OnTopic Elektron Digitone II - 1.10B
  • #304
Firmware Update 1.10:
Improvements​
Added Overbridge support.
Added Chord modes (Root, Center, Spread & Memory).
Added the possibility to select if the SCALE parameter in the KEYBOARD SETUP menu should be set per track or per pattern.
Added the ability to preview a kit using [TRIG 1-16] when the kit is highlighted in LOAD KIT and KIT MANAGER.
An arpeggiator sequence can now be rotated with [FUNC] +/.
The arpeggiator SPEED option has been extended with some additional choices. Also some options are now renamed.
Added a method to swap tracks within a pattern. You find this functionality in the SETUP menu ([FUNC] + [FLTR]).
Added an option to overdub in Live Recording mode, meaning recording on top of an existing trig does not remove the overlapping notes.
Added the possibility to add parameter locks to all active trigs on a sequencer page or track by holding down a trig and then also holding [PAGE] or [TRK] while editing a parameter.
Added [TEMPO/METRONOME] + [YES] shortcut to quickly toggle the metronome ON/OFF.
Added tap tempo via MIDI note, using G10 on FX CONTROL channel.
Added support for importing legacy SysEx data.
Added support for exporting a previously imported project or preset with Transfer.
Added an option in the PERSONALIZE menu option for allowing live recording parameter changes/locks only to already existing trigs.
Added an option in the PERSONALIZE menu that is called TRACK SELECT that lets you decide how to select tracks and how that action relates to triggering the sound of the track.
The currently active search filter is now shown at the bottom of the screen when searching presets or kits.
Added snap values to the MOD destination list, holding [FUNC] while scrolling to snap to destination categories.
The latest selected version of MUTE mode (pattern or global) is now remembered between power cycles.
The MIDI machines SEL 1-8 and SEL 9-16 parameters now have unique default SEL CCs.
Improved [PAGE] LED luminosity contrast.
Minor UI change to the AUDIO ROUTING TO MAIN and AUDIO ROUTING TO SEND FX items in the SETTINGS > AUDIO ROUTING menu.
Allowed sorting notes by timing order as an alternative to by pitch in NOTE EDIT mode. Click on encoder E to sort the note list per pitch (from highest on top to lowest at the bottom). Click on encoder F to sort the note list per time (from earliest added on top to latest added at the bottom). A tiny arrow next to E or F indicates if sorted by pitch or by time.
Added a PERSONALIZE menu option to prevent unvoluntary access to NOTE EDIT outside of GRID REC mode.
Added a PERSONALIZE menu option for if notes are previewed/played or not when added in NOTE EDIT mode.
Added possibility to move a note row in note editor. [YES] selects a row and then you can use [UP]/[DOWN] to move it around on rows that have the same microtiming. Press [YES]/[NO] to deselect. This only works when sorting by TIME is used.
Added the possibility to transpose all Note trigs on the active sequencer page by using [TRIG 1-16] + [PAGE] + [+] / [-] in GRID RECORDING mode.
Bug fixes​
The unit could in some circumstances freeze, when using the arpeggiator.
The arpeggiator did not play the notes in the order they were inserted in TRUE mode.
Trig preview [TRIG] + [YES] was always using the default note length.
Test Mode incorrectly referred to [SAMPLING] button when pressing [VOICE] button.
NOTE EDIT mode ignored parameter locks/preset locks for the preview when adding notes and always played the track sound.
External MIDI notes could be added to incorrect track when in NOTE EDIT mode.
It was not possible to transpose trigs in octave steps.
VAL 9-16 parameters could be incorrectly activated on MIDI tracks after power cycling.
Track transposition using [FUNC] + [+]/[-] was not applied when in MUTE mode.
Clearing locks with [TRIG] + [PLAY] made the NOTE parameter lock and micro-timing indicator disappear, suggesting they were cleared even though they are not.
Transposing below lowest octave could cause the device to freeze.
In the Note editor, adding notes lower than F#0 could corrupt the mini keyboard.
The incorrect sound could sometimes play when using certain voices and settings in combination.
Pattern chains skipped the first pattern and song mode skipped the first row if the sequencer was running when the chain/song started.
AUDIO ROUTING > USB OUT set to EXT did not work as expected.
The Delay send effect had pitching artefacts during small tempo changes.
