von der
produktseite:
Following specifications are preliminary and are subject to changes.
The Töörö is a polyphonic and multitimbral synthesizer module with 6 voices, 4 parts and a stereo signal path.
Sound Engine
Per voice:
Oscillators
Two 12bit digital oscillators with:
- waveform morphing
- factory and user tables
- additional sine modulator (for linear through zero phase modulation)
- auto-sync feature - hardsync
Filter
A single FL A847 optocoupler based 12dB/Octave low-pass filter with auto-oscillation and saturation features.
Shaper
A selection of shapers and filters algorithms from Fred's Lab.
Noise
A regular white noise source.
Ring modulator
An audio rate multiplication of osc1 output by osc2 output.
Envelopes
Two ADSR envelopes with hold stage and multiple triggering options.
LFOs
Two complex LFOs with various waveforms and their own AD envelope.
DCA
A digitally controlled attenuator with volume and panning control.
Per part:
MIDI channel selection, overall part volume and panning.
A syncable arpeggiator with multiple modes and patterns is included.
Global:
Multi-FX
A 12bit digital multi-FX module with:
- stereo ping-pong delay (with length, feedback and mix)
- chorus / flanger effect (with mode, speed and depth)
Instrument
Memory
The Töörö can store:
- 100 sound presets
- 10 multis
Connectivity
- 2 line-level unbalanced 6.35mm jacks (mix left & right)
- 2 instrument-level 3.5mm jacks for separate voice outputs (for voice 1-4 only)
- 1 DIN5 MIDI-IN
- 1 DIN5 MIDI-OUT (OUT + THRU configurable)
- 1 USB 1.1 B compatible port (for power and MIDI over USB)
- 1 power switch
UI
- 4 high-quality metal encoders
- 14 tactile switches
- dual digit 7-segment hexadecimal display
- 12 leds
Mechanics
- aluminum industrial enclosure
- quality rubber feet
- 170 x 120 x 45 mm
- 750 grams
ueberblicks-video mit prototyp (en francais - aber auch mit rudimentaeren franzoesischkenntnissen verstehe ich erstaunlich viel - das standard-synth-vokabular ist halt sehr aehnlich. man muss eigentlich nur wissen, dass "numérique" digital heisst
