Die Antwort vom Support möchte ich euch nicht vorenthalten, auch wenn ich mich damit blamiere...
Zunächst einmal die Beschreibung des "vermeintlichen Fehlers" (ja ich hätte hier fragen sollen, wie es im originalen Mono/Poly ist)
1.
Preconditions:
- Set Portamento to a value != 0 to hear when Portamento occurs and when not.
- Arpeggiator settings = 1 OCT, UP, off.
- OSC1 - OSC4 all set to the SAME register (e.g. 8")
- Voice mode = Poly/Poly
- choose a single note to play on the keyboard. It doesn't matter which one, please only remember which it was.
- play it two times.
- The first time you might hear a portamento, but the second time you will not, of course.
BUT THIS IS NOT THE ISSUE!
How to reproduce it?
- Set the arpeggiator to 1 OCT, UP, Latch
- Play a different key on the keyboard, for your convenience choose one two octaves higher.
- The first 4 tones that can be heard will have portamento (glide from the deeper note played before), the 5th and all subsequent one will not sound with portamento.
So in the first 4 steps the Monopoly always glides from the note that was played BEFORE the arpeggiator to the key hold after it was switched on.
From step 5 onwards it will forget this and only play the note that was played after the arpeggiator was switched on.
2.
same preconditions:
BUT AGAIN THIS IS NOT THE ISSUE!
- This time play TWO notes on the keyboard
For your convenience choose as the first note the one a single octave above the previously played one (with arpeggiator = off) and choose as the second note the same key two octaves higher.
- The first 4 (four!) tones that can be heard _will_ have portamento, the 5th and all subsequent one will not sound with portamento.
When does it behave as expected?
Portamento can be heard with each note even after the 5th note when you choose THREE random notes after you have switched on the arpeggiator.
It also seems to work in other voice modes.
Die Antwort des Supports (sie haben das auf dem originalen Mono/Poly reproduziert):
At the first round of ARP poly mode, the note always different from the initial note of the oscillator, so it would start glide.
If you press 1, 2 or 4 notes, after the first round, the same note will come to same oscillator, so It wouldn’t glide.
But if you press 3 notes, each round the same oscillator will play a different note, it will glide.
We have tested the original model here and it just acts like the same as yours, this is not a bug but expected behavior.
