Elektron Digitone (aktuelle Firmware: V1.42A)
Steht meines Wissens auch so in der Anleitung. Wird sicherlich einige sehr unzufrieden machen.
Jo, das wäre der extrem schade, zumal es am Digitakt geht.
Vielleicht schmeissen sie es ja beim nächsten SW-Update ausm Digitakt raus?
Und was ist ein "Quick-Note-Modus"?
das Handbuch sagt:
  1. Press [TRACK 1–4] to select the track to which you want to add note trigs and additional notes. A green [TRACK] key light indicates the active track.
  2. Press [RECORD] to enter GRID RECORDING mode. The [RECORD] key lights up red to indicate that GRID RECORDING mode is active.
  3. Press and hold (keep holding until step 8 of this procedure) the [TRIG] key to where you want to add, adjust or remove notes and then press [UP] or. [DOWN] A graphic mini keyboard appears
    at the top the screen. The leftmost number is the active note. The number in brackets shows the number of notes on the sequencer step. Then follows the note value of the active note. A lled key on the screen keyboard shows the active note and the other notes are shown as dots.
  4. Use the [UP] and [DOWN] keys to adjust the value of the note. Press and hold [FUNCTION] and press [UP] or [DOWN] key to adjust the pitch one full octave up or down.
  5. Press [YES] to enter a new note. Then again use the [UP] and [DOWN] keys to move the added note to the desired note value.
  6. Use the LEFT and RIGHT
    keys to navigate to a previously added note and then press [UP] or [DOWN] to move the note. Note 1 is the root note. The other notes are o sets to the root note. If you adjust the root note value, the other notes moves along with it.
  7. Press [NO] if you wish to remove an already added note.
  8. Release the [TRIG] key to Quick Note editing.
klingt gar nicht quick für mich
das Handbuch sagt:
Oh weh, das klingt nicht gut!
Danke trotzdem für das posten!
Hoffentlich wird das Teil gut. Einen solchen FM Synthesizer im "Groovebox-Format" mit guter Bedienung am Gerät selbst und sehr stabilem OS fände ich schon super.
Hmmmm, bei Thomann steht jetzt 2.2. als Lieferdatum...also heute! Dann müsste ich meinen ja dann theoretisch morgen kriegen...Auf der Produktseite steht aber 28.2.
Mal sehen.
28.02., wenn man jetzt bestellt. Vorbesteller bekommen dann wohl Ware aus der Erstanlieferung.
Also das Teil klingt jedenfalls schonmal ganz gut:
Das Delay und das Reverb klingen irgendwie auch besser als im Digitakt.
Trotzdem nichts für mich bei dem Preis.
Hier noch ein gutes Review mit vielen interessanten Details (auch zu FM):
Also Noten auf dem Midikeyboard spielen und Trig-Taste im Aufnahme-Modus drücken geht, aber die Notenlänge wird leider nicht übertragen. Vielleicht liegt es an mir, aber ich muss die Länge nachträglich mit Locks einstellen. Wie ist das eigentlich beim Digitakt?
Geht das mit der Notenlänge per MIDI Keyboard überhaupt bei den anderen Elektron Geräten? Bei der Machinedrum geht es auch nicht.
Mit dem Rytm habe ich es nie getestet, aber der Octatrack nimmt die Länge mit auf.
das geht nur im realtime-record .. im step mode machts nicht so richtig Sinn oder
Beim A4 ist es mit der integrierten Tastatur perfekt gelöst: Im Grid Mode wird die Note Length nicht ge-p-lockt, im Live-Recording Mode wird sie ge-p-lockt.
Kommt auf die Arbeitsweise an. Ich bin ein schlechter Keyboardspieler und möchte nicht alles nachträglich verschieben. Wenn ich genau weiß auf welchen Steps ich Noten in verschiedener Länge haben möchte nehme ich den Grid-Recording-Modus. Kann aber auch sein, dass ich es mir unnötig kompliziert mache.
Echt? Wie hast du das hinbekommen? Also nicht in diesem umständlichen Quick-Note-Modus? Beim DT: Record, Trig gedrückt halten und Taste(n) am externen MIDI-Keyboard drücken, loslassen, fertig. Das geht beim DTo so nicht. Jedenfalls nicht bei mir :shock:
EDIT: Hab es gerade nochmal ausprobiert. Es funktioniert tatsächlich wie du es geschrieben hast. Ist komisch, dass es gestern nicht ging. Auf Autokanal und das andere MIDI-Gedöns hab ich geachtet. Naja, egal. Es funktioniert und das ist gut so :frolic:
Ich spiele alle Synthesizer über den Octatrack und habe dort einen Midi-Track angelegt, der mit dem Autochannel vom Digitone (Kanal 10) übereinstimmt. Ansonsten einfach Grid-Recording, Step-Taste gedrückt halten und auf dem Midikeyoard spielen.
Ich habe es auch ohne den Octatrack dazwischen getestet und das klappt auch.
Das einzige was mich bis jetzt (dezent :mrgreen:) an der Kiste stört ist die blaue & graue Beschriftung - die ist bei geringem Licht nicht mehr lesbar.
Ich freue mich auf die Erstbesitzer!!
Könnt ihr mal einen Zwischenstand abgeben zu folgenden Punkten:
1.) Läßt sich aus dem Digitone einfacher ein gewünschter Klang entwickeln als mit anderen FMlern? Oder ist es mit dem Digitone genauso schwer Klänge zu erstellen?
2.) Wie klingt er? Druckvoll und breit, oder doch eher dünn und nach Plastik?
3.) Wie buggy ist der Digitone?
1.) Ich hatte nur den Yamaha TX81Z und dagegen ist die Bedienung am Digitone ein Segen.
2.) Der Klang ist sehr vielfältig und kann breit, druckvoll aber auch nach Plastik klingen ;-)
Klare FM-Glockensounds, warme Flächen, fette Bässe, Dub-Techno-Chords, Noise, Retro-Sounds wie z.B. Orgeltöne, 8-Bit-ähnliche Sounds, richtig gute Percussions.... alles möglich.
3.) Mir ist bewusst noch kein Bug aufgefallen, aber das heißt nicht, dass es keine gibt.
Für mich persönlich ist der Digitone eine geniale Techno-Maschine mit der ich unkompliziert zu guten Ergebnissen komme. Die Effekte gefallen mir auch richtig gut. Was mich allerdings am meisten überrascht: Man kann mit den 8 Stimmen unglaublich viele Sounds in die 4 Tracks legen bis die Stimmen verbraucht sind - das Teil geht eigentlich als Groovebox durch.
schön !
damit sind wohl die groben sachen über die ich heut bei elektronauts gelesen hatte wohl schon gefixt.
hatte mir dann deswegen meinen ( schon bezahlten) DN auf "stopp/und erst benachrichtigen lassen" setzen lassen.
um allenfalls auf nen zweiten batch auszuweichen
( die LED sache war da noch nicht klar zuzuweisen. software vs. harware problem )