There was a slight stepping effect in certain ranges when adjusting or modulating the PAN parameter.
Tracks could under some circumstances trigger with incorrect note on release after external MIDI input.
CONTROL ALL CONFIG settings were not retained after power cycling.
SysEx import/export of presets did not work correctly.
There was a misleading error message when trying to back up imported legacy projects without first saving them to the Digitone II.
After changing TRIG mode while in STEP RECORDING mode, [FUNC] erroneously accessed quick mute mode.
The indicator for unsaved imported legacy projects (two small arrows next to the project name) was retained after deleting the project.
Clicks could occur at Note On messages using the Legacy LP/HP filter.
A set kit name was not remembered after changing pattern and then saving the same kit to another slot. Instead, the kit name defaulted to KIT.
A track with retrig enabled did not retrigger when triggered via external MIDI.
Loading kits to preset pool via PRESET/KIT -> MANAGE was broken.
The screen header disappeared in the LOAD PRESET view when no presets were visible.
Holding [UP] or [DOWN] to scroll was not functioning when selecting TRIG mode.
A parameter lock on the RTRG parameter remained active after deleting and re-placing a trig.
Preset preview could stop working after using [FUNC] + [YES] and [TRIG 1-16] interchangeably while in the LOAD PRESET menu.
Triggering a track while saving a preset played an unrelated preset.
LFO on MIDI tracks doesn’t work after switching to a MIDI machine.
Encoder input could carry over if the subpage was accessed using [UP/DOWN].
For some patterns in the PRESETS project, a couple of parameters that controls aspects of the external inputs were not set correctly.
Some Control All parameter positions were not consistent.
Some NRPN parameters regarding the Euclidean sequencer didn’t work as intended.
M.i.a.u.: klangsulfat und finderzh
  • #307
...ungewohnt, solche Streicher mal aus einem Digitone zu hören. Klingt mit dem Monologue einfach nur genial!
M.i.a.u.: studio-kiel, ganje und finderzh
  • #309
Der Kanal von HEXWAVE bietet mittlerweile einige Videos zum Digitone II
M.i.a.u.: Modulerche
  • #311
1.10A ist draußen (Bugfixes):
  • Preset locking an FM DRUM preset on an FM TONE track could cause the wrong graphics to be displayed on the PARAMETER pages.
  • In some rare cases, after converting a lock trig to a note trig, the trig could play back with an inconsistent note value.
  • Track layers were not swapped when performing a track swap.
  • Sometimes a preset’s name was lost after it was added to preset pool if the preset name contained lower case characters.
  • Adding parameter locks to all active trigs on a MIDI track did not work.
  • The SLEW parameter was missing in the modulation destination list.
  • SONG mode mutes were not swapped when performing a track swap.
  • The parameters on the SRC page were missing on the device after selecting a MIDI machine using Overbridge.
  • Removing send effects from main outputs, also removed them from their individual outputs.
  • Removing parameter locks on active MIDI trigs while holding [TRK] did not work.
M.i.a.u.: finderzh, Braunsen84 und Modulerche
  • #315
Mal ne Frage an die DToneII user:
Überlege mir, meinen Model:Cycles durch DTII zu ersetzen. Was mich bein M:C immer am meisten nervt ist, dass man aufgrund des winz-Displays (fast) nie sehen konnte, in welchem Pattern und auf welchem Track man gerade werkelt. Gerade bei Live-Jams mit viel realtime-Schrauberei eher unsexy (die LEDS unter den Pad- und Trig-Tasten sind sowieso viel zu dunkel und durch die Einfarbigkeit nicht sehr "auskunftfreudig):
M-C Display.png Nur in diesem "Main-Screen ist das sichtbar, sobald man in ein Menu abtaucht oder nen Regler befingert, verschwindet die A01-TR1 Anzeige 🙁
Jetzt habe ich mal schnell im DToneII manual geblättert und sehe auch hier, dass die Anzeige offensichtlich öfter keine Aussage zu Patternnummer- und Tracknummer macht - aber immerhin öfter als beim M:C.
Beim DTII zeigt das Display aber immerhin in so manchen Menus links oben das Pattern und darunter den aktiven Track an:
Wie ist da nun so der Usebility Faktor, gerade beim Live-Jammen bezüglich des Überblicks Pattern/Track eurer Meinung nach? Fehlt euch die Anzeige hier und da, oder sieht man genug? Auch ggf. zusätzlich ausreichend durch die LEDs im Pannel u./o. unter den Trig-Tastern?
