Hohner HS-2/E (iPD Synthese)
Dass man diese hier noch ausgräbt ;-)
Ich habe den Synth dann doch verkauft. Es war mir zu (zeit)aufwändig die Sounds zu programmieren, obwohl man aus dem Kasten in der Tat sehr Interessantes rausholen konnte.
hier in der CZ/VZ Yahoo-group gibt es eine neue Version eines Casio VZ / Hohner HS2 Editors für Midi-Quest:
https://groups.yahoo.com/neo/groups/CZ-VZ-Files/conversations/messages/329
Die bestehende Anpassung wurde stark überarbeitet.
MidiQuest ist natürlich erforderlich. So wie es aussieht, ist dies momentan eine der wenigen, wenn nicht die einzige, voll funktionierende Editor-Lösung für die VZ-Synths.
- added a more sophisticated „matrix“ for module/line/mode selection with graphical visualization of the signal flow, with ON/Off and SOLO buttons for modules, better module selection and more
- fixed a lot lot of controls that were inverted (i.e. the master level was max. at 0 and min at 127, and many more)
- fixed the range and resolution for a lot of parameters that use the 0..99 range instead of 0..127 (using maps) - now the editor values are the same as shown on the VZ-display
- automatic setting of note-ranges for the Key Follow parameters - they should not overlap, because in some cases the VZ rejects such sysex-data.
- changed the overall design, arranged all parameters in a more logical way, replaced envelope- knobs with numeric controls, added a visualization for LFO wave forms.. and a lot more
- added horizontal sliders for setting the envelope end steps
- added initialization macros for more reliable switching of play-modes
- added a „Voice Init“ button - be careful, it sets all values to defaults
- added dedicated buttons for activating the current play mode in the respective editor panels (normal, operation, multi - if this does not happen automatically, which it normally should do)
- changed a lot of parameter names, which were strange or simply wrong (i.e Pos X-Fade instead of „effect“ and many more)
- added a script to automatically set the modules pitch range and direction depending on the setting of „Fix Pitch“
- changed the overall layout and some parameter names in the Operation and Multi panels
