Green Dino
X---X---X---X
Zeit zum Editieren ist abgelaufen, also neues Post. Das PDF von Korg ist schreibgeschützt deshalb musste ich an den PC um den Text zu kopieren...Aber was man anfängt, das macht man auch zu Ende.
Setting the MIDI channel of
each part
MIDI ch ................................................ 1...16
Here you can set the MIDI channel for each key-
board part and for the drum parts. The same MIDI
channel is used for transmission and reception. The
factory settings are as follows.
1. Press the Global key (it will light).
2. Use the [ ]/[ ] cursor keys to change the display
to read "MIDI ch."
3. Press the part key for which you want to change
the MIDI channel (the key will light). To change
the MIDI channel for the drum parts, press any of
the 13 part keys (all of the drum part keys will light).
4. Turn the dial to select the channel.
The MIDI channel for keyboard part 1 that you
specify here will also be used to transmit and re
ceive program changes and exclusive data ("Glo-
bal MIDI channel").
MIDI Utility
Here you can make MIDI filter settings, assign drum note
numbers, assign control change numbers, and transmit/
receive MIDI data
Assigning the drum note numbers
DRUM NOTE NO. ........................... C-1...G9
You can assign a MIDI note number (as a note
name) for each drum part. If you assign the same
note number for two or more parts, those parts will
sound simultaneously when controlled from an
external MIDI device.
1. Press the Global key.
2. Hold down the shift key and press step key 15
(MIDI UTILITY) (key 15 will blink). The param-
eter display will indicate "MIDI Util."
3. The value display will indicate "Filter." Turn the
dial to change this to "DrNote," and press key 15.
4. Press the drum part key whose note number you
want to assign.
5. The parameter display will show the name of the
selected drum part, and the value display will in-
dicate the corresponding number.
Turn the dial to select the desired note number. For
each drum part that you want to assign, repeat the
steps of selecting the drum part and then selecting
a note number.
6. When you have finished making settings, press key
15 to return to Global mode. (Key 15 will go dark and
the Global key will light.) If you decide to cancel, press
the STOP/CANCEL key or press a mode key.
each part
to read "MIDI ch."
bal MIDI channel").
MIDI Utility
receive MIDI data
want to assign.
a note number.
