hoping this will be helpful for people and won't cause problems in anyone's existing workflow. Still open to feedback if you have any thoughts.
Grüße
