activeroot=rescue bootpartition=boot0 board_rev=v3.1 conf=esp5 rcutree.kthread_prio=95
Feb 27 17:26:04 machbike0 kernel: Booting Linux on physical CPU 0x0000000000 [0x410fd034]
Feb 27 17:26:04 machbike0 kernel: Linux version 6.12.34 (oe-user@oe-host) (aarch64-esp5-linux-gcc (GCC) 13.2.0, GNU ld (GNU Binutils) 2.42.0.20240216) #1 SMP PREEMPT_RT Mon Jun 30 15:39:32 UTC 2025
Feb 27 17:26:04 machbike0 kernel: KASLR disabled due to lack of seed
Feb 27 17:26:04 machbike0 kernel: Machine model: MB Release
Feb 27 17:26:04 machbike0 kernel: Reserved memory: created CMA memory pool at 0x00000000c1000000, size 960 MiB
Feb 27 17:26:04 machbike0 kernel: OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
Feb 27 17:26:04 machbike0 kernel: OF: reserved mem: 0x00000000c1000000..0x00000000fcffffff (983040 KiB) map reusable linux,cma
Feb 27 17:26:04 machbike0 kernel: NUMA: Faking a node at [mem 0x0000000040000000-0x000000023fffffff]
Feb 27 17:26:04 machbike0 kernel: NODE_DATA(0) allocated [mem 0x23efaeb00-0x23efb177f]
Feb 27 17:26:04 machbike0 kernel: Zone ranges:
Feb 27 17:26:04 machbike0 kernel: DMA [mem 0x0000000040000000-0x00000000ffffffff]
Feb 27 17:26:04 machbike0 kernel: DMA32 empty
Feb 27 17:26:04 machbike0 kernel: Normal [mem 0x0000000100000000-0x000000023fffffff]
Feb 27 17:26:04 machbike0 kernel: Movable zone start for each node
Feb 27 17:26:04 machbike0 kernel: Early memory node ranges
Feb 27 17:26:04 machbike0 kernel: node 0: [mem 0x0000000040000000-0x000000023fffffff]
Feb 27 17:26:04 machbike0 kernel: Initmem setup node 0 [mem 0x0000000040000000-0x000000023fffffff]
Feb 27 17:26:04 machbike0 kernel: psci: probing for conduit method from DT.
Feb 27 17:26:04 machbike0 kernel: psci: PSCIv1.1 detected in firmware.
Feb 27 17:26:04 machbike0 kernel: psci: Using standard PSCI v0.2 function IDs
Feb 27 17:26:04 machbike0 kernel: psci: MIGRATE_INFO_TYPE not supported.
Feb 27 17:26:04 machbike0 kernel: psci: SMC Calling Convention v1.2
Feb 27 17:26:04 machbike0 kernel: percpu: Embedded 22 pages/cpu s50608 r8192 d31312 u90112
Feb 27 17:26:04 machbike0 kernel: pcpu-alloc: s50608 r8192 d31312 u90112 alloc=22*4096
Feb 27 17:26:04 machbike0 kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Feb 27 17:26:04 machbike0 kernel: Detected VIPT I-cache on CPU0