Danke euch
  • #316
Ich organisiere Parterns so, das ich Tracks in Gruppen ordne und auf den gleichen Positionen lasse. Sonst kommt man schnell durcheinander
  • #317
@Plasmatron Meinst du mit Gruppen > Banks? Also pro Song/"Lied" alle Pattern innerhalb einer Bank, zB. Bank-A (Pattern 1-16)? mache ich auch so, aber das reicht zumindest beim M:C nicht, um den Überblick zu halten.
Und was meinst du mit ".... auf den gleichen Positionen lassen"?
Danke
  • #318
Danke
Nutze den Digitakt. Ich meinte mehr auf die Tracks innerhalb des Pattern bezogen, um da nicht durcheinander zu kommen. mache ja eher klassisch und tanzorientierten Trance. Da lege ich dann zb Kick Immer auf 9, Bass 10, harte Snare 11, Hihat 12 dann sind 13-16 die externen Midi Geräte, die dann aber auch fest vergeben werden. 1-4 sind Athmos und Effekte, 5-8 sind Beatpattern und Lead Sachen. So kann ich egel in welchem Pattern( meistens ) schon Muten ohne zu wissen, ob Bank 2 Pattern 6 jetzt auch das ist , was ich erwarte. Ich kenne meine Arbeit ja, aber Nummern kann ich mir nicht merken..
So eine reaktive Ordnung von Instrumentengruppen zu den Track Nummern geht prinzipiell ja auch bei anderen Musikrichtungen. Oder man denkt sich einen eigenen Code aus.
Aber ohne diese Ordnung wüsste ich auch nicht mehr, was jetzt genau in welchem Track steckt..
M.i.a.u.: 7cluster und deeptune
  • #321
Ola,
für mehr "Freiheit" habe ich mir für meinen neuen Digitone II folgendes Konverterkabel gekauft, um ihn auch an einem USB-Netzteil oder USB-Akku (= 5V) betreiben zu können (das Teil macht aus den 5V des Akkus bzw. USB 12V für den Digitone, gibt max. 1000mA ab, der Digitone braucht im Schnitt ~500 - 700mA > ~7Watt, passt also, laut Herstellerangabe des Kabels ist es für die Digi-Baureihe von Elektron geeignet):
https://www.thomann.de/de/myvolts_ripcord_12v_dc.htm
Nun kam das Teil, angeschlossen und hat gefunzt. Einmal für ca. 2h, danach nie wieder. Ich werd irre. Hab nachgemessen an der Ausgangsbuchse, da kommt auch im Leerlauf brav 11,8 Volt raus. Hab alles ausprobiert, mit Akku, mit USB-Netzteil - nix-nada.
Also bei Thomann um Umtausch gebeten, neues Teil angeschlossen und was ist? Geht auch nicht - nicht ein mal! Wie kann das sein, es ging doch - einmalig?!
Hat jemand von euch sowas an einem Digi-XY in Betrieb? Alternative?
Jemand ne Erklärung, wie das sein kann, dass es einmalig funktioniert und danach nie wieder?
Der Vollständigkeit halber: mein Digitakt II funktioniert mit dem mitgelieferten Netzteil natürlich einwandfrei.
Danke euch
  • #322
Ola,
Danke euch
Schließe mich der Frage an, meine beiden DT2 & DN2 portabel mit Akku betreiben zu können würde mich auch interessieren.
  • #323
Ola,
Danke euch
"Please note a USB port with power output of 2.4 amp is required for guaranteed continuous power."
Könnte darin das Problem liegen?
  • #324
Ola,
Danke euch
da wird dein USB Netzteil wohl "n Schlag weg ham"
nimm doch das Teil
https://www.thomann.de/de/myvolts_step_up_tip_12v_center_pos.htm und n vernünftiges USB-C Netzteil mit PD
  • #325
Woher kommt dieser Satz? Der Digitone wird ja nicht über den USB-B Anschluß mit Saft versorgt, sondern über den 12V DC Eingang. Und da stehen als Bedarf 1A drauf, was auch schon überdosiert ist, da er max. ~7Watt Leistung zieht, was bei 12V Spannungsversorgung ca. 0,6A sind!
