Yamaha FM-Synthesizer Generation/s
Yamaha FM synthesizers. for yamaha EX and vector series scroll down..
find editors for your FM synth here
find a complete „how to make a bass with FM“ tutorial here / Tutorial für FM Bass Sounds hier..
Yamaha Synth overview..
yamaha dx5 synthesizer algo panel
FM SYNTH GENERATIONS
DX-TG-SY-FS-PLG —- the fm synthesis HISTORY @ yamaha
-1st generation DX series (80ies, a bit rough sounding 12bit converters): DX1,DX5, TX7, DX9, TX816 / TX216, DX21.
FM SYNTHS first generation
DX1, DX5 DX7 GS1/2
the gs1 and gs2 started it all with FM synthesis (simple „piano like“ combo keyboards, also the CE20 and CE25 combo simple-sizers.. not really worth a look these days.. shame on me for all vintage fm fans, but it’s just preset keyboards..)
– first there was the DX1 with a big algorithm display 1984, later the DX-5 (1985) and of course the DX7 (1983). they are all 6 OP FM synthesizer. the DX-1–:
dx1
DX1 pic by theo bloderer @ bluesynths.com
the biggest dx ever: incl a special algorithm display!....here’s a nice dx1 link… was very very expensive but had lots of displays and 76key keyboard. the reast qas identical to the
frequency modulation fm synth – how FM works?
please check the synth? menu
fm synthese: german/deutsch: wie FM synthese funktioniert unter synth? oder ausführliche erklärung FM Synthese erklärung
the speciality with yamaha is: you need to think different: the rates are „angles“,so 99 is the fastest possible rate! (don’t confuse this!)..
at the same time yamaha put out the 4 OP systems (cheaper), DX9 (1983) and later the DX21 that had split and dual mode like the DX5 and the poly mode only synths DX27, DX100 etc.. all 4OP synthesizers.
tx81z
more 4 OP synthesizers? the V50 workstation, DX11 (the first 4OP – multimode dx!), TX-81z (racked DX11),FB01 small module in a „cheap“ looking case. (smaller than 19″, not rackable but an expander)..
fm synthesizer yamaha dx-5
thx to PMM – twicethemovie – peter m mahr for DX5 images
also they introduced rack modules like the TX-7 (the non-rackable but desktop DX-7) and the big TX816 . it had lots of tf1 modules that represent ONE DX7DX-7’s in a rack!.. the TX216 had 2 TF1 modules 1985. each,so you could eqasily have 8
the dx or fm synthesis is well known for bell and rhodes sounds, but it can do much more than that!! or fm basses got popular in the 90ies ;) but autechre and other new electro bands showed there is another use of fm synthesis sounds!!
the first generation DX had 12bit DA converters, so you had aliasing and „hard“ sounding sonic „response“.
there were very strange models like the ys100 and ys200 (almost preset/simplified FM synthesizers), the 4OP workstation V50 and 6OP and 4OP synthesizers:
yamaha dx7 synthesizer
DX7, the legendary 12bit one..
click to enlarge
yamaha dx-7
the 4 OP DX frist generation , no velocity.. DX9
yamaha dx9<– enlarge the little brother DX-9 / 4OP
2nd generation (better DA on some models, still the most wanted generation for its „vitality“ of sound):
DX27, DX-27s/DX27L, DX100, FB01, DX-7IID, DX-7IIFD, DX7s, TX-802, TX81z, DX-11, V-50, TQ05 … 16bits AD from now! higher quality. on the DX7II / DX11/TX81z models.
Yamaha also put out the FB01
yamaha fb01 fm synth<–FB01 (thx joerg for pic)
very cheap 4OP synth with 8xmultitimbral synth. you can change everything as long as you use a software editor. but: well, for FM you should consider editor software anyway. the 4OP and 6OP Range also took place in Yamahas „keyboard“ range and some „exotic“ keyboards (cheap to mid price range). even sound cards..
yamaha dx100 synthesizer
click to enlarge the (4OP) DX100 (1985), it’s small enough…
yamaha cx5m standard
and CX5M II 128 msx computer with 4 OP-fm sound
yamaha cx5m msx computer with fm sound
click CX5M to enlarge..
there is a FM voicing card in the slot, you need the editor to change the sounds.. otherwise you need to program it yourself (if you know where to poke to?) ;)
yamaha cx5m II 128 msx computer with fm sound
click on the pic to see the CX5M II / 128
btw it stands on a GS2 2OP first FM Synth and the big full expanded TX816 with TF1 modules (each one is a DX7!)<— the GS2 looks like this
with the TX-816 on top –
the keyboards on the left are also used for the CX5M Computers..
