Tempera - Granularsynth
... kann hier bitte jemand gelegentlich die aktuelle FW verlinken und ein paar Infos dazu einstellen??
Ich hab's mir mit Discord verdaddelt und komm dort seit der 2.1beta9 nicht mehr rein...
Mein Fehler, ich meinte die 2.2beta9, dann gibt es wohl noch nix neueres.
Weil es gerade Thema war... :xenwink:
Andre22:20​
Hello fam!Hope you're having a pleasant early week! A fresh Tempera v2.2-beta10is ready:
  • Polished when an emitter finds itself behind a held key when the overlay keyboard is hidden, that key is transluscent and the emitter can be seen through. It is up for consideration whether this works, and/or if this should be tweaked further.
  • Support brand new crash reporting mechanism -- as is widely appreciated, Tempera's firmware is pretty stable, but every once in a while a crash occurs. These are so few and far in between that they are hard to catch, reproduce and fix. Now when the firmware crashes, a hopefully useful information will appear on the displays. Please take a photo and post it in ⁠tempera or DM/email it. Each photographed crash will earn the reporter an intangible prize of gratitude!
  • New batch loading of samples: when loading an audio file into a track, a whole folder can be loaded in.
    • Inside the folder, each audio file, sorted alphabetically, will be loaded consecutively into the tracks starting from the one being loaded into. This means that if you batch-load into the first track, all 8 will be loaded in; but if you batch-load into the 3rd track, only tracks 3 4 5 6 7 8 will be loaded in.
    • This can take a while, please wait until the knob LEDs finish blinking
    • The tracks are loaded in auto-trimmed to their length or ~11s, whichever is smaller
    • The tracks are set to BPM/Hz if it's indicated in the filename (⁠news-and-updates⁠)
  • Tweaked on-grid PolyAT is tweaked in sensitivity. It is now both faster but also more volatile. In particular please note the before and after (I think this might be too sensitive).
If you find the time, please give it a go and report feedback
Download the firmware here: https://fw.beetlecrab.audio/tempera/tempera-2.2-beta10.firmware
Upgrade instructions same as before, two posts up
