Torso S-4 Sculpting Sampler
Der Torso S-4 hat das 2.0 Update erhalten:
S-4 OS v2.0​
June 17 2025
Features​
  • PERFORM: Global macros and punch-in effects for expressive, hands-on control. Map any parameters across the four tracks of the S-4 to the eight slider macros (supports unipolar and bipolar modes) or use the four action buttons as punch-in effects.
  • SCENE: Save and trigger up to 128 snapshots of full machine states per project. Use CHANCE and RULE to trigger chained scenes in sequence or randomly. Supports Program Change for easy external control.
  • TEMP: Temporarily change any parameter during performance and snap back instantly with the [TEMP] button.
  • COPY: Copy and paste scenes, tracks and devices with the [COPY] button.
  • DISC: New MATERIAL device for streaming audio directly from the internal storage.
  • FOLLOW: New envelope follower available as Modulation Source. Use internal or external audio as the control source, adjust fall and rise time, apply sample and hold and apply modulation to any parameter.
  • Track Launch: Start and stop any of the four tracks individually using the new Track Launch available in the Mix View. Track mutes moved to [CTRL] actions in the Mix View.
Enhancements​
  • Optimized Internal Microphone: The internal microphone has been polished for a cleaner sound.
  • New Modulation Mapping Workflow: Modulation Mapping is updated for more seamless and intuitive mapping with momentary controls. While [MOD] is held, Mapping Mode is active – turn any parameter to apply modulation to that parameter. Tap an action button while [MOD] is held to switch Modulation Source, tap again to open the Modulation Source view.
  • Sample Preview: Preview samples directly in the Sample Browser by holding [CTRL] + [PLAY].
  • Track Record and Track Launch quantization options available in [CONFIG].
  • Quick actions enabled for [TRACK], [SCENE], [MIX] to overlay view-specific actions in any view.
  • Added option in CONFIG → METER for stopping Modulator transport when the S-4 is not playing.
  • Storage used is now indicated in CONFIG → SYSTEM.
  • Track Input and MIDI settings restructured in [CONFIG]. They are now under separate menus CONFIG → AUDIO and CONFIG → MIDI.
  • Inputs options renamed to IN1/IN2.
  • Added IN1/MIC input option.
  • Increased gain for line out and headphones.
  • Main Level is no longer bound to projects.
  • USB audio out is now post-fader, respecting levels set in the Mix View.
  • Settings in a Device are saved when switching Devices (or bypassing) in a Device Slot.
  • Tap an encoder while in Modulation Mapping Mode to switch between unipolar and bipolar mapping.
  • Inverted bipolar mapping added for modulation.
  • MAIN REC feature moved to [CTRL] + [PLAY] and features quantization, adjusted under CONFIG → METER.
  • Holding [TRACK] or [CLEAR] when changing device keep actions.
  • Reorganized [CLEAR] actions.
  • Updated CCs and MIDI NOTE implementation.
  • Buttons LED strength and color tweaked.
  • GUI Enhancements:
    • Modulation Mappings are now visually indicated in the GUI as well as via the LEDs on the S-4.
    • Updates to header includes showing current Scene instead of current device, MIDI in/out indicator removed and updated page indicator design.
    • Added scrolling slider to list views.
    • Smaller tweaks to layout, icons, device visualizations, etc.
  • TAPE: Enhanced TAPE device for the MATERIAL slot with new looping and overdubbing capabilities, as well as vari-speed recording.
  • TAPE and DISC monitor behaviour can be changed in [CONFIG] → METER.
  • RING: Added modes for the DECAY parameter.
    • SUSTAIN: Decay resonance is applied *after* filter cutoff, and WAVES/NOISE modulation.
    • CHOKE: Decay resonance is applied *before* filter cutoff, and WAVES/NOISE modulation.
  • DEFORM: Added modes for the CRUSH parameter.
    • BITCRUSH
    • REDUX
    • BITCRUSH/REDUX
  • DEFORM NOISE COLOR renamed to NOISE TONE.
  • VASTAdded modes for the SPREAD parameter:
    • PHASE SHIFT: Shift the delay time in stereo
    • PING PONG: Alternate the delay between and left and right stereo channels.
    • DIFFUSION: Diffuse the delay for reverb-like effects
  • VAST:Feedback increased to 200%
  • VAST:The TONE parameter is now bipolar, allowing for both highpass and lowpass filtering of the delay feedback chain and reverb.
  • POLY:Can now be triggered via the [TRIG] action.
Bugfixes​
  • Fixed issues with saving and loading projects.
  • Performance enhancements and optimizations to prevent crashes.
  • Optimized laggy interface in TAPE.