3rd generation: 20 Bit AD Converters – HiEnd Sound
TG77,SY77, SY99 added samples (77:rom, 99: ram), designing your own algorithms and up to 3 feedbacks and nice spx like FX (spx1000 x2 on the SY99) and : from now on no1 could say FM sounds thin!! thats still refering to the 1st/2nd gen fm synths .. 20bit AD now.. more hi-end sound but some prefer the 2nd generation for „authentic“ dx sound (rough and hard) we are talking about small changes..
<– 3rd gen FM: TG77 pic thx to lostweb.
4th generation:
FS1R , the only 8 OP + 8 OP(unvoiced) synth!
5th generation:
dx200, plugin concept: works on most yamaha workstation called plg100dx (beside modules for physical modeling aka vl70m, piano and VA (called AN) etc.. well ,the dx-200 is almost soundwise the „2nd generation“..
the DX7 got updated for its old style 12bit D/A converters. so the DX7II and DX7IIFD (and dx7s) were born 1987 (read about disk format of it under „digital“ or tricks). there was a rack version also: the TX802. the 2nd generation DX7II had unisono mode!! find the DX7II as a rack „TX802“ . find unisono in TX816/216,TX802, DX7II series and layer-type sounds on the FS1R,tg/sy models. the DX-21 and DX11/tx81z have performance and/or unison modes ,too! which is very interesting!! sounds fat!
tx802<– TX802 (thx for pic top summa)
btw: there have been a lot of expansions for the DX7 (more memory etc.. like e! etc..)
today you can get a „hardware plugin board“ PLG-DX that is in fact a complete DX-7 for CS6X, Motif series etc..
the dx200 is also based on the DX7 PLG board. its a DX7 with knobs like some sort of macro „easy page“-control.. you can edit the DX7 with software but in a live situation you still have those knobs like „harmonics“ to change the OP frequencies at one knob tweak.. so it is a comprimise,but not a bad one.. there is only one much better solution: the programmer:
jellinghaus dx programmerluxury programmer and the most known yamaha fm synthesizer: DX7, 25 were made by the company from dortmund/germany JELLINGHAUS – controls DX7,TX7 or TF modules of a TX816 module rack as well..
the latest DX7 – based synth is the strongly expanded yamaha FS1R, has 8 OPs and another 8 „unvoiced“ OPs with BPF filters and lots more plus formant sequencing.
Yamaha DX-7II Centennial: there was a special version in 1988 with 76 keys, 32voices, means 2 DX7IIs in one case.. rare of course like the silver version of the DX7.
yamaha fs1rFS1R pic thanks to plasmatron
another on by myself..
fs1r
there is another very rare 8OP „vintage“ synthesizer from 1988 called yamaha FVX1
it’s high price may have shocked the ppl and helped not to sell it much, had also FX on board.
but before the FS1R, yamaha had the big SY and TG series:
yamaha tg77
YAMAHA SY77 and TG77 that had samples on board and the first FM synthesiizers form yamaha with filters (well you do not necessarly need them in an fm synth) 2 filters to be exact. also extra env for pan and samples that could be included in the FM signal path (As an operator), had 3 feddback lines instead of 1, the FS1R also has only 1 feedback line. also the TG77 , SY77 and SY99 all had a free assignable algorithm. the SY99 had some ram slots to use OWN samples with!!.. 4 slots, 512MB each. available. thats the main difference and the 2 spx900 FX processors. the TG77 had ind. outs. the SY77 and TG77 had a smaller fx unit, but also 2×2 FX sections as the SY99 but no sample ram. also the tg and sy synths could route the pitch env individually to the OPs unlike all other yamaha fm synthesizers.
the latest one is the DX7 as a „plugin hardware“ that can be attached to some newer yamaha keyboards and the dx200 groovebox, that has a DX7 and a 16step sequencer in it.. (german: deutscher test hier zu lesen!)
of course there are also software plugins – but not from yamaha. native instruments made the fm7 and loftsoft has the fmheaven. both got a free algo-matrix and fm7 has 128 step envelopes that even sound „wavetable’ish“ if intensitively used.. ;)
6th Gen – Reface DX
this one is even more punchy – but with 4OPs only – maybe a start for more? Feedback is different (shapes the waveforms instead of making it noisier like white noise) but 8step envelopes..
Reface_DX
ONE GENERAL WARNING
: most yamaha FM synthesizer KEYBOARDS do have a range from 0 to 120 for velocity! thats,why some people get shocked when they realize: oh, I can not go beyond 120 (121-127 = maximum velocity). so I recommend the racked versions exept if you do not want to use the keyboards for other synthesizers than the internal one!!
the old dx, the newer one (DX7II), SY77.. etc.. they are all limited here.. anyway the SY99 is still the top model for 6OP FM with rom AND ram samples.. the FS1R sounds a bit „nicer“ .. and it’s response is somewhat „slower“.. we are talking about „freak infos“ here..
