Tempera - Granularsynth
  • #123
... kann hier bitte jemand gelegentlich die aktuelle FW verlinken und ein paar Infos dazu einstellen??
Ich hab's mir mit Discord verdaddelt und komm dort seit der 2.1beta9 nicht mehr rein...
  • #126
Klasse, dankeschön!! 👍
Mein Fehler, ich meinte die 2.2beta9, dann gibt es wohl noch nix neueres.
  • #128
Weil es gerade Thema war... :xenwink:
Andre22:20​
Hello fam!Hope you're having a pleasant early week! A fresh Tempera v2.2-beta10is ready:
  • Polished when an emitter finds itself behind a held key when the overlay keyboard is hidden, that key is transluscent and the emitter can be seen through. It is up for consideration whether this works, and/or if this should be tweaked further.
  • Support brand new crash reporting mechanism -- as is widely appreciated, Tempera's firmware is pretty stable, but every once in a while a crash occurs. These are so few and far in between that they are hard to catch, reproduce and fix. Now when the firmware crashes, a hopefully useful information will appear on the displays. Please take a photo and post it in ⁠tempera or DM/email it. Each photographed crash will earn the reporter an intangible prize of gratitude!
  • New batch loading of samples: when loading an audio file into a track, a whole folder can be loaded in.
    • Inside the folder, each audio file, sorted alphabetically, will be loaded consecutively into the tracks starting from the one being loaded into. This means that if you batch-load into the first track, all 8 will be loaded in; but if you batch-load into the 3rd track, only tracks 3 4 5 6 7 8 will be loaded in.
    • This can take a while, please wait until the knob LEDs finish blinking
    • The tracks are loaded in auto-trimmed to their length or ~11s, whichever is smaller
    • The tracks are set to BPM/Hz if it's indicated in the filename (⁠news-and-updates⁠)
  • Tweaked on-grid PolyAT is tweaked in sensitivity. It is now both faster but also more volatile. In particular please note the before and after (I think this might be too sensitive).
If you find the time, please give it a go and report feedback
Download the firmware here: https://fw.beetlecrab.audio/tempera/tempera-2.2-beta10.firmware
Upgrade instructions same as before, two posts up
M.i.a.u.: j3122
  • #129
NEW BETA!
Hello dears, a nice Saturday deserves a nice Tempera beta firmware. Thank you for the testing and bug reporting, a few improvements and fixes are ready: v2.2-beta12
  • Fixed wrong MIDI channel handling introduced by previous beta, channel 16 should now be working fine again
  • FIxed bottom brackets indicating BPM quarter notes in <:Tracks:1213121087605571614> Trim are now always shown
  • Fixed a source of live grains glitching sound, hopefully the last
    :crossed_fingers:
  • Improved when one of the step sliders in Step LFO is turned, a temporary big slider with indicated value appears, in addition to information on number of steps. The resolution of the steps has been clamped to 3 decimal points to allow for predictable value entry. The big slider will disappear after a second of not turning the knob, but can be made to disappear sooner by pressing eg. Scroll button momentarily
    :mag:
    :control_knobs:
  • New function: Merge canvas. Instead of loading the whole canvas, a
    :white_circle:
    + Load (which changes text to Merge) will load the canvas without audio files.
    :arrow_right:
    :arrow_left:
Firmware is available for for testing here: https://fw.beetlecrab.audio/tempera/tempera-2.2-beta12.firmware
Firmware instructions the same as before, please report any bugs, crashes or quirks found!
:hammer_and_wrench:
:microscope:
:racing_car:
M.i.a.u.: j3122
  • #131
... kann bitte bitte jemand Infos zur v2.2-beta13 geben??
An die FW komm ich ran, weiß aber nicht was sich geändert hat...
  • #132
Andre29.05.25, 17:03​
Hello, it's almost the end of the week which means time for another Tempera beta firmware v2.2-beta13:
  • Fixed small Emitter MIDI bug where under some circumstances Out needs to be toggled as well in order for Into work,
  • Fixed hopefully a Step LFO bug where sometimes a deactivated step would play out. In other words, if the total Lengthis 8, sometimes the 9th step would play.,
  • Polished Max volume parameter now applies a stronger attenuation.,
  • Implemented external MIDI PolyAT. Since we're very happy with Tempera's grid PolyAT pressure response, Tempera now also listens to polyphonic pressure from an external MIDI keyboard. Bring out your Linnstruments and Osmoses, (disable full MPE
    ) and map an axis on a parameter
    :Keyboard:
The beta firmware is available for downloading here: https://fw.beetlecrab.audio/tempera/tempera-2.2-beta13.firmware
  • Place the downloaded firmware file on an SD card or USB flash drive
  • Insert it into Tempera and turn Tempera on while holding the Round button
  • Follow instructions on the displays,
Upgrade instructions are the same as before two posts up, please report quirks, crashes and bugs!
M.i.a.u.: j3122
  • #135
Ich ergänze mal zum besseren Verständnis den von @j3122 geposteten Firmware-Link für die aktuelle Beta-Version, um den auf Discord beposteten Begleittext. Mit der aktuellen Version findet ein nicht ganz unerheblicher Umbruch im System statt.