  • Fixed an issue where files could not be transferred to and from the S-4.
  • Fixed an issue where recordings didn’t play when transferred to a computer.
  • Fixed an issue where renaming projects in USB Mass Storage Mode didn’t affect projects when opening them up on the S-4.
  • Fixed crashes when entering USB Mass Storage Mode while sending CC.
  • Fixed an issue where sending CC to parameters could cause them to lock.
  • Fixed an issue where the first entry in a list couldn’t be deleted.
  • Fixed crashes when the internal storage becomes full.
  • Fixed an issue where the Global Tempo didn’t reset on new projects.
  • Optimized button presses so the S-4 no longer register double presses by mistake
Ich hab mir das Album gestern angehört, ich find's super, das zeigt wunderbar was die Kiste kann, das Album find ich so gut das ich selbst überlege mir einen zu kaufen!!
Endlich mal eine gute Werbung für die Kiste, ich hoffe, die Entwickler haben das Video auch gesehen...
Frank
Also ich kann irgendwie noch nicht so richtig einschätzen was man da eigentlich hört, also was schon im Sample ist und was Torso dazu generiert. Diese Resonator-Sachen kann man noch erkennen, viel Hall ok, aber sonst?
Obwohl ich Jay Hosking sonst oft super finde, ist der Sound seines Torso-Albums irgendwie anstrengend und irgendwas ist da auch stereo-mäßig komisch. Das Video von Substan finde ich zumindest angenehmer zu hören. Vielleicht werde ich aber auch einfach nur alt ;-)
Ich auch schon länger (coole updates bisher).
Das video habe ich mir vor ein paar Tagen auch angeguckt aber es hat bei mir eher das Gegenteil bewirkt.
Obwohl ich Jay Hosking sonst oft super finde, ist der Sound seines Torso-Albums irgendwie anstrengend und irgendwas ist da auch stereo-mäßig komisch. Das Video von Substan finde ich zumindest angenehmer zu hören. Vielleicht werde ich einfach nur alt
+1
bei mir sind eigtl nur 3 Sachen hängen geblieben:
1. Hoffe ich doch dass man die Auflösung der Knobs ändern kann (muss ich noch im manual nachschauen).
Denn er dreht ja teilweise sowas von durch, das kann doch nicht normal sein, 5-10 oder mehr Umdrehungen um einen kompletten Regelweg zurückzulegen - die aussserdem teilweise sowas von wahllos hektisch rüberkommen, dass ich ab und zu das Gefühl hatte es geschah just for demonstration purposes (oder war das optische Täuschung, denn bei anderen Einstellungen/Knobs sah es wiederum normal aus), konnte es nicht genau beaobachten da die linke Hand ständig die Sicht versperrte, weil die rechte mit Temp halten beschäftigt war -> feat. request=toggle/hold s.a. 3.)
2. Als die Kamera ausfiel und er zeitweise mit dem mobile filmte, wtf hat er mit der Oberfläche gemacht, Pommes? ... was ist das, dachte Metal oder etwa doch irgendeine Beschichtung? ..da krie isch plaq
3. Übertriebene Nutzung der Temp Funktion, wie damals bei beinahe allen Model Cycles/Samples videos, die ich dann, wahrscheinlich übersättigt davon, dann selbst so gut wie nie dort eingesetzt habe. Live Performance hin oder her, gut und schön .. aber wenn es da sonst nix zu tun gibt, ausser alle paar Takte alles zu verstellen und dann wieder zurück zum original Zustand, well..
Da geb ich mir dann ebenfallls auch eher ne halbe Stunde Ambient mit langsam evolving scapes.
Obwohl ich mich damit nie in den Wald setzen würde.
überlege weiter
Ich habe den S-4 hier stehen. An der Auflösung der Regler kann man nichts einstellen. Es sind acceleration encorders, d.h. langsames Drehen für feine Werte und schnelles Drehen für grobe Parametersprünge. Das erklärt eventuell auch seine Drehbewegungen im Video: dreht er 5-10 mal scheinbar endlos rum, ruft er nur kleine Parameter Änderungen ab. Ansonsten benutzt er nahezu nur den Temp Button für scheinbar wahllose temporäre Änderungen, die sind weg, wenn er den Temp Button wieder loslässt. Warum er die Macro Performance nicht nutzt ... nun ja, gerade da kann man mit den Modulatoren viel wildes Zeugs machen über alle Spuren hinweg, da beginnt der Spaß zusammen mit den Scenes erst... und ich habe in das Video gerade noch mal reingeschaut, der Mann macht das schon gut, es ist aber ausschließlich nur im Mixer das Muten & wieder Starten von Spuren in Verbindung von TEMP für die FX Änderungen und für Übergänge (Delay, Hall zb...) wenn eine Spur stoppt. Scene und Perform nutzt er nicht.
