Michael Burman
"back to the roots"Hässlich
oh man , was waren das für Zeiten als ich jedes Elektron Gerät bei Erscheinen faszinierend fand ... jetzt kommt nur noch Rotz
ja genau ... sollen se auch machen, aber weil ich eigentlich sowas wie ein Elektron-Fan bin, hätte ich mir was Innovatives gewünscht.Liegt sicher auch am Investor.
Strategie: Aus der bestehenden Investition / Technologie / SW-Basis maximal viele Produkte / Varianten herausholen um Kasse zu machen.
Dabei kommt dann sowas raus wie Model:Samples und Digitone Keys.
List of changes from OS 1.10A to 1.20
Improvements
Added support for Overbridge plugin.
Added Digitone Keys hardware support.
[Digitone Keys] Implemented USER mode functionality.
[Digitone Keys] Implemented hold functionality.
[Digitone Keys] Added MIDI Ext mode.
Improved Ratio B parameter scaling to enhance control when editing the parameter.
Added support for Sustain pedal (Sustain and Sostenuto CC) over MIDI.
Implemented Control All revert functionality ([MIDI] + [NO]).
Added functionality to randomize page parameters. [PARAMETER] + [YES] to randomize. [PARAMETER] + [NO] to reset PARAMETER page to its last saved state.
Implemented reload track Sound functionality. ([NO] + [T1-4])
Implemented reload Page parameters functionality. ([PAGE] + [NO])
Added the option to mute individual audio tracks from the main output, both on global and on pattern level. The global settings are found here: SETTINGS > AUDIO ROUTING. The pattern settings are found here: PATTERN > AUDIO ROUTING.
Added support for pattern mutes over NPRN.
Added support for playing chords with external MIDI keyboard/controller.
Implemented portamento functionality. The portamento parameters are on the TRIG page and the portamento settings are found here: SETTINGS > SOUNDS > SETUP > PORTAMENTO.
Implemented multi map functionality.
Modulation envelope delay is now reflected in the envelope graph.
Delay Time parameter values are now displayed as note values on relevant steps.
Implemented Undo functionality in the NAMING menu.
doch das Ding gibt es
ich fände es toll, wenn der Digitone mehr Machines (und Stimmen) spendiert bekäme
hoppla, ich lag falsch!
Was ist außer Keys und Knobs der Unterschied? Mehr Stimmen oder Tracks?
Keys/Pitch und Modulationrad
klar mit leicht umarrangierten Knöpfen, in Pissgelb und Kackbraun und der Fader ist dann vertikal eingebaut HURRAach menno, octatrack mk3 gibs wohl dann in 1-2 jahren :)
Und zwar in einem ganz neuen Formfaktor.Dikitakt mit Pads
