Through Zero VCO
Was sind eigentlich die Vorteile eines Through Zero VCO gegenüber herkömmlichen spannungsgesteuerten Oszillatoren?
Und zum FM-Modulieren benötigt man dann 2 Through Zero VCOs oder lässt sich ein einzelner Through Zero VCO auch
von einem "normalen" Oszillator ansteuern? Bzw umgekehrt?!
kurz:
- tonal spielbar
- ein thru zero osc klingt anders, als ein frequenzmodulierter oszillator, der sich nur im positiven bereich modulieren lässt
aus der bedienungsanleitung für DCAM synth squad (dort mit bild):
"Thru-zero oscillator FM
The term ‘thru-zero FM’ refers to the ability to modulate the frequency of an oscillator beyond zero into negative frequency values. Negative frequencies are vitally important for a stable pitch response with any possible amount of modulation, and is a prominent characteristic of the Yamaha DX-series’ implementation of FM. Cypher’s implementation gives you digital FM-style sounds rendered by a realistic analogue circuit model, with the convenience and polyphony of a software instrument.
Thru-zero FM is not usually possible with analogue oscillators – instead of the frequency travelling beyond zero when modulated, it simply stops at zero until the modulation causes it to rise into positive values again. The result is that, at harmonic ratios, the overall pitch that is heard is irregular at lower frequencies. Thru-zero FM allows for the timbre to remain harmonic at all frequencies even with very large modulation.
The following waveform plots show thru-zero and normal analog FM using a square wave as the modulator, and a sawtooth wave as the signal being modulated. While the square wave is high, the pitch of the saw is increased, and when the square wave is low the pitch is decreased.
0.51.01.52.0TimemS0.40.20.20.4VoltageV0.51.01.52.0TimemS0.40.20.20.4VoltageVThru-zero FM:The decrease in pitch results in a negative frequency, and the saw-up waveform becomes a saw-down waveform. A triangle waveform corner is created at the point of transition.Normal analogue FM:The osc is unable to produce a negative frequency when the pitch decreases. It becomes clamped at zero and stays constant until the modulator increases the pitch. The result is that the resulting pitch is not the same as the original saw wave.
There are currently some thru-zero analogue oscillators available for modular systems, such as the Cyndustries Zeroscillator. However, these tend to be rather expensive (especially if you need a polyphonic system) and there are still inherent problems such as the inability to achieve exact tuning ratios.
Thru-zero FM is very easy to implement on digital synths that use wavetable-lookup techniques, such as the Yamaha DX series. Cypher’s oscillator FM is capable of thru-zero FM using true virtual oscillators generated in real time, without using wavetable-lookup techniques (which cannot offer the same sound quality as a modelled analogue-style oscillator)."
Ich hatte mal einen Synthia through-Zero-VCO und kann vom erheblichen Patchaufwand nur abraten. Der hat zwar einen geilen Sound, aber der Modcan VCDO bringt einen schneller ans Ziel und hat dazu noch einen Quantizer sowie einen Modulations-VCO an Board. Go for Modcan! Eins der ganz wenigen Module die ich vermisse, seit ich mein 5 HE Sytem verkauft habe.
Bei analogen OSCs wäre noch wichtig, dass die Phasenlage starr ist, sonder hast du bei der FM immer 2 variable Parameter und die analoge OSCs haben ja oft weder Phasensteuerung noch starten sie immer mit der gleichen Phasenlage. Die lin. FM hilft bei der tonalen Spielbarkeit und der einfacheren Steuerung.
Freilaufend wird ja gern als super Feature genannt, hier wäre es doof. Deshalb sollte so ein Modul idealerweise auch die Phase im Griff haben.
Bernie hat doch vor einiger Zeit einen in Walhalla implantiert. Er wird Dir schon sagen können, was dieses Modul kann.
Das war mal der Meinige!
Kein Grund für Bernie, sein Wissen um dieses Modul nicht mit uns zu teilen.
Vielleicht ist er ja so freundlich und berichtet ein wenig tiefer über seine Erfahrungen.
Du hast vollkommen Recht und ich würde meinen dummen Kommentar gerne löschen.
Ich sehe keinen dummen Kommentar, nur eine kurze und grobe Einschätzung.