Und zu 2. : die Oberfläche vom Torso S-4 ist so eine Metalplatte, die merkt sich die Fingerabdrücke .... und damit das keiner sieht, sind fast alle Videos auf YT immer recht dunkel oder auch gerne mal dunkelgrün eingefärbt oder mit besonders starken Schwarz/Schatten-Werten, damit es keiner sieht ... haha - es sein denn, man putzt das Gerät extra für den großen Youtube Auftritt 😄
Ach verdammt, jetzt habe ich hier auch einen stehen! :phat:
Bin sehr angetan von dem Teil und finde das Bedienungskonzept ziemlich intuitiv und die Soundergebnisse ungewöhnlich. Sowas habe ich hier noch nicht.
Mein S-4 (V2.0) hat aber manchmal Startprobleme, d.h. das Display geht an, aber es erscheint nichts darin. Wenn man dann "blind" auf dem Master-Encoder drückt und unten rechts mit "yes" bestätigt, fährt der S-4 auch wieder runter, scheint also irgendwie schon da zu sein. Meistens bootet der dann danach wieder normal. Ebenso hatte ich, dass das Teil, ohne etwas damit zu machen, irgendwann komplett eingefroren war. Allerdings würde ich nicht ausschließen wollen, dass ich durch einen Bedienfehler das Master-Resampling ausgelöst habe und möglicherweise das Teil einfach vollgelaufen ist.
Wie sind denn die Erfahrungen hier so? Ich bin mir nicht sicher, ob ich sowas schon auf eine Bühne mitnehmen wollte. Ich hoffe aber, dass der Hersteller dran bleibt, denn das Teil ist es das wert.
Update: Ich kann ausschließen, dass das Einfrieren durch Resampling und vollgelaufener S-4 passiert. Mittlerweile habe ich eher MIDI im Verdacht, da mein S-4 momentan im Verbund läuft. Hat hier jemand nicht ähnliche Erfahrungen oder läuft das Teil bei euch superstabil?
das Einfrieren beim Start (dunkles Display) tritt selten auf, das gab es mit Version 1.2.2 nicht. Midi ist es nicht, habe ich den S-4 z.B. nicht mit Midi + USB verbunden, kann es auch vorkommen. Das muss eher was mit dem Boot Vorgang vom neuen 2.0 OS zu tun haben. Ansonsten läuft das Ding stabil.
Aber da du den S-4 auch hast, frage ich mal: alles schön und gut mit den neuen Funktionen im 2.0 OS, aber das Torso das Tape-Device wieder abgespeckt hat, ist nicht gut, oder? So mache ich fast alles im Disc Mode, da hier einfach mehr Funktionen sind (und leider kein Overdub...). Vor 2.0 konnte man einfach mit einem aufgenommenen Take in den Poly Modus wechseln und diesen dann 8 stimmig spielen. Könnte was mit der unendlichen Recording Zeit im Disc Modus zu tun haben, da der Buffer im Tape Modus nur 30 sec hat. So muss man immer den Weg über das Zwischenspeichern des Samples machen und dieses dann in den Poly Mode laden.
Aber den Wechsel zwischen 30sec Tape und Poly könnten sie wieder einführen. Und mehr Material Modes wie Sclice-Mode oder Spectral wie beim GR-Mega, sowie 24/12dB analog style Filter z.B. , oder Paser/Flanger, im Tape Modus Wow/Flutter/Drop Out FX etc -- aber ich denke, da kommt bestimmt noch einiges mit weiteren Updates.
Der S-4 ist ein wenig wie Sugar Bytes Graindead oder Output Portal in Hardware Form mit 4 Tracks 🙂
Ja, das kann ich bestätigen. Eigentlich läuft es schon ziemlich stabil, aber leider nicht 100%. Und so lange ich nicht weiß wo das herkommt, weiß ich auch nicht wie ich es irgendwie umgehen kann.
Ich bin ja quasi erst seit zwei Tagen dabei und direkt mit 2.0 eingestiegen. Daher habe ich die fehlenden Funktionen nicht so mitbekommen, finde sowas aber ärgerlich und schwierig. Mir war z.B. nicht bewusst, dass man im Tape-Mode früher 6 Minuten aufnehmen konnte oder auch in den Poly-Modus wechseln so dass das Sample übernommen wird. Vor 2.0 gab es wohl auch 128 Grains anstatt jetzt 64.