Andregestern um 20:27 Uhr​
Hello friends!Long in the works, Tempera beta firmware v2.2-beta14 is ready.This one is a strange beta, and I recommend some caution with trying it out. Even very basic expectations like being in tune might break.With all the firmware additions, things started hitting the wall with available DSP power, and new optimization gains are becoming marginal at ever increasing effort. There's simply no more room for any additional processing.So in order to make room for new processing, this is an attempt to cheat by changing Tempera's DSP rates. The basic idea is that Tempera becomes a hybrid with all samples stored in 48kHz , while audio is processed at 41.4kHz(the number is not a typo). This seems like a neat solution for the following reasons:
  • Above best-case 20kHz, we were processing audio for nobody to hear anyway
  • Grains pitched higher simply use a higher mipmap so aliasing is not an issue
  • Grain pitched lower use the full (now defacto oversampled) original sample so high-frequency loss is not an issue either
  • This maneuvre saves everyone between 15% and 16% of DSP budget
  • No change to factory or user audio samples, your libraries and canvases remain as they were
This beta should verify that there is no regression, that things are in tune and overall functionality is retained. Well basically it is to verify that things have, in fact, not changed
Apart from a few bugfixes fixed along the way:
  • Fixed a bug where a BPM grain would decrease in volume with a higher note
  • Fixed a regress bug where BPM grains behaved weirdly with note vs cell sizes making percussive canvases wrong
  • Fixed the LP24 filter should now be better balanced in volume vs other filters
  • Fixed a bug introduced earlier which lowered the Global volume
  • Fixed gain on external mic is higher because it was too low
Grab your kilobytes here: https://fw.beetlecrab.audio/tempera/tempera-2.2-beta14.firmware , and please report bugs
  • #136
Andre16:58​
Hello fam
A small bugfixing update for Tempera with v2.2-beta15:
  • Fixed BPM-related trim markers both visually and in processing should be correct now @Sezare56
  • Fixed Step LFO in bipolar mode now shows -1 to 1 range when adjusting the step, instead of previously incorrectly 0 to 1 . Low hanging fruit from @TUAN 's massive list
  • Fixed Formant filter Emphasis not doing anything. Also from @TUAN 's list
  • Adjusted internal microphone's frequency response slightly
Download here: https://fw.beetlecrab.audio/tempera/tempera-2.2-beta15.firmware
Report any odd sightings and unidentified audio phenomena
M.i.a.u.: j3122
  • #138
Andre15:56​
Hello friends,another small but nice Tempera firmware v2.2-beta20:
  • Fixed an ancient bug where RelX and RelX would not be reset when loading an ancient canvas (such as Empty.canvas). Thanks @Sally @Petrolivio for finding this
  • New euclidean Rotate function: holding the Round button and turning the knob will adjust the rotation/offset of the steps
  • Improved during testing the new Rotate function I thought it was easy to get lost in the squares. Now there's a realtime running playhead across the steps, so this Euclidean thing has now become our "sequencer at home"
Grab the firmware here: https://fw.beetlecrab.audio/tempera/tempera-2.2-beta20.firmware , please test and report
M.i.a.u.: j3122
  • #139
Andre19:18​
Hello fam!It's a good day for a new Tempera beta firmware, this time a release candidate for the production v2.2. So, welcome v2.2-rc1:
  • New set of patina effects: Age, Slip and Compress. These are meant to simulate collected dust, chipped and worn out paint
  • New MIDI control to trigger recording via MIDI. This is done by sending Note on and Note off events on the Emitter MIDI channel (used previously only to place emitters with notes, now renamed to Control MIDI channel). Send Note on 100/E6 to start recording the fist track, and Note off to stop recording. Other tracks are numbered consecutively, Note on 101/F6 for the second track, and so on.
  • Improved emitter volume is now audio-rate unlike previously being applied only when the grain is emitted
    This allows eg. for tremolo-type effects when modulated, individual AD/AR envelopes and so on.
  • Improved MIDI CC curve for grain cell length and density are hand-tuned by @Sally
  • Improved Overlay keyboard show/hide is now independent on the actual overlay mode @TUAN
  • Improved The colorsplash animation is tweaked slightly to fade to black more, and a new "scrensaver" mode is added where the touchgrid is simply turned off
  • Improved the Initial.canvas with a facelift
  • Fixed Reverse in Live grains being out of tune
  • Fixed Emitter copy/pasting bugs @Octobird @TUAN
  • Fixed Playhead in Track->Edit now displays correctly @TUAN
  • Maybe fixed blank screens bug fix attempted again but let's not pop the champagne yet
  • Probably fixed some sporadic crashes related to thread synchronization
Grab it here: https://fw.beetlecrab.audio/tempera/tempera-2.2-rc1.firmware
  1. Place the firmware file onto an SD card or USB flash drive
  2. With the storage medium plugged in, turn Tempera on while holding the round button
  3. Follow instructions on the displays
M.i.a.u.: hardberg
  • #140
Andregestern um 18:22 Uhr​
Hello all!Thank you for speedy bug reports, comments and discussions on the first 2.2 RC. We are go for Tempera v2.2-rc2:
  • New reverb. While Tempera has no ambition to provide the ultimate reverb, it should nevertheless work well in most common scenarios, including percussive inputs. The previous reverb was almost entirely thrown out (RIP
    ) and replaced by a completely new, more robust and better tuned model. It's not strictly neutral and has an opinion but fairly modest. The Diffuse parameter was removed in favor of a dedicated Predelayparameter. This expansion was made possible by the DSP savings from the earlier sampling rate changes.
