Online es gibt ein PDF manual. Ich glaube man muss es auf 1.2v/hz UND der gate auf S-Trig 15v pull up einstellen.
ANALOGUE CONNECTIONS
CV A & B(-3 volts to +8 volts)
- the control voltage output to control the pitch of most synths, such as Roland, SCI, and Moog, Korg
and Yamaha. When using this make sure that the correct scaling is selected ie volt per octave or Hz/v.
Connect this output to the input marked CV, oscillator, KBD IN, VCO CV in, VCO, KEY Volt in, etc., of
your synth.
CV x Gate Select (default: 5v pull-up)
- you can select the following type outputs for the Gate output;
S-trig no pull-up
This would probably be used for Moogs & Korgs.
S-trig 5v pull-up
S-trig 15v pull-up
This would probably be used on the Yamaha CS range of synths instead of the Gate output.
CV x CV/HZ Select ( Volt/Oct or Hz/V or 1.2V/Oct – default: Volt/Oct scaling)
- This is used to select the scaling system. Most synths will use Volt/Octave scaling, although most Korg
and Yamaha synths will require the Hz/V selection (note that the Korg Monopoly is Volt/Octave). For
the very few synths that employ 1.2V/Octave scaling (one tenth of a volt per semitone) the
1.2V/Octave mode should be selected.
