mikesonic
gerade eben entdeckt
mopho os 1.4.9
1. New Arp modes added
2. Sequencer Slew added
3. Encoder response improved
4. Ignore program change global option added
5. Program knob changes the value on the screen - this should make editing patches quicker, you can select the variable you want to change with any of the assignable parameter knobs and then change it using the program encoder
6. Tap tempo - Hold the assign parameters button and tap the push it! switch. Sequences will start on the 5th tap
7. Arp latch with the new global for pedal mode
8. Fixed a few smaller bugs
9. Fixed a bug that prevented the assign param encoders from calculating the max value of the param they're editing correctly
gibt es hier: http://prophet5.org/viewtopic.php?t=521
der link für nicht angemeldete funktioniert nicht !!!!
mopho os 1.4.9