______
Yamaha Synth overview..german/deutsch einen test zum fm7 und fmheaven gibts hier..
the typical relationship to control the OPs (OSCs) amplitude – 6 ENVs of a TG77:
Fm synthese DX7 / TG77
an FM algo of a 6 OP synth.. software like the fm7 allows feedbacks as many as you like, in the TG77/SY99 you can have up to 3 of them. the feedback will generate „noise“-like effect.. but you can create very noise like sounds by using a hi-frequency OP at max level.. this one is the TG77’s algorithm – btw: pm/pd phase modulation is often the same result than the fm systems. you know, yamha holds the patents, only pd systems can have feedback ,so yamaha themselves used also „PD/PM“..
algorithmus FM
more on fm in deutsch/german:
  • synthdiplom (download hier!.. deutsch)
  • tutorial area (click tutorial button!)
  • or search for FM by „summa“ ;)Yamaha fm und dx synthesizer STORY und INFO – HIER!!!EDITORS / EDITOREN?beside Apple/Emagic/C-lab sounddiver which will sooner or later be cancelled because apple thinks midi and hardware is over.. try these:for the fs1r find an editor (free) here
    with yamaha fm synth you may want a nice editor? yes! you can still use SOUNDDIVER (thats the best one) if you are on a mac, for pc users you may need to use midiquest or unisyn / .. or the free dx-manager
    Die Seite von KPR hat eine recht gute Liste mit Software die du austesten koenntest.
    http://www.dx7heaven.com/more about dx7 by dave benson
    Dave Bensons Page ist auch ein Muss fuer jeden DX7 Besitzer.
    http://www.math.uga.edu/~djb/html/dx7.html
    some freeware for several synths incl fs1r etc.:
    Hier noch ein Link zu einem Freeware Editor Programm, fuer diverse Synthesizer…
    http://www.jsynthlib.org/
    who ever wants to edit on an atari, still can use this – Wer sich ein wenig mit dem ATARI auskennt kann den ST Emulator Steem mit div. ATARI Software (die mittlerweile freeware ist) einsetzen…
    http://steem.atari.st/
    emulations for ST stuff can be found here:
    für den mac gibts natürlich auch ST emulationen,aber da hat man ja sounddiver (noSTalgia wäre sonst zu nennen siehe emulation.net)
    more FM literature.. free.. off this site..
    http://www.angelfire.com/music/creon/bgfm.htm
    https://web.archive.org/web/20130721201237/http://www.clavia.com:80/nordmodular/Modularzone/FMsynthesis.html
    http://www.soundonsound.com/sos/may00/articles/synth.htm
    http://www.digitalmusicworld.com/html/hardware/SynthSeminars/fm-e/index.html
  • SUMMA has done a nice table to check the ratio between the OSCs – since FM is based on RATIOS I can tell you why: it is simply easier because you can also check the harmonic content by ratios.. with standard synth absolute frequencies or octaves you also don’t have the RANGE 1:32..
    1. Ratio Verhaeltnisse entsprechen der Harmonischen Reihe..
    2. Ganze X:Y Ratio Verhaeltnisse ergeben immer eine „reine Modulation“…
    3. Gerade bei hoeheren Frequenzen ist die Unterteilung feiner als bei der Oktave/Semitone Einteilung…
    the resolution with higher frequencies is much higher with ratios..DX FM -> VZ Coarse (Halbtoene / semitones)
    1 = 0
    2 = 12
    3 = 19
    4 = 24
    5 = 28
    6 = 300.5 = -12
    0.25 = -19
    0.125 = -24
    0.065 = -28
    0.0325 = -30in german DX7II disc format:
    Der DX7II schreibt seine Disketten im MSX-Format, ein altes Format aus der 8-bit Computer Zeit, den japanische Hersteller fast schon zum Ende der 8bit-Ära geschaffen haben.. Wenn man mit dem Mac oder PC jetzt auf die Sounds zugreifen (zB um sie in Native Instruments FM7 oder fmheaven zu importieren) will muss man sich wohl nach einem Converter umschauen der MSX Diskformate lesen kann. Also nicht DOS! Es gibt noch ein paar andere ältere Geräte von Yamaha die dieses Format benutzen.. Vorsicht: viele emulatoren emulieren nicht das disk-format sondern die hardware und arbeiten mit abbildern der MSX disks im DOS oder Mac/HFS(+) format.. versuchs bei www.emulation.net
  • Yamaha Synth overview..
Related posts
One Thought to “Yamaha FM-Synthesizer Generation/s”
  1. YAMAHAのシンセサイザーは、とても素晴らしい音色です!
Comments are closed.