Wenn ich das richtig verstanden habe, haben die die Firmware noch mal neu geschrieben. Da kann man nur hoffen, dass einige Dinge die es schon gab, später noch mal nachgeliefert werden
Mir würde vorerst schon reichen wenn das was da ist vollkommen stabil funktionieren würde. Mich stört momentan auch, dass der Looper, je nach Material, an den Loopenden knackst. Sowas geht nicht. Gegen weitere Funktionen habe ich natürlich trotzdem nichts einzuwenden.
Btw. Wow & Flutter kann man wunderschön simulieren, indem man mit einem geglätteten Zufallsmodulator leicht den Direction-Parameter moduliert. Das habe ich zufällig eben gemacht. Klingt ziemlich authentisch und nur Dropouts fehlen noch. Die könnte man vielleicht mit einer einer zweiten Zufallsmodulation auf Volumen hinbekommen.
Ich finde das Teil ja eigentlich phänomenal, aber die Bugs müssen die in den Griff bekommen, sonst habe ich kein Interesse daran.
Portal habe ich, aber Graindead kannte ich noch nicht und muss ich mir mal anschauen - danke für den Tipp.
Hab seit Januar eine S4.
Ich kannte alle Probleme auf discord und auch die langsamkeit von firmware bug patches seitens torso und hab mich mental darauf eingestellt.
Mein Gerät hat tatsächlich wenige der richtig fiesen Probleme. Random restarts, crashes, bricked, Projekte verloren usw. hatte ich nicht bis sehr wenig.
Konzept & Features, Spaßfaktor, Desing & UI - alles fein. Das ganze Ding ist echt eine gute Idee und das "Sculpting" label passt. Hab mich selten so angenehm in einem Sampler mit sounddesign verlieren können.
Die nun fertigen Bereiche Perform und scenes sind prima! Klar, durchdacht, viel potential für Kreativität mit genau der richtigen Menge an features, nicht zu viel, nicht zu wenig.
Die ganzen Ambient flächen videos tun der S4 keine Gerechtigkeit. Da geht so viel mehr, je nach sample halt.
Die s4 ist die perfekte "Organische" Ergänzung zu meiner Digitone 2.
ABER: Meine Geduld ist am Ende mit 2.0.
- Das ganze ding ist instabiler als zuvor. Midi sync in hard-crashed das Gerät nach 30min bis 1h. Repeatable und von vielen Nutzern reported.
- Black screen bei startup, kabel raus kable rein nötig
- eine neue Player maschine die nichts wirklich neues bringt, die meiner meinung nach völlig unnötig ist in Anbetracht der ganzen bugs.
- Midi timing ist konstant 16ms off. (lässt sich nachvollziehen indem man sample starts in der s4 manuell um 16ms verschiebt) hören die schlecht in der QA oder was?
Support sagt die stabilität, freezes und timing haben hohe prio für das nächste update. ich glaub nicht mehr dran dass da zeitnah was kommt.
Wenn das Gerät in 2 Jahren mal ausgereift ist, kauf ich mir wieder eine.
Schade, dass solche Probleme einen den Spaß verderben. Ich finde den S4 super interessant und hoffe, dass sie die Stabilität der Software in den Griff bekommen. Ja und Sync wäre natürlich ein Muss.
Kann ich leider alles nur so bestätigen. Da meiner noch neu ist, kann ich den noch zurückgeben, ringe aber mit mir, weil - wenn es läuft - ist es der Kracher. Ich kenne da auch nichts vergleichbares. Echt schade.
Zum Thema Blackscreen - da gab es doch ein Script was zumindest das Problem beseitigen soll. Ich habe das noch nicht gemacht, weil ich momentan keinen freien externes USB-C Stick habe. (siehe https://discord.com/channels/989426604172279858/1239590444543905895 )
wie gesagt, der killer für mein setup ist das syncing. ohne das verliere ich meinen gewünschten anwendungsfall.
braucht man das nicht, kann man stabiler per analog clocken oder ist fein mit den freezes, ist schon wieder eine menge gewonnen. ich hab einfach keine lust mehr auf irgendwas zu warten jetzt und verkaufe die box nun. vielleicht kommt in einem monat ein patch und dann ahbe ich halt pech gehabt.
Ja, geht mir letztlich auch so und wahrscheinlich nutzen auch die meisten das Teil irgendwie gesynct. Wenn man wenigstens wüsste, was genau das Problem auslöst. Ich hatte neulich mehrere Stunden daran gebastelt, mit einem Digitakt als Master und keine Probleme gehabt. Dann mal 15 Minuten aus dem Studio gegangen ohne dass was lief und nach der Rückkehr war das Teil plötzlich eingefroren.
Mich stören zudem noch immer wieder auftretende Knackser nach gesampelten Material, die man auch nicht wegbekommt. Da ist noch viel Luft nach oben 😟