  • New Record mode -> Replace-> Trim option which auto-trims the track so it fits the recorded audio
  • Fixed the Delay's feedback now fades out as expected when Coloris active
  • Fixed the patina effects should no longer decrease volume when Mixed in without any of the effects engaged
  • Fixed the Age effect now no longer enters uncontrollable self-oscillation
  • Fixed when switching recording tracks via MIDI, the new recording track now correctly begins recording from the beginning
  • Improved triggering recording via MIDI is now done only by Note on messages, once to start, again to stop
Grab it here: https://fw.beetlecrab.audio/tempera/tempera-2.2-rc2.firmware
Please give it a test and report anything odd
M.i.a.u.: hardberg, j3122, VEB Synthesewerk und eine weitere Person
  • #142
Andre17:49​
Hello fam!We're getting there I think, here's Tempera v2.2-rc3:
  • Fix attempt for most or all of the new crashes. Based on the crash photos they seem to be one way or another related to string concurrency race conditions
  • Improved LFO Free is renamed to Retrig for both synced and unsynced LFOs, this should be clearer
  • Improved grains are not emitted from a track if that track is being recorded into except Live Grains
  • Minor fix screensaver now kicks in a bit later just like before
Grab it here: https://fw.beetlecrab.audio/tempera/tempera-2.2-rc3.firmware
  • Place the firmware file onto an SD card or USB flash drive
  • With the storage medium plugged in, turn Tempera on while holding the round button
If you see any crashes in particular, but also any low hanging fruits to fix or improve don't hesitate to suggest
M.i.a.u.: mr.slow und j3122
  • #144
Ich fand das sehr interessant als das vorgestellt wurde.
Ist das sowas wie eine granulare groovebox? Ich habs schon wieder vergessen. Macht aber einen guten Eindruck.
Wie ist denn die Qualität? Wirkt das stabil?
Und wie gut reagieren die kleinen Pads auf die implementierten Funktionen?
  • #145
Die Verarbeitungsqualität ist ausgezeichnet und die Pads reagieren ohne spürbare Latenz.
M.i.a.u.: SirAdrianFish
  • #146
Andregestern um 20:35 Uhr​
Dear friends, bug bandits, dear feature request committee,
Today is the day the production Tempera v2.2 firmware is released.
Grab the v2.2 here https://beetlecrab.audio/tempera/support/
Updated manual here https://docs.beetlecrab.audio/tempera/
Decksavers are available on the store https://beetlecrab.audio/store
The biggest thank you goes to this community of various beetles and oh-so-many varieties of crabs. It took 20 beta releases and 3 release-candidates to get here. The bug hunting was indispensable and feature requests varied and colorful. Really, as you know, by far most things were in one way or another designed by you.
Inevitably, I think we have maxed out on everything that could be pushed in, so now we are free to fill all remaining cracks in idle CPU space by more modulator destinations (or other modulator addons), quality of life improvements and whatever seems like a good idea. If it fits and is a good idea, let's add it, no need for keeping a reserve for the future just in case.
Once again, great job everyone!
M.i.a.u.: j3122
  • #147
Der Flächenteppich kommt aus dem Tempera. Sehr schön!
M.i.a.u.: noise_level_11 und TopperHarley
  • #148
Andre​
Hello fam!
The v2.2 was very well received and overall we are very happy with the state of the firmware. I consider it, broadly speaking, complete.
That being said, there are ideas that are simply too good to pass on, so now we're leaving beyond the horizon, into the open ocean. The firmware editions to come are going to be sort of between a beta and a production release, without a schedule or plan. You're welcome to participate in The Document . Please note that this is a community effort and I'm not the admin of the list, please ask the good people in ⁠tempera on what the etiquette is.
So, please welcome the new Tempera firmware: v2.2+a:
  • Hopefully Fixed ? regression bug where Note length grains on BPM tracks were too short, while on Hztracks they were too long.
  • New modulator destinations: modulate any other modulator's speed, size, phase offset, or attack and decay of AD/AR envelopes.
A few notes on the modulators modulating modulators:
  • Speed and Phase are also Attack and Decay/Release for AD/AR modulators respectively
  • If you try modulating a syncedLFO's Speed, it will immediately resync and jump in phase.
  • The UI indicators need some polishing, after initial unsuccessful attempts I've decided to publish without and leave it until the next edition
Please give this a test and report any bugs, quirks, and so on
Grab it here: https://fw.beetlecrab.audio/tempera/tempera-2.2+a.firmware
  • With the storage medium plugged in, turn Tempera on while holding the round button until the orange splash
M.i.a.u.: j3122
