633k
inactive profile.
..in Zeiten des großen B gibt es auch neue, kleine, unabhängige Hersteller. Da dürfte doch für jeden das passende zu finden sein.
Synth voice features
- Fully analog signal path
- 2x analog oscillators
- Continuously variable waveform
- Thru-zero frequency modulation
- Hard-sync
- Filter overdrive
- 1x 3-pole multi-mode filter
- Continuously variable filter color
- 1x Main ADSR envelope
- 13x dedicated AD envelopes
- 20x dedicated modulator
- 4 waveforms
- Type settings : Free/Synced/Audio-Rate
- Audio-Rate anti-aliased, quantized to OSC1
- Free from 0.1 to 80 seconds
- Attack-Decay segment from 10us to 20s
- Up to 64 step per pattern
- Individual length/scale/beat-division per pattern
- Individual microshift/ratchet/probability per step
- Per step parameter automation (offsets)
- Swing/Slide/Accent
- Copy/paste anything
- Undo/Redo anything with 1024 events history
- Mod Note mode
- Fast, clock independent project Load/Save
- Quandtized note randomizer
- Ranged parameter automation randomizer
- Step randomizer
- Mod note randomizer
- Microshift/Probability/Ratchet randomizer
- 32 projects
- 64 patterns per projects
- 3200 parameter automation per step
- 40 mod note per projects
- 23x transilluminated potentiometer
- 24x illuminated silent mechanical switch
- 23x 808-style switch
- MIDI In/Out/Thru
- 1x 1/4” unbalanced main audio out jack
- 2x 1/8” eurorack Clock/Reset input
- 2x 1/8” eurorack CV outputs
- 2x 1/8” eurorack Gate outputs
- 48kHz internal CV D/A converters
- Flash-EEPROM upgradable OS
- MIDI class compliant USB-B port
- Output level: +15dBu maximum
- Output impedance: 200 Ohm
- Voltage range: -8V/+8V
- 1V/oct resolution : 3cents of a semitone
- Unit consumption: 10W typical
- Recommanded power supply: 15V DC, 2A
- Machined aluminum front panel
- ABS-PC back panel
- Dimmensions: W300xD150xH42
- Weight: approx. 1.6kg
- 3-year Norand warranty
- Mono (obviously)
- High-quality power supply
- Quick-start guide
