Das LVX hat ein
Firmware Update erhalten:
New Features
• New Damping control for delay types. (Damping at zero is the original LVX voicing for all Types)
• For Digital, the Damping control allows you to darken your repeats
• For BBD, the Damping control alters the filter structure around the bucket brigade clock, with no clock noise preset when
damping is set to 100%
• For Tape, the Damping control changes the filter structure and ages the tape to allow for darker timbres
• New Half Speed Delay Parameter – allows half speed sounds for all structures
• New Hold Modifier, when assigned this modifier lets you hold the current preset footswitch to control a parameter. You can
also trigger a Hold via MIDI (CC 118)
• Expression parameters can now be controlled by other modifiers via new Source parameters, this lets you assign up to 7
parameters to a single modifier
• New Character Delete and Character Insert for preset naming (when naming, push C3 to delete, push C1 to insert)
• New Full Name Clear, when the naming field is highlighted in Save As View, hold C1 for a full instant erase of the name
• MIDI command to enter Tuner mode (CC 117 to enter/exit Tuner mode)
• MIDI command for Tap Tempo switch (CC 99 is used for a Tap press)
Enhancements and Bug fixes
• New taper for Analog Mix to better match DSP Mix taper
• Sped up digital potentiometer transition time to improve patch switching performance
• Improved phase synchronization in Mono Mode for delay types
• Improved phase synchronization in Mono Mode for delay note division changes
• Filter Resonance UI code now allows for a Q value of 1
• Fixed MIDI Omni bug when controlled by an encoder
• Expanded CC data for Looper Half Speed / Reverse switch: Data < 63 provides Half Speed Toggle and Data >= 63 provides
Reverse Toggle
• Improved Memory clearing for the PolyChroma effect during preset transitions
• Added instructional text to the Firmware Update Screen
• Disabled the envelope modifier in Bypass to remove false triggers
• Reversed the Delay Multi Structure’s Pan control to correctly match left and right
• Quick Save via active/lit LED button now works in Save As View
• New Factory Reset View with Start and Cancel buttons
• Minor change to the compressor for tighter input tracking
• Fixed the behavior for Favorite Parameters assigned to Type: None
