Habe die Prozedur als Dokument auf der Festplatte zu liegen. Für alle Fälle sozusagen.
TUNING PROCEDURE, THIRD VERSION
The arrangement of the trimpots is as follows: each row pertains to each oscillator, the top is OSC1, middle is OSC2, bottom is OSC3. From the right, the 1st trimpot is SHIFT (also known as RANGE), the next is OCTAVE, the next is SCALE, and the fourth is HI END.
Only the SHIFT, OCTAVE, and SCALE trimpots are accessable through the access holes on the rear cover. If the Minimoog is below serial #10175 and you have the third version board, there may or may not be new access holes drilled out for OCTAVE.
Set the front panel controls as follows:
TUNE=0
GLIDE=0
PITCH WHEEL=CENTER (detent)
MOD WHEEL=OFF
OSCILLATORS
OSCILLATOR MOD=OFF
OSC 3 CONTROL=ON
ALL OSC RANGE SWITCHES=16
ALL OSC WAVEFORMS=RAMP
OSC 2 RANGE=0
OSC 3 RANGE=0
MIXER
ALL OSC MIXER VOLUME=7
NOISE/EXT IN=OFF
FILTER
FILTER MODULATION=OFF
KEYBOARD CONTROL 1=OFF
KEYBOARD CONTROL 2=OFF
CUTOFF FREQUENCY=(+)5
EMPHASIS=0
AMOUNT OF CONTOUR=0
CONTOURS
ATTACK=1M
DECAY=1M
SUSTAIN=10
MAIN OUTPUT VOLUME=10
MAIN OUTPUT=ON
SCALE
OSCx=OSC1, OSC2, or OSC3
• Turn on OSCx in the mixer on the front panel. All other switches in the mixer should be OFF.
• Change OSCx RANGE switch on the front panel to 16.
• Hold down the LOW A key and adjust OSCx SHIFT trimpot for 55hz.
• Hold down the HIGH A key and adjust OSCx SCALE trimpot for 440hz.
• Repeat steps 29 and 30 until no further adjustment is necessary.
Repeat for each oscillator
HI END
• Change OSCx RANGE switch on the front panel to 2.
• Hold down the LOW A key and adjust OSCx SHIFT trimpot for 440hz.
• Hold down the HIGH A key and adjust OSCx HI END trimpot for 3520hz.
• Repeat steps 34 and 35 until no further adjustment is necessary.
Repeat SCALE and HI END sections until no further adjustment is necessary.
OCTAVE
• Change OSCx RANGE switch on the front panel to 32.
• Hold down the HIGH A key and adjust OSCx SHIFT trimpot for 220hz.
• Hold down the HIGH A key and adjust OSCx OCTAVE trimpot for 3520hz.
• Repeat steps 39 through 42 until no further adjustment is necessary.
SHIFT
• Hold down the HIGH A key and adjust OSCx SHIFT trimpot for 440hz.
