Oberheim OB-X8 Synthesizer (V2.0)
rz70
öfters hier
Neuer Teaser
1953C1BD-4651-4E64-83F6-2BEE15D6F8DD.jpegEC883A55-8484-42F8-9F30-F45282BCDC0B.jpeg75ADB0E9-49C0-48AE-A621-45A29E942BAF.jpeg4DC7291A-6D6C-4EF6-8BAA-1FAB6C0E7135.jpeg990B7285-FEB8-4BB6-96A4-53AB1639A8F2.jpeg8617EAAE-694F-4C1D-92D3-1BDB79E9281E.jpeg
From 99musik:
8-voice, pure-analog polyphony with sine, saw, square, triangle, and noise
Two discrete SEM/OB-X-lineage VCOs per voice deliver classic punchy Oberheim tone
Discrete SEM-lineage VCFs deliver authentic OB-X-style tone and presence
Genuine Curtis filters add bold OB-Xa/OB-8 character
Meticulously modeled envelope responses match each OB model: OB-X, OB-Xa, and OB-8
The 61-key FATAR velocity- and touch-sensitive keyboard allows unparalleled expression and responsiveness
Bi-timbral capability allows two presets simultaneously for splits and doubles
400-plus factory programs, including the full set of factory sounds for the OB-X, OB-SX, OB-Xa, and OB-8
Integral, fanless, heatsink-free power supply
Real walnut end cheeks
High-resolution OLED display enables patch management and easy access to advanced features
Classic Oberheim Pitch and Mod levers allow expressive note bending, vibrato, and access to arpeggiator functions
Enhancements
Additional SEM Filter modes add high-pass, band-pass, and notch functions to the classic OB-X filter
Vintage knob allows variable amounts of voice-to-voice variability to emulate the behavior of vintage instruments
Velocity sensitivity adds expressiveness to volume and filter
Channel Aftertouch adds real-time performance-based modulation
Enhanced unison allows variable voice stacking from 1-8 voices
Variable triangle wave cross-modulation
Over 600 user-programmable preset locations
Programmable per-voice pan allows wider stereo presence
Variable oscillator and noise levels
Ins & Outs
Stereo and Mono outputs
Volume, Sustain, and Filter inputs
Arpeggiator clock input
MIDI In, Out, Thru
USB
MSRP: $5000
Release date: June“
UPDATE 2.0
- Instant binaural mode pans individual voices hard left and right for true stereo operation
- Simultaneously selectable waveshapes for each oscillator extends timbral variety
- New 4-Pole low pass filter type with fuller bass at high resonance
- New VCO 1 and 2 level LFO modulation destinations for independent timbral mixing
- Arpeggiator clock sync now has selectable note division values for expanded rhythmic control
- Twice the Split and Double memory locations, including program storage directly in the new banks for 512 more stored sounds
- Separate MIDI channels for lower/upper split bi-timbral operation
- Poly chain for up to 32 voices with 4 connected instruments
- MPE for new levels of expressiveness
Weitere Info zum Update findet Ihr hier unten auf der Seite: https://oberheim.com/products/ob-x8/
M.i.a.u.: Studiodragon, Steven Hachel, rauschwerk und 35 andere
Klasse!!! Krieg ich direkt Gänsehaut beim Anschauen …das Dreamteam!
M.i.a.u.: Area88, kalyxos, Lauflicht und eine weitere Person
Gute Jungenzz....absolut Sympathico....mit Schnäpschen.....Prost!!! Man darf gespannt sein was da kommt.
Ja das wird sicher ein sehr interessanter Synthesizer. Interessant ist auch, dass er anscheinend als Oberheim und nicht als Sequential erscheinen wird.
Oha… wollte eigentlich Richtung OB-6, aber da warte ich doch mal etwas….
M.i.a.u.: Soundwise unlike
Langweilig. Die klonen bestimmt wieder einen klassischen Behringer. :gaehn:
M.i.a.u.: Bojang Prodöktschns, MLaca, 8ikjhgtzuk456789 und 15 andere
Gibt es eigentlich noch irgend einen Thread der noch nicht durch das B-Wort kontaminiert wurde? :roll: dankeschön...
M.i.a.u.: Mr. Roboto, VEB Synthesewerk, HansLanda und 3 andere
Die Schaltungen auf den Bierdeckeln könnten andeuten, dass man tatsächlich zwischen Filtertypen umschalten kann (wie beim P5/P10). Wird ja schon lange diskutiert.
M.i.a.u.: Audiohead und Hamudi2000
Oh mann, da gab es bisher kaum etwas zu sehen, aber alle lechzen schon ... das sollte mal B machen! ... Ach so! Machen die ja auch? ;)
M.i.a.u.: dubsetter, Audiohead und Summa
Wie B sagt, muss auch A sagen: Abstrakt Instruments mit dem VS-1. Ich wette mal, dass man den Oberheim zuerst bekommt. Wenn Dave Smith einen Teaser zeigt, dann ist das Produkt fertig und bald im Laden.
M.i.a.u.: Soundwise unlike, dubsetter, HansLanda und eine weitere Person
  • #29
Ach stimmt ja, die haben den ollen 4 Voice mit einer Matrix geklont. Jetzt kommt die Kiste wirklich ..