  • #326
da wird dfein USB Netzteil wohl "n Schlag weg ham"
nimm doch das Teil
https://www.thomann.de/de/myvolts_step_up_tip_12v_center_pos.htm und vernünftiger USB-C Netzteil mit PD
In dem von dir verlinkten Teil steckt die identische Technik wie in meinem gekauften Kabel.
Und nein, "das" USB Netzteil hat keinen Schlag weg, der Laptop daran wird brav geladen.
Es geht auch primär um den Anschluss an einen Akku mit USB-Ausgang, das HATTE ja kurz mit Kabel #1 funktioniert, nach ~ 2h dann aber nie wieder und mit Kabel #2 überhaupt noch gar nicht. Und natürlich ist der Akku voll geladen und liefert auch max. die korrekte Menge Strom (~ 2,5A).
Noch jemand ne Idee?
  • #327
Nein, da irrst du dich:
+ How is it different to myVolts Ripcord?
myVolts Ripcord also allows you to power gear from USB, but Step-Up Power Tips take advantage of recent developments in USB power, allowing much more powerful gear to be powered simply. Ripcord could only power up to 12 Watts, but Step-Up can provide up to 8 times that wattage (100 Watts), under the right circumstances. As an example, the 12V Ripcord can power the Elektron Digitakt (12W). The 12V Step-Up can power the Elektron Digitakt, and it can also run the more power-hungry Elektron Analog IV with ease (18W).
+ How does Step-Up Power Tip work?
The Step-Up takes advantage of protocols called PD (Power Delivery) and QC (Quick Charge) present in USB power sources. These protocols allow a device to request a certain voltage (5V, 9V, 12V and even 15V or 20V in some cases) from a USB port. A Step-Up Power Tip connects to the power source, requests the voltage needed by your gear, and supplies it. Step-Up handles up to 100W - however, will only deliver what the PD / QC Source it's connected to can provide, so you do need to check the spec of your power source.
  • #328
Hm, das von mir gekaufte Kabel RipCord liefert bis zu 12Watt, der DigiTone braucht nur ~7Watt, da stimmt doch dann was nicht in den Speks oder? entweder zieht der Digitone wesentlich mehr oder der RipCord kann nur wesentlich weniger, als 12Watt - so ein Mist.
Die höheren Leistungsabgaben des StepUp Steckers werden eigentlich nicht für den Digitone benötigt. Muß ich den halt auch noch kaufen.... 🙁
  • #329
Durchschnittlich 7W schließt ja nicht aus, dass kurzzeitig deutlich mehr Saft gezogen wird. USB 2.0 liefert laut Spezifikation 2,5W (0,5A bei 5V), USB 3.2 schon 4,5W (0,9A bei 5V). D. h. am USB 2.0 Anschluss wird es deswegen vielleicht eng.
Spezifikation​
Spannung​
Strom​
Leistung​
USB 1.0/1.1​
5 V​
0,1 A​
0,5 W​
USB 2.0​
5 V​
0,5 A​
2,5 W​
USB 3.0/3.1/3.2​
5 V​
0,9 A​
4,5 W​
USB-BC 1.2​
ca. 5 V​
min. 1,5 A​
min. 7,5 W​
USB-Typ-C​
5 V​
3 A​
15 W​
USB-PD​
5 bis 20 V​
bis 5 A​
bis 100 W​
USB-PD 3.1​
28 bis 48 V​
bis 5 A​
bis 240 W​
Quelle:
M.i.a.u.: deeptune
  • #330
@Braunsen84
Es geht ja hier nicht um einen USB-Anschluß! (für mein Verständnis). Es geht um eine Stromversorgung aus einem USB-Akku, der (laut seinen Speks) min. 2.0A liefern kann; nachmessen kann ich das leider nicht.
Mein Elektron Model:Cycles funzt übrigens seit langem problemlos an eben diesem Akku, braucht aber auch nur 5Volt zum Betrieb, keinen Konverter dazwischen und zieht aber wohl nur ~0,75A. Nundenn - ich hole mir den StepUp-Stecker und schaue, obs dann funzt und werde berichten die Tage.
M.i.a.u.: verstaerker und Braunsen84
