Max for Live Devices & Tutorials
Spectral Attractors uses a physics simulation and a phase vocoder.
The phase vocoder sounds whatever spectral content is in the current “state”. The “state” is attracted to up to 4 other spectral “states” called “attractors”, which attract the state via the physics simulation with two different modes:
(1) FFT Mode: physics simulation is in 12288 dimensions (a bit higher CPU as a result) in which every FFT frequency bin amplitude, phase value and previous frame value for both left and right channels is a dimension, which results in a complex soundscape and combination of spectrums.
(2) 2D Mode: physics simulation is in 2 dimensions, in which attractors are spread out on a 2D plane based on their spectral differences. The sounding “state” then depends on how close it is to the attractors in a 2D space, resulting in spectra closer to the original attractor states. This mode also includes an option for either interpolating or crossfading based on distance to attractors.
Attractor states are selected by taking “snapshots” of audio in a buffer, which can either be a dropped sample or recorded live from routing audio from another track in Live. Additionally there are parameters for controlling the physics dynamics and real time frequency domain pitch shifting.
Download
Möchte hier mal auf die SEEDS Collection von Novelmusic hinweisen.
2 Sequenzer (Polyphon, Strum, Ratchets, Scales Morpher) mit 2 externen Clock-Generatoren, umfangreich verschaltbar durch externen Hub, Preset Utility, 2 Modulatoren für Wahrscheinlichkeiten und Midi Noten. Jeweils gute Eingriffsmöglichkeiten durch Push!
https://www.novelmusic.org/m4l/seeds
max 4 live ? da war doch was. hat mein ableton immer abstürzen lassen.
mit ableton 8, 9 und 10... (11er braucht im leerlauf 10% mehr cpu. muss deshalb auf nen neuen rechner warten)
ich trau mich da nicht mehr ran an m4l, wenn sich die projekte nicht mehr öffnen lassen, bringt das beste plugin nüscht!
Also auch nach mehreren Versuchen lassen sich die Projekte nicht öffnen?
Bei mir sind Abstürze sukzessive weniger geworden und seit der 10er läufts eigentlich gut. Ganz selten stürzt Live beim Laden von Sets mit M4L Geräten direkt ab, klappt dann aber immer beim zweiten Versuch...
ich habe kaum noch abstürze, seit ich m4l meide ^^
aber nein, die projekte wo das problem besteht, lassen sich nicht mehr öffnen.
ich vermute, dass beim laden ram peaks entstehen, die meine 8 gb ram nicht abfedern können.
Dreh die Audio Engine ab bevor du dieses Live set ladest. Ohne Audio Engine on initialisiert fast nichts in M4L devices und somit wird sich vermutlich auch das Dokument öffnen. Wenn das nicht hilft, und du weisst welche devices du verwendet hast, dann die einfach verschieben oder umbenennen. Live findest sie dann nicht und ignoriert sie einfach.
Das Live set an sich kann durch M4L devices nicht beschädigt werden.
dir ist klar, dass du das auch lösen kannst, indem du das plug-in deinstallierst?
aber mal was anderes. passiert euch das auch mit stock content oder nur mit kostenlosem drittanbieterkram?
viele leute programmieren nämlich einen ziemlichen mist zusammen, und m4l ist auch nicht unbedingt eine so eine safe sache, schon gar nicht wenn man auf neue systeme migriert u.ä.
grad probiert, mitm asio4all treiber läuft es.
den tipp muss ich mir merken. :) (ableton 10.1.41)
top! der ausgewählte treiber sollte egal sein. audio muss einfach nur aus sein. gilt auch alles für Live 11. das is auch ganz oft die ursache, wenn leute glauben, dass ihre m4l devices plötzlich nicht mehr funktionieren.
initialisierung findet immer in data rate statt, bevor die device irgendwas von audio weiß. das laden von neuem max code (in welcher form auch immer) sollte eigentlich keine IO treiber abschießen oder umgekehrt.
Wenn sich ein Liveset mal nicht laden lässt, dann kann man auch folgendes versuchen:
In Ableton Live links im Browser unter "Places" einfach die entsprechenden Unterordner (also die Einzelspuren) von dem Song aufklappen.
Dann kann man gemütlich die einzelnen Spuren in ein neues Projekt ziehen.
Das hat mir schon das eine oder andere mal die Rettung von vermurksten *.als Projekten ermöglicht.
Das Slink Bundle gibt es auf der Hersteller Seite aktuell für 37,50€.
Jemand hat einen alternativen Editor für Ableton Wavetable mit M4L erstellt. Floating Window inklusive....
ZL Wavetable Editor [zoftloud]
die Stimme ist so cool ... das ist fast schon n Track
Etwas flauschiges FFT-Gebimmel gefällig?
ich möchte da an dieser stelle werbung für dieses device machen. ich finde es wirklich großartig und es wertet den ableton wavetable ungemein auf. ich war auch mit dem entwickler tyler (zoftloud ist eine one-man-show) in kontakt und habe ihn gefragt ob er das interface zoombar (floating window) machen kann, was er in ca. 3 wochen implementiert hat. ein sehr netter kontakt.
ich finde, dass solche leute definitiv unterstützt gehören.
er hat mir auch geschrieben, dass er einen ähnlichen editor für operator / sampler in planung hat, aber das interesse am wavetable-editor weit hinter seinen erwartungen geblieben ist und der programmieraufwand relativ groß ist in relation zu den verkaufszahlen.
So ein Editor für den Operator wär es noch.
(siehe oben ;-))
er hat noch andere interessante devices: https://zoftloud.gumroad.com/
also macht auch ein bisschen werbung… hätte nämlich auch gerne einen editor für den operator :)
