ANTS modular synth auf Kickstarter
P
ppp
(hoffe ich bin im richtigen subforum)
https://www.kickstarter.com/projects/pl ... ynthesizer
Ants! is:
Analog: true analog electronics and sound.
Modular: connect the different parts and functions with standard 3.5mm pacth cords to create from classic to weird and new sounds.
Affordable: Ants! retail price will be 480€. Just a fraction of the cost of a basic eurorack modular system.
Compatible: 100% compatible with the eurorack voltage system and patching cords. It can be expanded it with most of the eurorack modules available in the market.
Portable: small size and desktop format.
Big: despite the small size Ants! have a lot of features which make it very powerful and versatile. Much more than a basic modular system.
Features:
4 Oscillators: yes, 4! V/Oct triangle-core oscillators. 2 of them switchable to LFO. Combining sinusoidal, triangle, saw, square and pulse with PWM. Play chords, detuned basses, octaved leads, drums, and frequency modulated sounds.
2 LFOs: 2 low frequency oscillators with triangle, square and pulse outputs.
VCF: switchable analog 12dB low-pass / 6db high-pass filter with resonance. At high input volumes it distort the signal. Self oscillating. It can sound crystal clear or really dirty.
2 A/R envelopes: 2 attack - release envelopes with manual and external controls. Working at different times.
Mixer: 3 input mixer. Mix oscillators, envelopes, noise or any other AC or DC signal.
2 VCAs: control the level of the signals with 2 analog VCAs.
Noise: a white noise source!
Sample and Hold: create random voltages, stepped sequences or dither your sounds or even your own voice.
AND gate: logic AND gate. Combine oscillators to create new waves, combine LFOs to create different patterns or mix your control signals to create complex modulations.
MIDI to CV: connect any MIDI keyboard, sequencer or computer and transform the digital signal to analog voltages for controlling the synth.
49 patch points, 28 potentiometers, 5 switches and 8 leds.
Normalized: Some connections are already made between some functions. Just connect your Midi or CV controller and play the synth without patching it. You can break any connection by plugging a patch cord to the normalized input.
sieht vielversprechend aus. Sozusagen die East-Coast version des 0-Coast (der ja West-Coast ist). Und zum selben günstigen Preis.
Wenn ich das richtig verstanden habe, ist er (halb-)modular (Definitionsfrage!), funktioniert über die Normalisierungen aber auch ohne Kabel.
Das kann Dir niemand beantworten, der das Teil nicht in der Hand hatte.
Aber es ist davon auszugehen, dass VCOs in VCF in von EG modulierten VCA funktioniert, also der klassische "East Coast" Synth.
Kein Sync der Oszillatoren, keine niederfrequenten Sägezahnschwingungen, keine invertierten Hüllkurven.
Ein Mischer zu wenig: Entweder hat man nur einen Modulationseingang für das Filter, kann dafür aber über den 3-auf-1-Mischer alle 5 Klangquellen (4 VCOs + Noise) in das Filter leiten, oder man kann das Filter von drei Quellen modulieren, darf dafür aber nur zwei Signale filtern.
Die normalisierten Verbindungen sind:
XTOSC·Y square wave --> VCF in1
OSC·X saw wave --> VCF in 2
VCF out --> VCA2 in
MIDI TO CV gate --> A/R ENV 1 gate
A/R ENV 1 out --> VCF cv freq + VCA2 cv in
Z noise --> S/H sig
XTOSC·X square wave --> S/H clock
Warum nicht auch gleich die Steuerspannung des MIDI TO CV an die in das Filter normalisierten Oszillatoren normalisiert wurde, ist mir schleierhaft. Ebenso fehlen LFO X auf PWM von XTOSC·Y, sowie LFO Y auf die CV-INs von OSC·X.
Leider sind die Normalisierungen auf der Frontplatte nicht erkennbar, aber das Frontplattendesign soll ja noch geändert werden: "Front panel: Some labels from the front panel need some changes in order to be more intuitive."
Und so könnte man weiter machen: Wenn schon ein Multimode-Filter, warum dann nicht auch als Bandpaß schaltbar? Warum sind die Hüllkurven nicht loop-bar? Ist es ein Fehler, dass die Hüllkurven nicht auch als Attack-Decay arbeiten können? Wird das MIDI-to-CV-Interface auch Portamento beherrschen?
Aber: Für rund 560 € scheint das meiner Ansicht nach trotz aller Kritik ein tolles Angebot zu sein, das preislich gleichauf mit dem Makenoise 0-Coast für 575€ liegt.
Bin mal gespannt wann der Ants endlich erhältlich ist.
Und vor allem wo. Interessante Kiste.
